Home » Newcomers » Newcomers » After reinstalling because of problems with plugins, eclipse doesn't start anymore
After reinstalling because of problems with plugins, eclipse doesn't start anymore [message #197850] Mon, 05 March 2007 12:29
Originally posted by: l.s.rockfan.web.de
maybe someone can help me.
After having some problems with eclipse, when i was experimenting with
various uml-plugins last week, eclipse couldn't be switched from c(++)
to java perspective anymore. So i descided to uninstall eclipse
completely and then reinstall the sdk again. To do so, i used yum, like
always. I'm working under fc6.
Now I run into the problem that after installing eclipse doesn't start.
log-file:
!SESSION 2007-03-05 17:03:24.358
eclipse.buildId=M20070212-1330
java.fullversion=GNU libgcj 4.1.1 20070105 (Red Hat 4.1.1-51)
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=de_DE
Command-line arguments: -os linux -ws gtk -arch x86
!ENTRY org.eclipse.update.configurator 2007-03-05 17:03:29.099
!MESSAGE Could not install bundle plugins/org.eclipse.pde.build/
Bundle "org.eclipse.pde.build" version "3.2.1.r321_v20060823" has
already been installed from:
update@plugins/org.eclipse.pde.build_3.2.1.r321_v20060823/
!ENTRY org.eclipse.core.runtime 2007-03-05 17:03:30.996
!MESSAGE Product org.eclipse.sdk.ide could not be found.
!ENTRY org.eclipse.osgi 4 0 2007-03-05 17:03:31.019
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: No application id has been found.
org.eclipse.core.internal.runtime.PlatformActivator$1.run(or g.eclipse.core.runtime_3.2.0.v20060603.jar.so)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(org.eclipse.osgi_3.2.2.R32x_v20070118.jar.so )
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(org.eclipse.osgi_3.2.2.R32x_v20070118.jar.so)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(org.ecli pse.osgi_3.2.2.R32x_v20070118.jar.so)
at java.lang.reflect.Method.invoke(libgcj.so.7rh)
at org.eclipse.core.launcher.Main.invokeFramework(startup.jar.s o)
at org.eclipse.core.launcher.Main.basicRun(startup.jar.so)
at org.eclipse.core.launcher.Main.run(startup.jar.so)
at org.eclipse.core.launcher.Main.main(startup.jar.so)
!ENTRY org.eclipse.osgi 2 0 2007-03-05 17:03:31.199
!MESSAGE One or more bundles are not resolved because the following root
constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2007-03-05 17:03:31.200
!MESSAGE Bundle
update@plugins/org.eclipse.jface.text_3.2.2.r322_v20070104.jar was not
resolved.
!SUBENTRY 2 org.eclipse.jface.text 2 0 2007-03-05 17:03:31.200
!MESSAGE Missing required bundle org.eclipse.swt_[3.2.0,4.0.0).
!MESSAGE Bundle update@plugins/org.eclipse.ui_3.2.1.M20061108.jar was
not resolved.
!SUBENTRY 2 org.eclipse.ui 2 0 2007-03-05 17:03:31.200
!MESSAGE Bundle
update@plugins/org.eclipse.jface_3.2.2.M20061214-1200.jar was not resolved.
!SUBENTRY 2 org.eclipse.jface 2 0 2007-03-05 17:03:31.200
!MESSAGE Bundle
update@plugins/org.eclipse.ui.workbench_3.2.2.M20070119-0800.jar was not
resolved.
!SUBENTRY 2 org.eclipse.ui.workbench 2 0 2007-03-05 17:03:31.200
!MESSAGE Bundle
update@plugins/org.eclipse.team.cvs.ssh2_3.2.1.M20061205.jar was not
resolved.
!SUBENTRY 2 org.eclipse.team.cvs.ssh2 2 0 2007-03-05 17:03:31.200
!ENTRY org.eclipse.osgi 2 0 2007-03-05 17:03:31.235
!MESSAGE The following is a complete list of bundles which are not
resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2007-03-05 17:03:31.235
!MESSAGE Bundle
update@plugins/org.eclipse.ui.cheatsheets_3.2.1.R321_v20060720.jar [4]
was not resolved.
