Home » Archived » BIRT » Tutorial 5, Field Guide to BIRT, problem running the "Writing an event handler in JavaScript&qu
Tutorial 5, Field Guide to BIRT, problem running the "Writing an event handler in JavaScript&qu [message #197914] Thu, 26 October 2006 18:51 Go to next message
Originally posted by: home4slc.pacbell.net
--------------050507090807010508070107
Content-Type: text/plain; charset=us-ascii; format=flowed
Im having trouble with on of the tutorials in the on-line help, "Field
Guide to BIRT", and wondering if it is a bug or pilot error. I will be
happy to enter a bugzilla if it is a bug if someone can take a moment to
help with this.
I completed tutorial 1 and have a sample report based on completing this
tutorial. In tutorial 5, Writing an event handler in JavaScript, I've
found a problem when following the instructions.
In Task 2 of Tutorial 5, Create and initialize a counter in
Table.onCreate() method,
the screen shot, Figure 22-5 shows the row called row["CUSTOMERNAME"],
but I believe this should be dataSetRow["CUSTOMERNAME"]. (This is
irrelevant to the problem later, but I believe the screen shot is
incorrect?)
Also, in Task 3, step 4 here is the JavaScript:
CustName=row.getExpressionValue( "row[CUSTOMERNAME]" );
The output I get when running the report only shows the first column's
first row (cell 1) correctly (listing 1 below), and I'm getting a stack
trace, and the CountOfMinis never increments. Here is the interesting
part of the stack trace:
(ThreadPool.java:683) at java.lang.Thread.run(Unknown Source)Caused by:
org.mozilla.javascript.EcmaError: TypeError: Cannot call method
"indexOf" of null (<inline>#3)
So I changed the above line of JavaScript to this:
CustName=row.getExpressionValue("row["CUSTOMERNAME"]");
and I get all of the output, the CountOfMinis still does not increment
and I get this stack trace (Listing 2);
org.mozilla.javascript.EvaluatorException: missing ) after argument list
(<inline>#4) at
org.mozilla.javascript.DefaultErrorReporter.runtimeError(Def aultErrorReporter.java:95)
I looked at the 2.1.1 version of the source and noticed that
getExpressionValue has been decremented. So I tried to modify the
example to what I thought would be correct and I still have problems.
I modified the code snippet for Task 3 to be this:
CustName = this.getRowData().getColumnValue(0);
Now I get the correct CountOfMinis, and no stack trace, but only the
first cell appears.
Can someone tell me the correct JavaScript to run this example? I've
also attached my report design file.
Susan
Listing 2
The following items have errors:
Data (id = 23):
- There are errors evaluating script "row=this.getRowData();
//CustName = this.getRowData().getColumnValue(0);
//countOfMinis = row.getColumnValue("row[CUSTOMERNAME]");
if( CustName.indexOf("Mini") != -1 )
countOfMinis += 1;".
