Home » Eclipse Projects » Eclipse Platform » problems starting eclipse with commandline
problems starting eclipse with commandline [message #197869] Thu, 19 February 2004 11:56 Go to next message
I have been struggling to start my own application from the DOS command
line with eclipse, but I keep on getting "Unable to locate application
extension".
This is how my plugin.xml looks like:
<?eclipse version="3.0"?>
<plugin
id="de.lilith.authentification"
name="Authentification Plug-in"
version="1.0.0"
provider-name="lilith.de"
class="de.lilith.authentification.AuthentificationPlugin">
<runtime>
<library name="authentification.jar">
<export name="*"/>
</library>
</runtime>
<requires>
<import plugin="org.eclipse.ui"/>
<import plugin="org.eclipse.core.resources"/>
<import plugin="org.eclipse.core.runtime.compatibility"/>
</requires>
<extension
id="LoginApplication"
point="org.eclipse.core.runtime.applications">
<application>
<run
class="de.lilith.authentification.LoginShell">
</run>
</application>
</extension>
</plugin>
the plugin is also exported in the plugin directory. My path hierarchy is
eclipse\workspace\de.lilith.authentification
Can someone please tell me how the command should look like in order to
get the application start with eclipse.
thanks & cheers,
Lilith
Re: problems starting eclipse with commandline [message #197945 is a reply to message #197869] Thu, 19 February 2004 13:58 Go to previous messageGo to next message
Originally posted by: richkulp.NO.SPAM.us.ibm.com
What does your command line look like?
Thanks, Rich Kulp
Re: problems starting eclipse with commandline [message #198101 is a reply to message #197869] Thu, 19 February 2004 19:05 Go to previous message
Originally posted by: pascal_rapicault.yahoo.fr
Your command line should be something like:
eclipse.exe -application de.lilith.authentification.LoginApplication
PaScaL
"lilith" <aljadiri@in.tum.de> a
Previous Topic:File Explorer
Next Topic:get selected project?
Current Time: Fri May 09 19:10:42 EDT 2025
Powered by FUDForum. Page generated in 0.03853 seconds