!SUBENTRY 2 org.eclipse.ui.cheatsheets 2 0 2007-03-05 17:03:31.235
!MESSAGE Missing required bundle org.eclipse.ui_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.ui.forms_[3.2.0,4.0.0).
!MESSAGE Missing optionally required bundle
org.eclipse.help.ui_[3.2.0,4.0.0).
!MESSAGE Bundle
update@plugins/org.eclipse.ui.views_3.2.1.M20060906-0800.jar [6] was not
resolved.
!SUBENTRY 2 org.eclipse.ui.views 2 0 2007-03-05 17:03:31.235
!MESSAGE Bundle
update@plugins/org.eclipse.ui.browser_3.2.0.v20060602.jar [7] was not
resolved.
!SUBENTRY 2 org.eclipse.ui.browser 2 0 2007-03-05 17:03:31.235
!MESSAGE Bundle
update@plugins/org.eclipse.ui.navigator_3.2.1.M20060913-0800.jar [8] was
not resolved.
!SUBENTRY 2 org.eclipse.ui.navigator 2 0 2007-03-05 17:03:31.235
!MESSAGE Missing required bundle org.eclipse.jface_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.ui.workbench_[3.2.1,4.0.0).
!MESSAGE Missing required bundle org.eclipse.ui_[3.2.1,4.0.0).
!MESSAGE Bundle
update@plugins /org.eclipse.ui.workbench.compatibility_3.2.0.I20060605-1400 /
[13] was not resolved.
!SUBENTRY 2 org.eclipse.ui.workbench.compatibility 2 0 2007-03-05
17:03:31.235
!MESSAGE Missing host org.eclipse.ui.workbench_[3.0.0,4.0.0).
!MESSAGE Bundle update@plugins/org.eclipse.jdt_3.2.1.r321_v20060823.jar
[18] was not resolved.
!SUBENTRY 2 org.eclipse.jdt 2 0 2007-03-05 17:03:31.235
!MESSAGE Missing required bundle org.eclipse.ui.intro_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.ui.cheatsheets_[3.2.0,4.0.0).
!MESSAGE Bundle
update@plugins/org.eclipse.update.ui_3.2.2.R32x_v20070111.jar [21] was
not resolved.
!SUBENTRY 2 org.eclipse.update.ui 2 0 2007-03-05 17:03:31.235
!MESSAGE Bundle update@plugins/org.eclipse.ui_3.2.1.M20061108.jar [26]
was not resolved.
!SUBENTRY 2 org.eclipse.ui 2 0 2007-03-05 17:03:31.235
!MESSAGE Bundle
update@plugins/org.eclipse.ant.ui_3.2.1.r321_v20060828.jar [30] was not
resolved.
!SUBENTRY 2 org.eclipse.ant.ui 2 0 2007-03-05 17:03:31.235
org.eclipse.ui.ide_[3.2.0,4.0.0).
!SUBENTRY 2 org.eclipse.ant.ui 2 0 2007-03-05 17:03:31.236
org.eclipse.ui.views_[3.2.0,4.0.0).
org.eclipse.jface.text_[3.2.0,4.0.0).
org.eclipse.ui.workbench.texteditor_[3.2.0,4.0.0).
org.eclipse.ui.editors_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.ui.externaltools_[3.1.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.ui.console_[3.1.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.debug.ui_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.jdt.ui_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.jdt.debug.ui_[3.2.0,4.0.0).
!SUBENTRY 1 org.eclipse.osgi 2 0 2007-03-05 17:03:31.236
!MESSAGE Bundle
update@plugins/org.eclipse.ui.console_3.1.100.v20060605.jar [31] was not
resolved.
!SUBENTRY 2 org.eclipse.ui.console 2 0 2007-03-05 17:03:31.236
!MESSAGE Missing required bundle org.eclipse.jface.text_[3.2.0,4.0.0).
!MESSAGE Bundle
update@plugins /org.eclipse.ui.workbench.texteditor_3.2.0.v20060605-1400.ja r
[35] was not resolved.