Error.ScriptEvaluationError ( 122 time(s) )
detail : org.eclipse.birt.report.engine.api.EngineException: There are
errors evaluating script "row=this.getRowData();//CustName =
this.getRowData().getColumnValue(0);//countOfMinis =
row.getColumnValue("row[CUSTOMERNAME]");CustName=row.getExpressionValue( "row["CUSTOMERNAME"]");
if( CustName.indexOf("Mini") != -1 ) countOfMinis += 1;". at
org.eclipse.birt.report.engine.executor.ExecutionContext.eva luate(ExecutionContext.java:556)
org.eclipse.birt.report.engine.executor.ExecutionContext.eva luate(ExecutionContext.java:528)
org.eclipse.birt.report.engine.script.internal.ScriptExecuto r.handleJSInternal(ScriptExecutor.java:66)
org.eclipse.birt.report.engine.script.internal.ScriptExecuto r.handleJS(ScriptExecutor.java:50)
org.eclipse.birt.report.engine.script.internal.DataItemScrip tExecutor.handleOnCreate(DataItemScriptExecutor.java:52)
org.eclipse.birt.report.engine.executor.DataItemExecutor.exe cute(DataItemExecutor.java:119)
org.eclipse.birt.report.engine.internal.executor.l18n.Locali zedReportItemExecutor.execute(LocalizedReportItemExecutor.ja va:35)
org.eclipse.birt.report.engine.layout.html.HTMLBlockStacking LM.layoutChildren(HTMLBlockStackingLM.java:63)
org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.la yout(HTMLAbstractLM.java:159)
org.eclipse.birt.report.engine.layout.html.HTMLInlineStackin gLM.resumeLayout(HTMLInlineStackingLM.java:94)
org.eclipse.birt.report.engine.layout.html.HTMLInlineStackin gLM.layoutChildren(HTMLInlineStackingLM.java:138)
org.eclipse.birt.report.engine.layout.html.HTMLRowLM.layout( HTMLRowLM.java:30)
org.eclipse.birt.report.engine.layout.html.HTMLBlockStacking LM.layoutChildren(HTMLBlockStackingLM.java:68)
org.eclipse.birt.report.engine.layout.html.HTMLTableBandLM.l ayoutChildren(HTMLTableBandLM.java:67)
org.eclipse.birt.report.engine.layout.html.HTMLTableLM.layou tChildren(HTMLTableLM.java:74)
org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout Children(HTMLPageLM.java:139)
org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout (HTMLPageLM.java:81)
org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutE ngine.layout(HTMLReportLayoutEngine.java:80)
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run (RunAndRenderTask.java:194)
org.eclipse.birt.report.service.ReportEngineService.runAndRe nderReport(Unknown
Source) at
Source) at
org.eclipse.birt.report.service.BirtViewerReportService.runA ndRenderReport(Unknown
Source) at
org.eclipse.birt.report.service.actionhandler.BirtRunAndRend erActionHandler.__execute(Unknown
Source) at
org.eclipse.birt.report.service.actionhandler.AbstractBaseAc tionHandler.execute(Unknown
Source) at
org.eclipse.birt.report.presentation.aggregation.layout.Engi neFragment.doService(Unknown
Source) at
org.eclipse.birt.report.presentation.aggregation.AbstractBas eFragment.service(Unknown
Source) at
org.eclipse.birt.report.servlet.BirtEngineServlet.__doGet(Un known
Source) at
org.eclipse.birt.report.servlet.BaseReportEngineServlet.doGe t(Unknown
Source) at javax.servlet.http.HttpServlet.service(HttpServlet.java:740)
org.apache.axis.transport.http.AxisServletBase.service(AxisS ervletBase.java:327)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:853) at
org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:247)
org.apache.catalina.core.ApplicationFilterChain.doFilter(App licationFilterChain.java:193)
org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.java:256)
org.apache.catalina.core.StandardPipeline$StandardPipelineVa lveContext.invokeNext(StandardPipeline.java:643)
org.apache.catalina.core.StandardPipeline.invoke(StandardPip eline.java:480)
at org.apache.catalina.core.ContainerBase.invoke(ContainerBase. java:995)
