import existing project into workspace extension point [message #18835] |
Tue, 02 September 2008 11:22  |
Originally posted by: oren_b1.verifone.com
I want to write a plugin that perform some operation after the user imports
existing project into the workspace, which extension point should I use?
I have found "org.eclipse.ui.importWizards" but this extension point gives
me the ability to add my own import wizard and I want to change already
existing wizard.
Oren Barzilai
Re: import existing project into workspace extension point [message #19293 is a reply to message #18991] |
Thu, 04 September 2008 04:00  |
Originally posted by: yeronimuz.aol.com
Eclipse uses plugins, features and fragments. Features are what you see if you do a Help->Software
Updates->Find and Install. These features may be composed of one or more plugins. Then you have
fragments which may extend plugins.
An explanation of this is found at http://www.ibm.com/developerworks/library/os-ecplug/
See also http://wiki.eclipse.org/Steps_to_use_Fragments_to_patch_a_pl ug-in
oren barzilai wrote:
> What do you mean new fragment? do you have a document that I can read and
> learn more about this topic?
> Thanks
> Oren
> "Jeroen Lankheet" <yeronimuz@aol.com> wrote in message
> news:g9m061$j1m$2@build.eclipse.org...
>>> Hello,
>>> imports existing project into the workspace, which extension point should
>>> I use?
>>> gives me the ability to add my own import wizard and I want to change
>>> already existing wizard.
>>> Thanks
>>> Oren Barzilai
>> I don't know the details, but I think you should create a new fragment
>> instead of a plugin and set the host plug-in ID to the one that's
>> providing your import wizard. Extend the wizard class and you should be
>> done.
>> Regards,
>> Jeroen Lankheet
Re: import existing project into workspace extension point [message #578353 is a reply to message #18835] |
Wed, 03 September 2008 08:33  |
> Hello,
> existing wizard.
> Thanks
> Oren Barzilai
I don't know the details, but I think you should create a new fragment instead of a plugin and set
the host plug-in ID to the one that's providing your import wizard. Extend the wizard class and you
should be done.
Jeroen Lankheet
Re: import existing project into workspace extension point [message #578378 is a reply to message #18970] |
Wed, 03 September 2008 08:55  |
Oren
>> Hello,
>> I use?
>> Thanks
>> Oren Barzilai
> done.
> Jeroen Lankheet
Re: import existing project into workspace extension point [message #578468 is a reply to message #18991] |
> Thanks
> Oren
>>> Hello,
>>> I use?
>>> Thanks
>>> Oren Barzilai
>> done.
>> Regards,
>> Jeroen Lankheet
FUDForum. Page generated in 0.08609 seconds