!SUBENTRY 2 org.eclipse.ui.workbench.texteditor 2 0 2007-03-05 17:03:31.236
!MESSAGE Bundle
update@plugins/org.eclipse.ui.externaltools_3.1.101.r321_v20060802.jar
[37] was not resolved.
!SUBENTRY 2 org.eclipse.ui.externaltools 2 0 2007-03-05 17:03:31.236
!MESSAGE Bundle update@plugins/org.eclipse.ui.forms_3.2.0.v20060602.jar
[40] was not resolved.
!SUBENTRY 2 org.eclipse.ui.forms 2 0 2007-03-05 17:03:31.236
!MESSAGE Missing optionally required bundle org.eclipse.ui_[3.2.0,4.0.0).
!MESSAGE Bundle
update@plugins/org.eclipse.ui.intro.universal_3.2.1.R321_v20060905/ [42]
was not resolved.
!SUBENTRY 2 org.eclipse.ui.intro.universal 2 0 2007-03-05 17:03:31.236
!MESSAGE Bundle
update@plugins/org.eclipse.jdt.ui_3.2.2.r322_v20070124.jar [44] was not
resolved.
!SUBENTRY 2 org.eclipse.jdt.ui 2 0 2007-03-05 17:03:31.236
!MESSAGE Missing required bundle org.eclipse.ui.console_[3.1.100,4.0.0).
!MESSAGE Missing required bundle org.eclipse.search_[3.2.0,4.0.0).
!SUBENTRY 2 org.eclipse.jdt.ui 2 0 2007-03-05 17:03:31.237
!MESSAGE Missing required bundle org.eclipse.compare_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.team.ui_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.ui.ide_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.ui.views_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.ui.editors_[3.2.0,4.0.0).
org.eclipse.ltk.ui.refactoring_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.ui.navigator_[3.2.0,4.0.0).
!SUBENTRY 1 org.eclipse.osgi 2 0 2007-03-05 17:03:31.237
!MESSAGE Bundle
update@plugins/org.eclipse.pde.runtime_3.2.0.v20060605.jar [45] was not
resolved.
!SUBENTRY 2 org.eclipse.pde.runtime 2 0 2007-03-05 17:03:31.237
!MESSAGE Bundle
update@plugins/org.eclipse.jdt.debug.ui_3.2.2.r322_v20061205.jar [47]
was not resolved.
!SUBENTRY 2 org.eclipse.jdt.debug.ui 2 0 2007-03-05 17:03:31.237
!MESSAGE Bundle
update@plugins/org.eclipse.ui.presentations.r21_3.2.0.I20060605-1400.jar
[48] was not resolved.
!SUBENTRY 2 org.eclipse.ui.presentations.r21 2 0 2007-03-05 17:03:31.237
!MESSAGE Bundle
update@plugins /org.eclipse.ui.views.properties.tabbed_3.2.1.M20060830-0800 .jar
[49] was not resolved.
!SUBENTRY 2 org.eclipse.ui.views.properties.tabbed 2 0 2007-03-05
17:03:31.237
17:03:31.237
17:03:31.237
!MESSAGE Bundle update@plugins/org.eclipse.help.ui_3.2.0.v20060602.jar
[52] was not resolved.
!SUBENTRY 2 org.eclipse.help.ui 2 0 2007-03-05 17:03:31.237
!MESSAGE Bundle
update@plugins/org.eclipse.ui.editors_3.2.1.r321_v20060721.jar [53] was
not resolved.
!SUBENTRY 2 org.eclipse.ui.editors 2 0 2007-03-05 17:03:31.237
!MESSAGE Bundle
update@plugins/org.eclipse.jdt.junit_3.2.1.r321_v20060810/ [58] was not
resolved.
!SUBENTRY 2 org.eclipse.jdt.junit 2 0 2007-03-05 17:03:31.237
!SUBENTRY 2 org.eclipse.jdt.junit 2 0 2007-03-05 17:03:31.238
!SUBENTRY 1 org.eclipse.osgi 2 0 2007-03-05 17:03:31.238
!MESSAGE Bundle
update@plugins/org.eclipse.pde.ui_3.2.1.v20060816-0800.jar [59] was not
resolved.