org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.java:191)
org.apache.catalina.valves.CertificatesValve.invoke(Certific atesValve.java:246)
org.apache.catalina.core.StandardPipeline$StandardPipelineVa lveContext.invokeNext(StandardPipeline.java:641)
org.apache.catalina.core.StandardContext.invoke(StandardCont ext.java:2422)
org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:180)
org.apache.catalina.valves.ErrorDispatcherValve.invoke(Error DispatcherValve.java:171)
org.eclipse.tomcat.internal.EclipseErrorReportValve.invoke(E clipseErrorReportValve.java:153)
org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java:174)
org.apache.coyote.tomcat4.CoyoteAdapter.service(CoyoteAdapte r.java:199)
org.apache.coyote.http11.Http11Processor.process(Http11Proce ssor.java:828)
org.apache.coyote.http11.Http11Protocol$Http11ConnectionHand ler.processConnection(Http11Protocol.java:700)
org.apache.tomcat.util.net.TcpWorkerThread.runIt(PoolTcpEndp oint.java:584)
org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.ru n(ThreadPool.java:683)
(<inline>#4) at
org.mozilla.javascript.DefaultErrorReporter.error(DefaultErr orReporter.java:82)
at org.mozilla.javascript.Parser.addError(Parser.java:120) at
org.mozilla.javascript.Parser.reportError(Parser.java:126) at
org.mozilla.javascript.Parser.mustMatchToken(Parser.java:212 ) at
org.mozilla.javascript.Parser.argumentList(Parser.java:1595) at
org.mozilla.javascript.Parser.memberExprTail(Parser.java:172 4) at
org.mozilla.javascript.Parser.memberExpr(Parser.java:1640) at
org.mozilla.javascript.Parser.unaryExpr(Parser.java:1500) at
org.mozilla.javascript.Parser.mulExpr(Parser.java:1429) at
org.mozilla.javascript.Parser.addExpr(Parser.java:1410) at
org.mozilla.javascript.Parser.shiftExpr(Parser.java:1390) at
org.mozilla.javascript.Parser.relExpr(Parser.java:1364) at
org.mozilla.javascript.Parser.eqExpr(Parser.java:1320) at
org.mozilla.javascript.Parser.bitAndExpr(Parser.java:1309) at
org.mozilla.javascript.Parser.bitXorExpr(Parser.java:1298) at
org.mozilla.javascript.Parser.bitOrExpr(Parser.java:1287) at
org.mozilla.javascript.Parser.andExpr(Parser.java:1275) at
org.mozilla.javascript.Parser.orExpr(Parser.java:1263) at
org.mozilla.javascript.Parser.condExpr(Parser.java:1246) at
org.mozilla.javascript.Parser.assignExpr(Parser.java:1228) at
org.mozilla.javascript.Parser.assignExpr(Parser.java:1234) at
org.mozilla.javascript.Parser.expr(Parser.java:1217) at
org.mozilla.javascript.Parser.statementHelper(Parser.java:11 04) at
org.mozilla.javascript.Parser.statement(Parser.java:616) at
org.mozilla.javascript.Parser.parse(Parser.java:347) at
org.mozilla.javascript.Parser.parse(Parser.java:287) at
org.mozilla.javascript.Context.compileImpl(Context.java:2349 ) at
org.mozilla.javascript.Context.compileString(Context.java:13 72) at
org.mozilla.javascript.Context.compileString(Context.java:13 61) at
org.eclipse.birt.core.script.ScriptContext.eval(ScriptContex t.java:221)
org.eclipse.birt.report.engine.executor.ExecutionContext.eva luate(ExecutionContext.java:549)
.... 65 more
Listing 1
Original example output
Customer Phone Contact
Alpha Cognac
Oct 26, 2006 11:37 AM
Data (id = 23):
CustName=row.getExpressionValue("row[CUSTOMERNAME]");
"row=this.getRowData();CustName=row.getExpressionValue("row[CUSTOMERNAME] ");
Source) at
Source) at
Source) at
Source) at
Source) at
Source) at
Source) at
Source) at
"indexOf" of null (<inline>#3) at
org.mozilla.javascript.ScriptRuntime.constructError(ScriptRu ntime.java:3240)
org.mozilla.javascript.ScriptRuntime.constructError(ScriptRu ntime.java:3230)
org.mozilla.javascript.ScriptRuntime.typeError(ScriptRuntime .java:3246)
