Home » Archived » BIRT » 'Select *' query always generates error
'Select *' query always generates error [message #198044] Fri, 27 October 2006 12:08 Go to next message
Originally posted by: goykhmanster.gmail.com
I am having a problem with BIRT report viewer.
Any time my query text has 'select *' in it (select all columns), i get
the following error on the report page:
Exception in:
ReportEngineService.runReport( )
Error happended while running the report
I am using BIRT report viewer 2.0.2 with Eclipse 3.1.
Has any of you ever got this problem? Is there a workaround? I would
appreciate any help. Thanks in advance.
Re: 'Select *' query always generates error [message #198211 is a reply to message #198044] Sun, 29 October 2006 21:44 Go to previous messageGo to next message
Can you get any error when you preview result in dataset editor page?Could
you please attach the detailed exception trace on the report page?
Mingxia
"Boris" <goykhmanster@gmail.com> wrote in message
news:11b4d5f698e226f26f1e099cab48009c$1@www.eclipse.org...
> Hi
> I am having a problem with BIRT report viewer. Any time my query text has
> 'select *' in it (select all columns), i get the following error on the
> report page:
> Exception in:
Re: 'Select *' query always generates error [message #198348 is a reply to message #198211] Mon, 30 October 2006 10:48 Go to previous messageGo to next message
This is the error from dataset editor:
An unexpected internal exception occurred.Please see log for detail.
Plug-in Provider:Eclipse.org
Plug-in Name:BIRT Designer UI
Plug-in ID:org.eclipse.birt.report.designer.ui
Version:2.0.2
Error Code:Error.GUIException.invokedByUnexpectedException
Error Message:IClob.getSubString()
Re: 'Select *' query always generates error [message #198385 is a reply to message #198348] Mon, 30 October 2006 21:24 Go to previous messageGo to next message
Boris,
It seems that your table contains Clob column....Could you please tell me
the database and jdbc driver you used?
Mingxia
news:898e2534c4d11aab9bf4bbe108ace096$1@www.eclipse.org...
> Version:2.0.2
Re: 'Select *' query always generates error [message #198438 is a reply to message #198385] Tue, 31 October 2006 13:24 Go to previous messageGo to next message
Originally posted by: bgoykhman.hotmail.com
Hmm... Thanks for pointing that out...
I am using Oracle Thin driver. Should i use OCI driver instead?
Re: 'Select *' query always generates error [message #198594 is a reply to message #198438] Tue, 31 October 2006 22:34 Go to previous messageGo to next message
Hi Boris,
Oracle Thin driver should also support Clob datatype. Maybe you could try
the latest version of Birt. BTW, could you provide the detailed error log
information in Error Log perspective? Thanks a lot.
Mingxia
"Boris" <bgoykhman@hotmail.com> wrote in message
news:ff9ab5f83da359b299c945aef911337e$1@www.eclipse.org...
Re: 'Select *' query always generates error [message #198642 is a reply to message #198594] Wed, 01 November 2006 13:24 Go to previous message
Error 2006-10-31 14:30:29.196 Error Message:IClob.getSubString()
Info 2006-10-31 14:30:29.196 Version:2.0.2
Info 2006-10-31 14:30:29.196 Plug-in ID:org.eclipse.birt.report.designer.ui
Info 2006-10-31 14:30:29.196 Plug-in Name:BIRT Designer UI
Info 2006-10-31 14:30:29.196 Plug-in Provider:Eclipse.org
Previous Topic:ODA Extension
Next Topic:Storing custom metadata in rptdesign file?
Current Time: Fri Jul 25 22:04:33 EDT 2025
Powered by FUDForum. Page generated in 0.05515 seconds