!SUBENTRY 2 org.eclipse.pde.ui 2 0 2007-03-05 17:03:31.238
!MESSAGE Missing required bundle org.eclipse.search_[3.1.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.ant.ui_[3.1.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.jdt.junit_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.pde.runtime_[3.2.0,4.0.0).
!MESSAGE Bundle
update@plugins/org.eclipse.team.cvs.ssh2_3.2.1.M20061205.jar [60] was
not resolved.
!SUBENTRY 2 org.eclipse.team.cvs.ssh2 2 0 2007-03-05 17:03:31.238
!MESSAGE Bundle
update@plugins/org.eclipse.update.scheduler_3.2.2.R32x_v20061214.jar
[64] was not resolved.
!SUBENTRY 2 org.eclipse.update.scheduler 2 0 2007-03-05 17:03:31.238
!MESSAGE Missing required bundle org.eclipse.update.ui_[3.1.0,4.0.0).
!MESSAGE Bundle
update@plugins/org.eclipse.ui.intro_3.2.2.R322_v20061214.jar [65] was
not resolved.
!SUBENTRY 2 org.eclipse.ui.intro 2 0 2007-03-05 17:03:31.238
!MESSAGE Bundle
update@plugins/org.eclipse.jface_3.2.2.M20061214-1200.jar [68] was not
resolved.
!SUBENTRY 2 org.eclipse.jface 2 0 2007-03-05 17:03:31.238
!MESSAGE Bundle
update@plugins/org.eclipse.ltk.ui.refactoring_3.2.2.r322_v20070124.jar
[69] was not resolved.
!SUBENTRY 2 org.eclipse.ltk.ui.refactoring 2 0 2007-03-05 17:03:31.239
!SUBENTRY 1 org.eclipse.osgi 2 0 2007-03-05 17:03:31.239
!MESSAGE Bundle
update@plugins/org.eclipse.jface.databinding_1.0.0.I20060605-1400.jar
[70] was not resolved.
!SUBENTRY 2 org.eclipse.jface.databinding 2 0 2007-03-05 17:03:31.239
!MESSAGE Missing required bundle org.eclipse.jface_[3.1.0,4.0.0).
!MESSAGE Bundle
update@plugins/org.eclipse.team.cvs.ui_3.2.2.M20061121.jar [73] was not
resolved.
!SUBENTRY 2 org.eclipse.team.cvs.ui 2 0 2007-03-05 17:03:31.239
org.eclipse.ui.navigator.resources_[3.2.0,4.0.0).
!MESSAGE Bundle update@plugins/org.eclipse.compare_3.2.1.M20060711.jar
[77] was not resolved.
!SUBENTRY 2 org.eclipse.compare 2 0 2007-03-05 17:03:31.239
!MESSAGE Missing required bundle org.eclipse.ui_[3.1.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.jface.text_[3.1.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.ui.ide_[3.1.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.ui.views_[3.1.0,4.0.0).
org.eclipse.ui.workbench.texteditor_[3.1.0,4.0.0).
!MESSAGE Bundle
update@plugins/org.eclipse.search_3.2.1.r321_v20060726.jar [78] was not
resolved.
!SUBENTRY 2 org.eclipse.search 2 0 2007-03-05 17:03:31.239
!MESSAGE Bundle
update@plugins/org.eclipse.ui.ide_3.2.1.M20060915-1030.jar [80] was not
resolved.
!SUBENTRY 2 org.eclipse.ui.ide 2 0 2007-03-05 17:03:31.239
!MESSAGE Missing required bundle org.eclipse.update.ui_[3.1.100,4.0.0).
!MESSAGE Bundle
update@plugins/org.eclipse.ui.workbench_3.2.2.M20070119-0800.jar [82]
was not resolved.
!SUBENTRY 2 org.eclipse.ui.workbench 2 0 2007-03-05 17:03:31.239
!MESSAGE Bundle
update@plugins /org.eclipse.ui.navigator.resources_3.2.1.M20060906-0800b.ja r
[84] was not resolved.