org.mozilla.javascript.ScriptRuntime.typeError2(ScriptRuntim e.java:3265)
org.mozilla.javascript.ScriptRuntime.undefCallError(ScriptRu ntime.java:3284)
org.mozilla.javascript.ScriptRuntime.getPropFunctionAndThis( ScriptRuntime.java:1965)
at org.mozilla.javascript.gen.c11._c0(<inline>:3) at
org.mozilla.javascript.gen.c11.call(<inline>) at
org.mozilla.javascript.ContextFactory.doTopCall(ContextFacto ry.java:304)
org.mozilla.javascript.ScriptRuntime.doTopCall(ScriptRuntime .java:2769)
at org.mozilla.javascript.gen.c11.call(<inline>) at
org.mozilla.javascript.gen.c11.exec(<inline>) at
org.eclipse.birt.core.script.ScriptContext.eval(ScriptContex t.java:224)
.... 65 more
Content-Type: text/xml;
name="customers.rptdesign"
Content-Disposition: inline;
filename="customers.rptdesign"
<!-- Written by Eclipse BIRT 2.0 -->
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.6" id="1">
<property name="createdBy">Eclipse BIRT Designer Version 2.1.1.v20060922-1058 Build &lt;20060926-0959></property>
<property name="units">in</property>
<property name="comments">Copyright (c) 2006 &lt;&lt;Your Company Name here>></property>
<method name="afterFactory"><![CDATA[importPackage( Packages.javax.swing );
frame = new JFrame( "Count of Minis = " + countOfMinis );
frame.setBounds( 310, 220, 300, 20 );
frame.show( );]]></method>
<data-sources>
<oda-data-source extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source" id="4">
<property name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver </property>
<property name="odaURL">jdbc:classicmodels:sampledb</property>
<property name="odaUser">ClassicModels</property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet " name="customers" id="5">
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">CUSTOMERNAME</property>
<property name="dataType">string</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">CONTACTLASTNAME</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">CONTACTFIRSTNAME</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">PHONE</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<structure>
<property name="nativeName">CUSTOMERNAME</property>
<property name="nativeDataType">12</property>
</structure>
<structure>
<property name="nativeName">CONTACTLASTNAME</property>
</structure>
<structure>
<property name="nativeName">CONTACTFIRSTNAME</property>
</structure>
<structure>
<property name="nativeName">PHONE</property>
</structure>
</list-property>
<property name="queryText">select customerName,
contactLastName,
contactFirstName,
phone
from Customers </property>
<xml-property name="designerValues"><![CDATA[<?xml version="1.0" encoding="UTF-8"?>
<model:DesignValues xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design" xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>1.0</Version>
<design:ResultSets derivedMetaData="true">
<design:resultSetDefinitions>
<design:resultSetColumns>
<design:resultColumnDefinitions>
<design:attributes>
<design:name>CUSTOMERNAME</design:name>
<design:position>1</design:position>
<design:nativeDataTypeCode>12</design:nativeDataTypeCode>
<design:precision>50</design:precision>
<design:scale>0</design:scale>
<design:nullability>Nullable</design:nullability>
</design:attributes>
<design:usageHints>
<design:label>CUSTOMERNAME</design:label>
<design:formattingHints>
<design:displaySize>50</design:displaySize>
</design:formattingHints>
</design:usageHints>
</design:resultColumnDefinitions>
<design:attributes>
<design:name>CONTACTLASTNAME</design:name>
<design:position>2</design:position>
<design:usageHints>
<design:label>CONTACTLASTNAME</design:label>
<design:attributes>
<design:name>CONTACTFIRSTNAME</design:name>
