Schema with more than 100 tables [message #197954] |
Fri, 27 October 2006 05:28  |
Originally posted by: pvmurthy.effigent.com
Hi All,
I was trying out the Dataset creator on my dev schema -- which has
more than 100 tables (Oracle DB)
THe Data set editor, seems to restrict the number of tables listed in
the table-selector view to only 100. Because of this, I am not able to
use any drag-n-drop feature for the remaining tables and have to resort
to hand coding the sqls.
Any way to get around this?
Cheers
Murthy
Re: Schema with more than 100 tables [message #198052 is a reply to message #198009] |
Fri, 27 October 2006 13:22  |
Thanks Leos, that worked.
Did not occur to me to check there at all :)
In article <eht05i$alg$1@utils.eclipse.org>,
Leos Literak <literakl@centrum.cz> wrote:
> Murthy Parthasarathi napsal(a):
> > Hi All,
> try Window > Preferences and there
> Report Design > Data set Editor > JDBC Data set
> and here Maximum number of tables in each schema to display,
> I can see 100 there.
> leos
FUDForum. Page generated in 0.03309 seconds