!SUBENTRY 2 org.eclipse.ui.navigator.resources 2 0 2007-03-05 17:03:31.239
!SUBENTRY 2 org.eclipse.ui.navigator.resources 2 0 2007-03-05 17:03:31.240
!MESSAGE Missing required bundle org.eclipse.ui.navigator_[3.2.1,4.0.0).
org.eclipse.ui.views.properties.tabbed_[3.2.0,4.0.0).
!SUBENTRY 1 org.eclipse.osgi 2 0 2007-03-05 17:03:31.240
!MESSAGE Bundle
update@plugins/org.eclipse.platform_3.2.2.r322_v20070117b/ [86] was not
resolved.
!SUBENTRY 2 org.eclipse.platform 2 0 2007-03-05 17:03:31.240
org.eclipse.ui.intro.universal_[3.2.0,4.0.0).
!MESSAGE Bundle
update@plugins/org.eclipse.team.ui_3.2.1.M200608151725.jar [87] was not
resolved.
!SUBENTRY 2 org.eclipse.team.ui 2 0 2007-03-05 17:03:31.240
!MESSAGE Bundle
update@plugins/org.eclipse.debug.ui_3.2.2.r322_v20070202.jar [92] was
not resolved.
!SUBENTRY 2 org.eclipse.debug.ui 2 0 2007-03-05 17:03:31.240
!MESSAGE Bundle
update@plugins/org.eclipse.jface.text_3.2.2.r322_v20070104.jar [96] was
not resolved.
!SUBENTRY 2 org.eclipse.jface.text 2 0 2007-03-05 17:03:31.240
!MESSAGE Bundle
update@.. /../lib/eclipse/plugins/org.eclipse.platform.doc.isv_3.2.2.R 32x_v20070115.jar
[99] was not resolved.
!SUBENTRY 2 org.eclipse.platform.doc.isv 2 0 2007-03-05 17:03:31.240
!MESSAGE Bundle
update@.. /../lib/eclipse/plugins/org.eclipse.sdk_3.2.2.r322_v20070212 /
[104] was not resolved.
!SUBENTRY 2 org.eclipse.sdk 2 0 2007-03-05 17:03:31.241
!MESSAGE Missing required bundle org.eclipse.help.ui_[3.2.0,4.0.0).
!SESSION 2007-03-05 17:29:32.713
Command-line arguments: -os linux -ws gtk -arch x86 -clean
!ENTRY org.eclipse.update.configurator 2007-03-05 17:29:34.131
!ENTRY org.eclipse.core.runtime 2007-03-05 17:29:34.828
!ENTRY org.eclipse.osgi 4 0 2007-03-05 17:29:34.834
!STACK 1
!ENTRY org.eclipse.osgi 2 0 2007-03-05 17:29:35.058
!SUBENTRY 1 org.eclipse.osgi 2 0 2007-03-05 17:29:35.058
!MESSAGE Bundle
!SUBENTRY 2 org.eclipse.jface 2 0 2007-03-05 17:29:35.058
not resolved.
!SUBENTRY 2 org.eclipse.ui 2 0 2007-03-05 17:29:35.058
!MESSAGE Bundle
resolved.
!SUBENTRY 2 org.eclipse.jface.text 2 0 2007-03-05 17:29:35.058
!MESSAGE Bundle
resolved.
!SUBENTRY 2 org.eclipse.team.cvs.ssh2 2 0 2007-03-05 17:29:35.058
!MESSAGE Bundle
resolved.
!SUBENTRY 2 org.eclipse.ui.workbench 2 0 2007-03-05 17:29:35.058
!ENTRY org.eclipse.osgi 2 0 2007-03-05 17:29:35.086
!SUBENTRY 1 org.eclipse.osgi 2 0 2007-03-05 17:29:35.086
!MESSAGE Bundle
was not resolved.
!SUBENTRY 2 org.eclipse.ui.cheatsheets 2 0 2007-03-05 17:29:35.086
!MESSAGE Bundle
resolved.