<design:position>3</design:position>
<design:usageHints>
<design:label>CONTACTFIRSTNAME</design:label>
<design:attributes>
<design:name>PHONE</design:name>
<design:position>4</design:position>
<design:usageHints>
<design:label>PHONE</design:label>
</design:resultSetColumns>
</design:resultSetDefinitions>
<design:attributes>
<design:attributes>
<design:attributes>
<design:attributes>
</design:ResultSets>
</model:DesignValues>]]></xml-property>
</oda-data-set>
</data-sets>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<text id="29">
<text-property name="content"><![CDATA[<CENTER><B><span style="font-size: larger">
Customer List
</B></span><BR>
<FONT size="small">For internal use only</FONT><BR><BR>
Report generated on <VALUE-OF>new Date( )</VALUE-OF>
</CENTER><BR><BR>
]]></text-property>
</text>
<table id="6">
<property name="width">100%</property>
<property name="dataSet">customers</property>
<list-property name="boundDataColumns">
<structure>
<expression name="expression">dataSetRow["CUSTOMERNAME"]</expression >
</structure>
<structure>
<expression name="expression">dataSetRow["PHONE"]</expression>
</structure>
<structure>
<expression name="expression">dataSetRow["CONTACTFIRSTNAME"]+" "+row["CONTACTLASTNAME"]</expression>
</structure>
<structure>
<expression name="expression">dataSetRow["CONTACTLASTNAME"]</expression >
</structure>
</list-property>
<method name="onCreate"><![CDATA[countOfMinis = 0;]]></method>
<list-property name="sort">
<structure>
<expression name="key">row["CUSTOMERNAME"].toUpperCase()</expression >
<property name="direction">asc</property>
</structure>
</list-property>
<column id="19"/>
<column id="20"/>
<column id="21"/>
<header>
<row id="7">
<cell id="8">
<label id="22">
<text-property name="text">Customer</text-property>
</label>
</cell>
<cell id="9">
<label id="24">
<text-property name="text">Phone</text-property>
</label>
</cell>
<cell id="10">
<label id="26">
<text-property name="text">Contact</text-property>
</label>
</cell>
</row>
</header>
<detail>
<row id="11">
<cell id="12">
<data id="23">
<property name="paddingTop">12pt</property>
<method name="onCreate"><![CDATA[row=this.getRowData();
//CustName = row.getColumnValue("row[CUSTOMERNAME]");
//CustName=row.getExpressionValue("row["CUSTOMERNAME"]");
countOfMinis += 1;]]></method>
<property name="resultSetColumn">CUSTOMERNAME</property>
</data>
</cell>
<cell id="13">
<data id="25">
<property name="resultSetColumn">PHONE</property>
</data>
</cell>
<cell id="14">
<data id="27">
<property name="resultSetColumn">CONTACTFIRSTNAME</property>
</data>
</cell>
</row>
</detail>
<footer>
<row id="15">
<cell id="16"/>
<cell id="17"/>
<cell id="18"/>
</row>
</footer>
</table>
</body>
</report>
--------------050507090807010508070107--
Re: Tutorial 5, Field Guide to BIRT, problem running the "Writing an event handler in JavaScrip [message #198097 is a reply to message #197914] Fri, 27 October 2006 18:50 Go to previous messageGo to next message
Thanks for your detailed comments. The online help, including the tutorials,
is based on release 2.1.0 of BIRT. There have been some changes between
2.1.0 and 2.1.1, which may be causing some of the problems that you're
experiencing. I'll look at these issues and let you know the outcome as soon
as I can. I'm not personally familiar with Tutorial 5, but I'll pass your
comments onto my colleague who wrote the tutorial. Unfortunately, he is
taking some vacation right now, but he'll be back in the office next
Thursday.
Jane Tatchell
BIRT documentation lead
"Susan Cline" <home4slc@pacbell.net> wrote in message
news:ehre4j$fjv$1@utils.eclipse.org...
> help with this.
> incorrect?)
> (<inline>#4) at
> at
> first cell appears.
