Exceptions at startup when running test workspace from IDE [message #1219005] |
Fri, 29 November 2013 14:52 |
Hi anybody,
I want to start a run configuration (Eclipse Application) with my xtext bundles applied to manually test some issues. I sometimes get the following exception (next time I start it normally works). Can you tell me what's the problem?
Thanks for any help,
Cheers
Markus
!SESSION 2013-11-29 15:45:29.482 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_41
java.vendor=Apple Inc.
BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=de_DE
Framework arguments: -product org.eclipse.sdk.ide
Command-line arguments: -product org.eclipse.sdk.ide -data /Users/OleyMa/vcs/itemisTrunkSvn/testprojects -dev file:/Users/OleyMa/vcs/itemisTrunkSvn/.metadata/.plugins/org.eclipse.pde.core/Test Workspace/dev.properties -os macosx -ws cocoa -arch x86_64 -consoleLog
!ENTRY org.eclipse.core.resources 2 10035 2013-11-29 15:45:32.623
!MESSAGE The workspace exited with unsaved changes in the previous session; refreshing workspace to recover changes.
!ENTRY org.eclipse.emf.ecore 2 0 2013-11-29 15:45:32.840
!MESSAGE Both 'vsa.marvin.mod.workflow.dsl' and 'vsa.marvin.mod.workflow.dsl' register a package for 'http://www.vsa.de/marvin/dsl/mask/0.1'
!MESSAGE Both 'vsa.marvin.mod.workflow.dsl' and 'vsa.marvin.mod.workflow.dsl' register a package for 'http://www.vsa.de/marvin/dsl/objectmodel/0.1'
!ENTRY org.eclipse.emf.ecore 2 0 2013-11-29 15:45:32.842
!MESSAGE Both 'vsa.marvin.mod.workflow.dsl' and 'vsa.marvin.mod.workflow.dsl' register a package for 'http://www.vsa.de/marvin/dsl/workflowcommon/0.1'
!MESSAGE Both 'vsa.marvin.mod.workflow.dsl' and 'vsa.marvin.mod.workflow.dsl' register a package for 'http://www.vsa.de/workflow/1.0'
!ENTRY org.eclipse.equinox.preferences 4 2 2013-11-29 15:45:33.944
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.equinox.preferences".
!STACK 0
java.lang.ExceptionInInitializerError
at org.eclipse.jdt.ui.PreferenceConstants.initializeDefaultValues(PreferenceConstants.java:3739)
at org.eclipse.jdt.internal.ui.JavaUIPreferenceInitializer.initializeDefaultPreferences(JavaUIPreferenceInitializer.java:38)
at org.eclipse.core.internal.preferences.PreferenceServiceRegistryHelper$1.run(PreferenceServiceRegistryHelper.java:300)
at org.eclipse.core.internal.preferences.PreferenceServiceRegistryHelper.runInitializer(PreferenceServiceRegistryHelper.java:303)
at org.eclipse.core.internal.preferences.PreferenceServiceRegistryHelper.applyRuntimeDefaults(PreferenceServiceRegistryHelper.java:131)
at org.eclipse.core.internal.preferences.PreferencesService.applyRuntimeDefaults(PreferencesService.java:368)
at org.eclipse.core.internal.preferences.DefaultPreferences.applyRuntimeDefaults(DefaultPreferences.java:221)
at org.eclipse.core.internal.preferences.DefaultPreferences.load(DefaultPreferences.java:274)
at org.eclipse.core.internal.preferences.EclipsePreferences.create(EclipsePreferences.java:409)
at org.eclipse.core.internal.preferences.EclipsePreferences.internalNode(EclipsePreferences.java:670)
at org.eclipse.core.internal.preferences.EclipsePreferences.node(EclipsePreferences.java:812)
at org.eclipse.core.internal.preferences.AbstractScope.getNode(AbstractScope.java:38)
at org.eclipse.core.runtime.preferences.DefaultScope.getNode(DefaultScope.java:76)
at org.eclipse.ui.preferences.ScopedPreferenceStore.getDefaultPreferences(ScopedPreferenceStore.java:250)
at org.eclipse.ui.preferences.ScopedPreferenceStore.getPreferenceNodes(ScopedPreferenceStore.java:285)
at org.eclipse.ui.preferences.ScopedPreferenceStore.internalGet(ScopedPreferenceStore.java:475)
at org.eclipse.ui.preferences.ScopedPreferenceStore.getBoolean(ScopedPreferenceStore.java:387)
at org.eclipse.jdt.internal.ui.preferences.MembersOrderPreferenceCache.install(MembersOrderPreferenceCache.java:61)
at org.eclipse.jdt.internal.ui.JavaPlugin.ensurePreferenceStoreBackwardsCompatibility(JavaPlugin.java:426)
at org.eclipse.jdt.internal.ui.JavaPlugin.start(JavaPlugin.java:373)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:300)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:478)
at org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger(BundleLoader.java:263)
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:109)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:469)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:395)
at org.eclipse.osgi.internal.loader.SingleSourcePackage.loadClass(SingleSourcePackage.java:35)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:461)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at java.lang.ClassLoader.loadClass(ClassLoader.java:247)
at org.eclipse.xtext.ui.shared.internal.Activator.isJavaEnabled(Activator.java:87)