!SUBENTRY 2 org.eclipse.ui.views 2 0 2007-03-05 17:29:35.086
!SUBENTRY 1 org.eclipse.osgi 2 0 2007-03-05 17:29:35.087
!MESSAGE Bundle
resolved.
!SUBENTRY 2 org.eclipse.ui.browser 2 0 2007-03-05 17:29:35.087
!MESSAGE Bundle
not resolved.
!SUBENTRY 2 org.eclipse.ui.navigator 2 0 2007-03-05 17:29:35.087
!MESSAGE Bundle
17:29:35.087
!SUBENTRY 2 org.eclipse.jdt 2 0 2007-03-05 17:29:35.087
!MESSAGE Bundle
not resolved.
!SUBENTRY 2 org.eclipse.update.ui 2 0 2007-03-05 17:29:35.087
was not resolved.
!SUBENTRY 2 org.eclipse.ui 2 0 2007-03-05 17:29:35.087
!MESSAGE Bundle
resolved.
!SUBENTRY 2 org.eclipse.ant.ui 2 0 2007-03-05 17:29:35.087
!MESSAGE Bundle
resolved.
!SUBENTRY 2 org.eclipse.ui.console 2 0 2007-03-05 17:29:35.087
!MESSAGE Bundle
!SUBENTRY 2 org.eclipse.ui.workbench.texteditor 2 0 2007-03-05 17:29:35.087
!MESSAGE Bundle
!SUBENTRY 2 org.eclipse.ui.externaltools 2 0 2007-03-05 17:29:35.087
!SUBENTRY 2 org.eclipse.ui.forms 2 0 2007-03-05 17:29:35.087
!MESSAGE Bundle
was not resolved.
!SUBENTRY 2 org.eclipse.ui.intro.universal 2 0 2007-03-05 17:29:35.088
!SUBENTRY 1 org.eclipse.osgi 2 0 2007-03-05 17:29:35.088
!MESSAGE Bundle
resolved.
!SUBENTRY 2 org.eclipse.jdt.ui 2 0 2007-03-05 17:29:35.088
!MESSAGE Bundle
resolved.
!SUBENTRY 2 org.eclipse.pde.runtime 2 0 2007-03-05 17:29:35.088
!MESSAGE Bundle
was not resolved.
!SUBENTRY 2 org.eclipse.jdt.debug.ui 2 0 2007-03-05 17:29:35.088
!SUBENTRY 2 org.eclipse.jdt.debug.ui 2 0 2007-03-05 17:29:35.089
!SUBENTRY 1 org.eclipse.osgi 2 0 2007-03-05 17:29:35.089
!MESSAGE Bundle
!SUBENTRY 2 org.eclipse.ui.presentations.r21 2 0 2007-03-05 17:29:35.089
!MESSAGE Bundle
17:29:35.089
17:29:35.089
17:29:35.089
!SUBENTRY 2 org.eclipse.help.ui 2 0 2007-03-05 17:29:35.089
!MESSAGE Bundle
not resolved.
!SUBENTRY 2 org.eclipse.ui.editors 2 0 2007-03-05 17:29:35.089
!MESSAGE Bundle
resolved.
!SUBENTRY 2 org.eclipse.jdt.junit 2 0 2007-03-05 17:29:35.089
!MESSAGE Bundle
resolved.
!SUBENTRY 2 org.eclipse.pde.ui 2 0 2007-03-05 17:29:35.089
!SUBENTRY 2 org.eclipse.pde.ui 2 0 2007-03-05 17:29:35.090
!SUBENTRY 1 org.eclipse.osgi 2 0 2007-03-05 17:29:35.090
!MESSAGE Bundle
not resolved.
!SUBENTRY 2 org.eclipse.team.cvs.ssh2 2 0 2007-03-05 17:29:35.090
Previous Topic:New to eclipse, need help with atf-windows-0.2.1
Next Topic:ColdFusion Stalling with Eclispe
Current Time: Sat Aug 30 02:22:51 EDT 2025
Powered by FUDForum. Page generated in 0.12494 seconds