> Susan
> Listing 2
> Data (id = 23):
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source) at
> Source) at
> Source) at
> Source) at
> Source) at
> Source) at
> Source) at
> Source) at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> (<inline>#4) at
> at
> at
> ... 65 more
> Listing 1
> Alpha Cognac
> Data (id = 23):
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source) at
> Source) at
> Source) at
> Source) at
> Source) at
> Source) at
> Source) at
> Source) at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 65 more
> id="1">
> here>></property>
> <data-sources>
> <oda-data-source
> id="4">
> <property
> </oda-data-source>
> </data-sources>
> <data-sets>
> <oda-data-set
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> contactLastName,
> contactFirstName,
> phone
> <model:DesignValues
> <design:attributes>
> <design:usageHints>
> <design:attributes>
> <design:usageHints>
> <design:attributes>
> <design:usageHints>
> <design:attributes>
> <design:usageHints>
> <design:attributes>
> <design:attributes>
> <design:attributes>
> <design:attributes>
> </oda-data-set>
> </data-sets>
> <page-setup>
> <page-footer>
> <text id="3">
> </text>
> </page-footer>
> </page-setup>
> <body>
> <text id="29">
> Customer List
> </B></span><BR>
> </CENTER><BR><BR>
> ]]></text-property>
> </text>
> <table id="6">
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> </list-property>
> <structure>
> <expression
> </structure>
> </list-property>
> <column id="19"/>
> <column id="20"/>
> <column id="21"/>
> <header>
> <row id="7">
> <cell id="8">
> <label id="22">
> <text-property
> </label>
> </cell>
> <cell id="9">
> <label id="24">
> <text-property
> </label>
> </cell>
> <cell id="10">
> <label id="26">
> <text-property
> </label>
> </cell>
> </row>
> </header>
> <detail>
> <row id="11">
> <cell id="12">
> <data id="23">
> <method
> <property
> </data>
> </cell>
> <cell id="13">
> <data id="25">
> <property
> </data>
> </cell>
> <cell id="14">
> <data id="27">
> <property
> </data>
> </cell>
> </row>
> </detail>
> <footer>
> <row id="15">
> <cell id="16"/>
> <cell id="17"/>
> <cell id="18"/>
> </row>
> </footer>
> </table>
> </body>
> </report>
Re: Tutorial 5, Field Guide to BIRT, problem running the "Writing an event handler in JavaScrip [message #198115 is a reply to message #198097] Fri, 27 October 2006 19:55 Go to previous messageGo to next message
Thanks Jane.
In the meantime I'll see if I can figure out the correct usage and post
a corrected example.
Susan
> Thursday.
Re: Tutorial 5, Field Guide to BIRT, problem running the "Writing an event handler in JavaScrip [message #198379 is a reply to message #198097] Mon, 30 October 2006 17:19 Go to previous messageGo to next message
I played with this example some more and I'm thinking there might be a
bug with the way the word "row" is parsed.
For Task 3 of Tutorial 5 here is the script that is supposed to be typed
into the onCreate method of the Script tab for the detailed row
CUSTOMERNAME.
CustName = row.getExpressionValue("row[CUSTOMERNAME]");
if (CustName.indexOf("Mini") != -1)
countOfMinis +=1;
As I mentioned in my previous email, running this script causes this
partial listing of the stack trace:
(This is the primary source: org.mozilla.javascript.EcmaError:
TypeError: Cannot call method "indexOf" of null (<inline>#3) at
..... lots of stuff cut out.....
at java.lang.Thread.run(Thread.java:534)Caused by:
at org.mozilla.javascript.gen.c183._c0(<inline>:3) at
org.mozilla.javascript.gen.c183.call(<inline>) at
at org.mozilla.javascript.gen.c183.call(<inline>) at
org.mozilla.javascript.gen.c183.exec(<inline>) at
.... 65 more
However, if you change the example to use this for the onCreate method:
myrow=this.getRowData();
CustName = myrow.getExpressionValue("row[CUSTOMERNAME]");
countOfMinis +=1;
The example executes correctly. Also, I tried this for the script;
CustName = this.getRowData().getExpressionValue("row[CUSTOMERNAME]");
countOfMinis +=1;
and it works fine as well.
So it appears like there might be some kind of parsing problem on the
word "row" in the first example. It looks like the word "row" in the
getExpressionValue method is being confused with the JavaScript
variable, row.
I'll enter a bugzilla bug for this. Also, I would be happy to help
correct this tutorial example. Other than providing a correct example
(until the bug is fixed, if it is a bug), is there another methodology
for providing information to correct documentation examples? For
instance, should I log a bugzilla for documentation issues as well?
I believe I found an error in another document on the web site that I
would like to report and provide a corrected example for as well.
Susan
> Thursday.
