Home » Language IDEs » ServerTools (WTP) » Best practices for "sharing" libs?
Best practices for "sharing" libs? [message #197848] Fri, 03 August 2007 10:43 Go to next message
Originally posted by: dserodio.gmail.com
My Web projects depend on lots of 3rd party libs like Hibernate, Spring,
etc.
When I did simple Java (non-Web) projects, I used to define User
Libraries for each lib, so that each team member could setup the User
Library on his machine, and have integrated Javadoc and source code for
the libs.
This approach doesn't work with Web apps. How could I have this same
effect with Web apps?
TIA,
Daniel Serodio
Re: Best practices for "sharing" libs? [message #197875 is a reply to message #197848] Fri, 03 August 2007 11:52 Go to previous messageGo to next message
hi Daniel,
Can you clarify how this approach is failing to work with web apps? (i.e. do
you need to have the JARs exposed by your User Library bundled into
WEB-INF/lib in the published/exported web app? if so, this is now possible
with WTP 2.0)
-Rob
"Daniel Serodio" <dserodio@gmail.com> wrote in message
news:f8veub$bug$1@build.eclipse.org...
> etc.
> the libs.
> TIA,
> Daniel Serodio
Re: Best practices for "sharing" libs? [message #198231 is a reply to message #197848] Tue, 14 August 2007 10:57 Go to previous messageGo to next message
Originally posted by: erikvaningen.gmail.com
Hi Daniel,
Have you considered Maven? The Maven plugin on eclipse is working quite
well. We use it and we are quite happy with it.
Ciao,
Erik
> etc.
> the libs.
> TIA,
> Daniel Serodio
Re: Best practices for "sharing" libs? [message #198406 is a reply to message #198231] Wed, 15 August 2007 14:02 Go to previous message
Erik,
Funny you ask about Maven, I'm asking this exactly because I want to
dump Maven :-)
m2eclipse's development is too slow, I don't know why then didn't
release 0.11 yet.
Thanks to your suggestion, I'm going to give Maven/m2eclipse a last chance.
What I want is to be able to see libraries's Javadocs and sources (if
available) from inside Eclipse, did you manage to get this working?
Thanks in advance,
Daniel Serodio
I've never been able to
Erik van Ingen wrote:
> Hi Daniel,
> Ciao,
> Erik
>> etc.
>> the libs.
>> TIA,
>> Daniel Serodio
Previous Topic:? Adding items to JST Server Module Context Menu?
Next Topic:My messages is just ignored
Current Time: Sat Aug 30 02:31:02 EDT 2025
Powered by FUDForum. Page generated in 0.04523 seconds
