Re: [buckminster-dev] Strange resolver behaviour when resolving PDE plugins - using "native&quo [message #18840] |
Tue, 27 May 2008 10:30 |
Originally posted by: ohurley.iona.com
> In my target platform I have two versions of "org.eclipse.emf.common":
> 1) 2.3.0
> 2) 2.3.2
> So, based on this two issues, I think Buckminster ignores my second
> plugin. I guess Buckminster's "eclipse.platform" support only one
> version of plugin, and he takes the first one in lexicographical
> order?
> What can be done to fix this issue? Or I just have to remove old
> plugins from my target platform? :-)
I think I found the same issue when using the javax.wsdl_1.5.1
and javax.wsdl_1.4.0, see
https://bugs.eclipse.org/bugs/show_bug.cgi?id=229930
Unfortunately I need *both* those plugins, so I can't remove
the oldest one. If you can get away with removing one of the
emf.common plugins, I would suggest that as a solution :)
cheers
--oh
IONA Technologies PLC (registered in Ireland)
Registered Number: 171387
Registered Address: The IONA Building, Shelbourne Road, Dublin 4, Ireland
FUDForum. Page generated in 0.05363 seconds