Re: Tutorial 5, Field Guide to BIRT, problem running the "Writing an event handler in JavaScrip [message #199041 is a reply to message #198379] Fri, 03 November 2006 15:03 Go to previous messageGo to next message
You are correct that there is a problem with the variable name, "row". It
appears that "row" is now a prohibited variable name.
There is another problem with the tutorial, however. It is no longer
possible to access a variable within one handler if that varialbe was
created in different event handler. Well, there is a way, but the tutorial
tries to use the old method. The variable "countOfMinis" must be a
serializable Java object and the methods that save and retrieve the
serializable object are reportContext.setPersistentGlobalVariable( ) and
reportContext.getPersistentGlobalVariable( ). The correct code for the three
event handlers is:
Table.onCreate:
countOfMinis = new Packages.java.lang.Integer("1");
reportContext.setPersistentGlobalVariable("cmKey", countOfMinis);
Row.onCreate:
countOfMinis = reportContext.getPersistentGlobalVariable("cmKey");
row_Data = this.getRowData();
CustName = row_Data.getExpressionValue( "row[CUSTOMERNAME]" );
if(CustName.indexOf("Mini") != -1){
mCount = countOfMinis.intValue();
mCount += 1;
countOfMinis = new Packages.java.lang.Integer(mCount);
ReportDesign.afterFactory:
countOfMinis =
reportContext.getPersistentGlobalVariable("cmKey").intValue();
frame.show( );
(Thanks to Jason Weathersby for helping me debug this.)
news:ei5toa$l2m$1@utils.eclipse.org...
> I played with this example some more and I'm thinking there might be a bug
> CUSTOMERNAME.
> countOfMinis +=1;
> (This is the primary source: org.mozilla.javascript.EcmaError: TypeError:
> at
> at
> at
> at
> org.mozilla.javascript.EcmaError: TypeError: Cannot call method "indexOf"
> at
> at org.mozilla.javascript.ScriptRuntime.typeError(ScriptRuntime .java:3246)
> at
> at
> at
> at org.mozilla.javascript.ScriptRuntime.doTopCall(ScriptRuntime .java:2769)
> org.eclipse.birt.core.script.ScriptContext.eval(ScriptContex t.java:224) at
> ... 65 more
> countOfMinis +=1;
> countOfMinis +=1;
> So it appears like there might be some kind of parsing problem on the word
> getExpressionValue method is being confused with the JavaScript variable,
> row.
> (until the bug is fixed, if it is a bug), is there another methodology for
> providing information to correct documentation examples? For instance,
> Susan
>> tutorials, is based on release 2.1.0 of BIRT. There have been some
>> changes between 2.1.0 and 2.1.1, which may be causing some of the
>> problems that you're experiencing. I'll look at these issues and let you
>> know the outcome as soon as I can. I'm not personally familiar with
>> Tutorial 5, but I'll pass your comments onto my colleague who wrote the
>> tutorial. Unfortunately, he is taking some vacation right now, but he'll
>> be back in the office next Thursday.
Re: Tutorial 5, Field Guide to BIRT, problem running the "Writing an event handler in JavaScrip [message #199126 is a reply to message #199041] Fri, 03 November 2006 18:42 Go to previous messageGo to next message
Hi Don,
Thanks for your help with this. I logged a bug for the problem when
using the word "row" in the JavaScript titled "Report Engine error
parsing word "row" in evaluating JavaScript", bugzilla 162817.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=162817
This was changed to a doc bug so the tutorial example could be
corrected. However, I made a comment to this bug that I thought that
BIRT should somehow throw a better error message when the word "row" is
encountered in a script and used as a variable.
So I'm not sure if I should log a new bugzilla for the tutorial
correction or the existing bugzilla # should be used. No one has
commented on the bug yet, so I'm not sure what is going on with it.
Susan
> event handlers is:
> Table.onCreate:
> Row.onCreate:
> mCount += 1;
> countOfMinis =
> frame.show( );
>>Hi,
>>CUSTOMERNAME.
