Home » Eclipse Projects » Plugin Development Environment (PDE) » import existing project into workspace extension point
import existing project into workspace extension point [message #18835] Tue, 02 September 2008 11:22 Go to next message
Originally posted by: oren_b1.verifone.com
I want to write a plugin that perform some operation after the user imports
existing project into the workspace, which extension point should I use?
I have found "org.eclipse.ui.importWizards" but this extension point gives
me the ability to add my own import wizard and I want to change already
existing wizard.
Oren Barzilai
Re: import existing project into workspace extension point [message #18970 is a reply to message #18835] Wed, 03 September 2008 08:33 Go to previous messageGo to next message
Originally posted by: yeronimuz.aol.com
oren barzilai wrote:
> Hello,
> existing wizard.
> Thanks
> Oren Barzilai
I don't know the details, but I think you should create a new fragment instead of a plugin and set
the host plug-in ID to the one that's providing your import wizard. Extend the wizard class and you
should be done.
Jeroen Lankheet
Re: import existing project into workspace extension point [message #18991 is a reply to message #18970] Wed, 03 September 2008 08:55 Go to previous messageGo to next message
What do you mean new fragment? do you have a document that I can read and
learn more about this topic?
Oren
"Jeroen Lankheet" <yeronimuz@aol.com> wrote in message
news:g9m061$j1m$2@build.eclipse.org...
>> Hello,
>> imports existing project into the workspace, which extension point should
>> I use?
>> gives me the ability to add my own import wizard and I want to change
>> already existing wizard.
>> Thanks
>> Oren Barzilai
> instead of a plugin and set the host plug-in ID to the one that's
> providing your import wizard. Extend the wizard class and you should be
> done.
> Jeroen Lankheet
Re: import existing project into workspace extension point [message #19293 is a reply to message #18991] Thu, 04 September 2008 04:00 Go to previous message
Eclipse uses plugins, features and fragments. Features are what you see if you do a Help->Software
Updates->Find and Install. These features may be composed of one or more plugins. Then you have
fragments which may extend plugins.
An explanation of this is found at http://www.ibm.com/developerworks/library/os-ecplug/
See also http://wiki.eclipse.org/Steps_to_use_Fragments_to_patch_a_pl ug-in
> Thanks
> Oren
>>> Hello,
>>> I use?
>>> Thanks
>>> Oren Barzilai
>> done.
>> Regards,
>> Jeroen Lankheet
Re: import existing project into workspace extension point [message #578353 is a reply to message #18835] Wed, 03 September 2008 08:33 Go to previous message
> Hello,
> existing wizard.
> Thanks
> Oren Barzilai
should be done.
Jeroen Lankheet
Re: import existing project into workspace extension point [message #578378 is a reply to message #18970] Wed, 03 September 2008 08:55 Go to previous message
Oren
>> Hello,
>> I use?
>> Thanks
>> Oren Barzilai
> done.
> Jeroen Lankheet
Re: import existing project into workspace extension point [message #578468 is a reply to message #18991] Thu, 04 September 2008 04:00 Go to previous message
> Thanks
> Oren
>>> Hello,
>>> I use?
>>> Thanks
>>> Oren Barzilai
>> done.
>> Regards,
>> Jeroen Lankheet
Previous Topic:Add new prespective : createInitialLayout never gets called.
Next Topic:PDE Builder: Copy eclipsec.exe to root folder
Current Time: Mon Jul 21 21:20:48 EDT 2025
Powered by FUDForum. Page generated in 0.25730 seconds