at org.eclipse.xtext.ui.shared.internal.Activator.initializeInjector(Activator.java:57)
at org.eclipse.xtext.ui.shared.internal.Activator.start(Activator.java:102)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:464)
at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(BundleLoader.java:340)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:229)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadClass(AbstractBundle.java:1212)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:174)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
at org.eclipse.core.internal.events.BuildManager.instantiateBuilder(BuildManager.java:894)
at org.eclipse.core.internal.events.BuildManager.initializeBuilder(BuildManager.java:847)
at org.eclipse.core.internal.events.BuildManager.getBuilder(BuildManager.java:538)
at org.eclipse.core.internal.events.BuildManager.getBuilder(BuildManager.java:567)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:237)
at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:292)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:295)
at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:351)
at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:374)
at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBuildJob.java:143)
at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJob.java:241)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
Caused by: org.eclipse.swt.SWTException: Invalid thread access
at org.eclipse.swt.SWT.error(SWT.java:4397)
at org.eclipse.swt.SWT.error(SWT.java:4312)
at org.eclipse.swt.SWT.error(SWT.java:4283)
at org.eclipse.swt.widgets.Display.error(Display.java:1076)
at org.eclipse.swt.widgets.Display.checkDevice(Display.java:624)
at org.eclipse.swt.graphics.Device.getSystemFont(Device.java:481)
at org.eclipse.jface.preference.PreferenceConverter.<clinit>(PreferenceConverter.java:84)
... 79 more
!ENTRY org.eclipse.osgi 4 0 2013-11-29 15:45:33.954
!MESSAGE An error occurred while automatically activating bundle org.eclipse.jdt.ui (403).
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.jdt.internal.ui.JavaPlugin.start() of bundle org.eclipse.jdt.ui.
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:734)
Caused by: org.eclipse.core.runtime.AssertionFailedException: null argument:
at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:85)
at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:73)
at org.eclipse.jface.resource.FontRegistry.<init>(FontRegistry.java:283)
at org.eclipse.jface.resource.FontRegistry.<init>(FontRegistry.java:308)
at org.eclipse.jface.resource.JFaceResources.getFontRegistry(JFaceResources.java:342)
at org.eclipse.jdt.internal.ui.JavaPlugin.ensurePreferenceStoreBackwardsCompatibility(JavaPlugin.java:448)
... 55 more
Root exception:
0 [Worker-1] WARN org.eclipse.xtext.ui.shared.internal.Activator - Disabling JDT use. : org/eclipse/jdt/ui/JavaUI
!ENTRY org.apache.log4j 2 0 2013-11-29 15:45:33.976
!MESSAGE org.eclipse.xtext.ui.shared.internal.Activator - Disabling JDT use. : org/eclipse/jdt/ui/JavaUI
Configure logging in path /Users/OleyMa/.egripse/targetplatform_201307031350.zip_exploded/eclipse/
Logging in file /Users/OleyMa/.egripse/targetplatform_201307031350.zip_exploded/eclipse/logs/mod.log
Modeling-Loglevel: FINER
13-11-29 15:45:34FINE .marvin.mod.workflow.Activator: Activating vsa.marvin.mod.workflow {
!ENTRY org.eclipse.osgi 4 0 2013-11-29 15:45:34.930
!MESSAGE Application error
!STACK 1
java.lang.NoClassDefFoundError: Could not initialize class org.eclipse.jface.preference.PreferenceConverter
at org.eclipse.ui.internal.themes.ThemeElementHelper.installFont(ThemeElementHelper.java:104)
at org.eclipse.ui.internal.themes.ThemeElementHelper.populateRegistry(ThemeElementHelper.java:59)
at org.eclipse.ui.internal.Workbench$29.runWithException(Workbench.java:1699)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:180)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:150)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4650)
at org.eclipse.ui.internal.StartupThreading.runWithoutExceptions(StartupThreading.java:94)
at org.eclipse.ui.internal.Workbench.initializeFonts(Workbench.java:1693)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:1551)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2702)
at org.eclipse.ui.internal.Workbench.access$7(Workbench.java:2591)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:608)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:567)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
at org.eclipse.equinox.launcher.Main.main(Main.java:1426)
13-11-29 15:45:34FINE .marvin.mod.workflow.Activator: } Activating vsa.marvin.mod.workflow => 0,874sec