>>countOfMinis +=1;
>>at
>>at
>>at
>>at
>>at
>>at
>>at
>>at
>>... 65 more
>>countOfMinis +=1;
>>countOfMinis +=1;
>>row.
>>Regards,
>>Susan
Re: Tutorial 5, Field Guide to BIRT, problem running the "Writing an event handler in JavaScrip [message #199810 is a reply to message #199041] Wed, 08 November 2006 05:24 Go to previous messageGo to next message
Hi Don,
you say:
"It is no longer
possible to access a variable within one handler if that variable was
created in different event handler."
In which version of BIRT this is true?
I'm using 2.1.1 and still works
Thanks Maria Baldassarri
Re: Tutorial 5, Field Guide to BIRT, problem running the "Writing an event handler in JavaScrip [message #201257 is a reply to message #199126] Thu, 16 November 2006 11:29 Go to previous messageGo to next message
Bug 162817 has been changed to a Report Designer bug. Should I log a
bugzilla for the tutorial?
Susan
Susan Cline wrote:
> Hi Don,
> Susan
>> "row". It appears that "row" is now a prohibited variable name.
>> tutorial tries to use the old method. The variable "countOfMinis" must
>> be a serializable Java object and the methods that save and retrieve
>> the serializable object are reportContext.setPersistentGlobalVariable(
>> ) and reportContext.getPersistentGlobalVariable( ). The correct code
>> for the three event handlers is:
>> Table.onCreate:
>> Row.onCreate:
>> mCount += 1;
>> countOfMinis =
>> frame.show( );
>>> Hi,
>>> a bug with the way the word "row" is parsed.
>>> typed into the onCreate method of the Script tab for the detailed row
>>> CUSTOMERNAME.
>>> countOfMinis +=1;
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 65 more
>>> countOfMinis +=1;
>>> countOfMinis +=1;
>>> variable, row.
>>> example (until the bug is fixed, if it is a bug), is there another
>>> methodology for providing information to correct documentation
>>> examples? For instance, should I log a bugzilla for documentation
>>> issues as well?
>>> Regards,
>>> Susan
>>>> you know the outcome as soon as I can. I'm not personally familiar
>>>> with Tutorial 5, but I'll pass your comments onto my colleague who
>>>> wrote the tutorial. Unfortunately, he is taking some vacation right
>>>> now, but he'll be back in the office next Thursday.
Re: Tutorial 5, Field Guide to BIRT, problem running the "Writing an event handler in JavaScrip [message #203177 is a reply to message #201257] Mon, 27 November 2006 18:04 Go to previous message
I logged a bugzilla for the tutorial itself since the example has not
been corrected as of 2.2.0 M1.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=165982
Susan
> Susan
> Susan Cline wrote:
>> Hi Don,
>> is encountered in a script and used as a variable.
>> Thanks,
>> Susan
>>> must be a serializable Java object and the methods that save and
>>> retrieve the serializable object are
>>> Table.onCreate:
>>> Row.onCreate:
>>> mCount += 1;
>>> countOfMinis =
>>> frame.show( );
>>>> Hi,
>>>> row CUSTOMERNAME.
>>>> countOfMinis +=1;
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> ... 65 more
>>>> countOfMinis +=1;
>>>> countOfMinis +=1;
>>>> the word "row" in the first example. It looks like the word "row"
>>>> in the getExpressionValue method is being confused with the
>>>> JavaScript variable, row.
>>>> issues as well?
>>>> I would like to report and provide a corrected example for as well.
>>>> Regards,
>>>> Susan
>>>>> let you know the outcome as soon as I can. I'm not personally
>>>>> familiar with Tutorial 5, but I'll pass your comments onto my
>>>>> colleague who wrote the tutorial. Unfortunately, he is taking some
>>>>> vacation right now, but he'll be back in the office next Thursday.
Previous Topic:java.lang.NoSuchMethodError: initStandardObjects
Next Topic:timestamp vs date???
Current Time: Sat Aug 30 02:22:49 EDT 2025
Powered by FUDForum. Page generated in 0.03843 seconds
