Home » Archived » IAM (Eclipse Integration for Apache Maven) » How to stop jetty:run from q4e 0.9?
How to stop jetty:run from q4e 0.9? [message #18834] Wed, 13 May 2009 23:20 Go to next message
I can launch my web app via the jetty:run goal from within q4e OK.
But it shows as a non-terminating task in Eclipse's Progress view.
Canceling the task using the red button in progress view is ineffective.
If I subsequently attempt goal jetty:stop (the "right way"), the launch of
this goal appears to block on the previous jetty:run goal.
Does q4e/IAM serialize maven goal execution?
If so, this seems to be a big obstacle to it supporting common usage
patterns.
-Ben
PS I expect I can workaround issue from Maven command line. However, to
some extent this defeats purpose of having Eclipse integration, if one
must regularly drop out of it.
Re: How to stop jetty:run from q4e 0.9? [message #18880 is a reply to message #18834] Thu, 14 May 2009 09:40 Go to previous messageGo to next message
Hello Ben,
Yes. IAM uses an single instance of the maven embedder, which is not
thread safe... so all calls are serialized.
We expect users to take advantage of WTP integration (which, if I am not
mistaken, already supports Jetty).
> patterns.
I think this deserves a bugzilla entry.
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=IAM
> -Ben
As a workaround, you can setup some External Tool Configurations (Run >
External Tools >...) in Eclipse for your typical use cases to run a
locally installed maven, so you do not need to leave the IDE (and, for
launching the jetty case, it will require you fewer clicks/keystrokes).
Thanks!
Abel Muiño
Re: How to stop jetty:run from q4e 0.9? [message #18903 is a reply to message #18880] Thu, 14 May 2009 10:30 Go to previous messageGo to next message
Abel Muiño wrote:
> Hello Ben,
>> launch of this goal appears to block on the previous jetty:run goal.
That's true.
Cheers
Philippe
Re: How to stop jetty:run from q4e 0.9? [message #569009 is a reply to message #18834] Thu, 14 May 2009 09:40 Go to previous messageGo to next message
Hello Ben,
> patterns.
> -Ben
Thanks!
Abel Muiño
Re: How to stop jetty:run from q4e 0.9? [message #569019 is a reply to message #18880] Thu, 14 May 2009 10:30 Go to previous messageGo to next message
Abel Muiño wrote:
> Hello Ben,
That's true.
Cheers
Philippe
Re: How to stop jetty:run from q4e 0.9? [message #652093 is a reply to message #18834] Wed, 02 February 2011 11:37 Go to previous message
btw is there a better solution than the workaround by Abel Muiño?
thank you
Tickets für aktuelle Events oder Tour Konzerte gibt es bei Tour Tournee
[Updated on: Wed, 02 March 2011 22:52] by Moderator
Previous Topic:The plugin 'org.apache.maven.plugins:maven-eclispe-plugin' does not exist or no valid version could
Next Topic:What command in Eclipse will compile Java test classes but would not run them)
Current Time: Mon Jul 21 21:31:31 EDT 2025
Powered by FUDForum. Page generated in 0.03926 seconds