***WARNING: Display must be created on main thread due to Cocoa restrictions.
!ENTRY org.eclipse.osgi 4 0 2013-11-29 15:45:34.955
!MESSAGE An unexpected runtime error has occurred.
!STACK 0
at org.eclipse.swt.widgets.Display.createDisplay(Display.java:833)
at org.eclipse.swt.widgets.Display.create(Display.java:816)
at org.eclipse.swt.graphics.Device.<init>(Device.java:130)
at org.eclipse.swt.widgets.Display.<init>(Display.java:707)
at org.eclipse.swt.widgets.Display.<init>(Display.java:698)
at org.eclipse.swt.widgets.Display.getDefault(Display.java:1396)
at org.eclipse.ui.plugin.AbstractUIPlugin.refreshPluginActions(AbstractUIPlugin.java:484)
at org.eclipse.ui.plugin.AbstractUIPlugin$2.bundleChanged(AbstractUIPlugin.java:602)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.dispatchEvent(BundleContextImpl.java:847)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
!ENTRY vsa.marvin.mod.workflow.dsl.ui 4 0 2013-11-29 15:45:34.955
!MESSAGE FrameworkEvent ERROR
!STACK 0
1323 [Worker-1] WARN org.eclipse.xtext.ui.shared.internal.Activator - Disabling JDT use. : org/eclipse/jdt/ui/JavaUI
!ENTRY org.apache.log4j 2 0 2013-11-29 15:45:35.298
1331 [Worker-1] ERROR org.eclipse.xtext.ui.shared.internal.ExecutableExtensionFactory - java.lang.NullPointerException
!ENTRY org.apache.log4j 4 0 2013-11-29 15:45:35.306
!MESSAGE org.eclipse.xtext.ui.shared.internal.ExecutableExtensionFactory - java.lang.NullPointerException
!ENTRY org.eclipse.core.resources 4 2 2013-11-29 15:45:35.306
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.core.resources".
!STACK 0
at org.eclipse.xtext.ui.shared.internal.ExecutableExtensionFactory.getBundle(ExecutableExtensionFactory.java:19)
at org.eclipse.xtext.ui.guice.AbstractGuiceAwareExecutableExtensionFactory.create(AbstractGuiceAwareExecutableExtensionFactory.java:57)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:262)
!ENTRY org.eclipse.core.resources 2 75 2013-11-29 15:45:35.307
!MESSAGE Errors occurred during the build.
!SUBENTRY 1 org.eclipse.core.resources 2 566 2013-11-29 15:45:35.307
!MESSAGE java.lang.NullPointerException encountered while running simpleProject.
!STACK 0
!ENTRY org.eclipse.core.jobs 2 2Job found still running after platform shutdown. Jobs should be canceled by the plugin that scheduled them during shutdown: org.eclipse.ui.internal.activities.MutableActivityManager$3$1
2013-11-29 15:45:36.199
!MESSAGE Job found still running after platform shutdown. Jobs should be canceled by the plugin that scheduled them during shutdown: org.eclipse.ui.internal.activities.MutableActivityManager$3$1
!ENTRY org.eclipse.core.jobs 2 2 2013-11-29 15:45:36.200
!ENTRY org.eclipse.core.jobs 2 2 2013-11-29 15:45:36.201
!ENTRY org.eclipse.core.jobs 2 2 2013-11-29 15:45:36.202
!ENTRY org.eclipse.core.jobs 2 2 2013-11-29 15:45:36.203
!ENTRY org.eclipse.core.jobs 2 2 2013-11-29 15:45:36.204
!ENTRY org.eclipse.core.jobs 2 2 2013-11-29 15:45:36.205
!ENTRY org.eclipse.core.jobs 2 2 2013-11-29 15:45:36.206
An error has occurred. See the log file
FUDForum. Page generated in 0.03898 seconds
