Home » Language IDEs » ServerTools (WTP) » Cannot create web project
Cannot create web project [message #197998] Wed, 08 August 2007 15:53 Go to next message
Originally posted by: mrzhu.mit.edu
I tried WTP+Eclipse all-in-one install (released on June 26), I also tried
Eclipse for J2EE Developer (version 3.3) then installed WTP package via
software update. In both cases, when I started Eclipse and tried to create
a web project by going to File > New > Other, I did not see any choice for
for project. The menu items for web project did not appear!
I use JDK 1.6. I don't think this should affect eclipse.
Any idea about how I can get Web Project menu items to show up?
- Harry
Re: Cannot create web project [message #198613 is a reply to message #197998] Tue, 21 August 2007 15:56 Go to previous messageGo to next message
Originally posted by: mjafar.mail.wtamu.edu
I have the same problem
Installed, de-installed
eclipse-jee-europa-win32.zip
wtp-all-in-one-sdk-R-2.0-200706260303-win32.zip
Many times last couple of days
I followed the instructions in the video tutorial
to the point of create new project,
Could not see the web options at all
Help i grealy appreiaed
MJJ
"harry zhu" <mrzhu@mit.edu> wrote in message
news:b64faf197cff4934d09db931d7db60c2$1@www.eclipse.org...
> - Harry
Re: Cannot create web project [message #198621 is a reply to message #198613] Tue, 21 August 2007 16:07 Go to previous messageGo to next message
Originally posted by: kosta.bea.com
I am not sure why it would cause problems to explicitly install WTP on
top of Eclipse IDE for Java EE developers, but Eclipse IDE for Java EE
developers already includes WTP plugins.
All you need to do is expand the eclipse-jee-europa-win32.zip file.
- Konstantin
Re: Cannot create web project [message #198629 is a reply to message #198621] Tue, 21 August 2007 16:15 Go to previous messageGo to next message
It is driving me nuts
I deleted my previous eclipse directory installs
then I extracted the zip
Some how I can not see the web components
I am sure it is something simple somewhere
But I can not put my finger on it
I use windows XP, I have tomcat 6.0 running
Help is greatly appreciated
MJJ
"Konstantin Komissarchik" <kosta@bea.com> wrote in message
news:46CB4617.5020904@bea.com...
>I am not sure why it would cause problems to explicitly install WTP on top
> - Konstantin
Re: Cannot create web project [message #198637 is a reply to message #198629] Tue, 21 August 2007 18:25 Go to previous messageGo to next message
Make sure that Eclipse is launching on a Java 5 VM or newer. If it is
launched on a 1.4 VM, a lot of the WTP functionality will not be available.
You can control which VM Eclipse chooses when it launches by using a -vm
switch in the eclipse.ini file.
- Konstantin
Re: Cannot create web project [message #198645 is a reply to message #198637] Tue, 21 August 2007 19:21 Go to previous message
Thanks Konstantin:
I was picking a 1.4 jvm some where along the way of a very long path.
Thanks to Windows XP,
it makes it virtually impossible to gracefully manage the path environment.
Apparently setting the run time environment in
Eclipse: Windows -> Preferences-> Installed JREs-> Excecution Environment
to a 6.0 is not enough to pick the right jvm
While looking at
Eclipse: help-> about Eclipse platform -> Configration Details
I noticed that it is picking a 1.4 jvm.
That gave me some clues knowing where that jvm came from (Oracle 10 client).
Lesson learned: Make sure the right jvm in the path environment is picked
Hope this helps some one else
MJJ
news:46CB6670.1040908@bea.com...
> available.
> - Konstantin
Previous Topic:Use xml editor in rcp application
Next Topic:Web Services Explorer Performance
Current Time: Fri May 09 21:25:20 EDT 2025
Powered by FUDForum. Page generated in 0.10653 seconds
