Home » Language IDEs » ServerTools (WTP) » files not getting published
files not getting published [message #197584] Mon, 30 July 2007 14:01 Go to next message
I am pulling my hair out with a WTP project that suddenly seems to
refuse to publish several files. Specifically, any files in my
src/main/java folder (which is specified as part of the Build Path) --
*except* for hibernate.cfg.xml -- do not get copied to WEB-INF/classes.
My org.eclipse.wst.common.components file has this line:
<wb-resource deploy-path="/WEB-INF/classes"
source-path="/src/main/java"/>
So shouldn't that mean that *all* files under /src/main/java get copied
to /WEB-INF/classes, period, end of story?
I have tried deleting and recreating the server configuration. I have
tried replacing my entire Eclipse install -- downloaded Europa fresh and
installed updates and WTP. Still the same behavior.
What can I do? This has brought my work to a grinding halt.....
Noel
Re: files not getting published [message #197601 is a reply to message #197584] Mon, 30 July 2007 14:32 Go to previous messageGo to next message
Noel Bush <noel@aitools.org> wrote in news:f8l92l$fqc$1@build.eclipse.org:
What aserver adapter are you trying to use in what platform..? As I
mentioned in a different post, there is known problem for Tomcat 5.5
https://bugs.eclipse.org/bugs/show_bug.cgi?id=107386
Re: files not getting published [message #197609 is a reply to message #197601] Mon, 30 July 2007 14:55 Go to previous messageGo to next message
Angel Vera wrote on 07/30/2007 02:32 PM:
Yes, I'm using Tomcat 5.5. Does this mean I'm out of luck? Are there
any workarounds? I can't find anything in the bug you link to that
describes the problem I'm encountering.
Thanks.....
Re: files not getting published [message #197618 is a reply to message #197609] Mon, 30 July 2007 15:17 Go to previous messageGo to next message
I think the bug is for a different problem. What is the output folder
for the Java classes in src/main/java and is this the only source
folder? Do you know how this Java source folder came about since you
normally get "src" as the default Java source folder for Dynamic Web
Projects?
Larry
> Thanks.....
Re: files not getting published [message #197626 is a reply to message #197618] Mon, 30 July 2007 15:22 Go to previous messageGo to next message
Thanks for your replies. The output folder for src/main/java. It is
not the only source folder -- there is one other. I changed both of
these and all seemed to be working well until just today. Earlier today
I found a problem where class files weren't getting updated properly.
So I tried re-creating the project, and that's where the trouble started.
But I have also tried creating a brand new "Dynamic Web Project" and
putting a file (log4j.properties, for example) into the default src
folder. It, too, does not get published.
Noel
Larry Isaacs wrote on 07/30/2007 03:17 PM:
> Projects?
> Cheers,
> Larry
>> Thanks.....
Re: files not getting published [message #197644 is a reply to message #197626] Mon, 30 July 2007 15:27 Go to previous messageGo to next message
Update -- I seem to have recovered the expected/desired behavior. But
in order to do this, I had to completely wipe out my workspace *and* the
project (after having already re-installed Eclipse). Now, suddenly, the
right files are getting copied into place.
Is there some hidden place where some of this behavior is configured?
See, I had to edit the .settings/org.eclipse.wst.common.component file
in order to customize how some files get copied. Maybe that's what
threw things off? But if so, what would be the *right* way for me to
find that out, and to find out what was wrong?
Noel
Noel Bush wrote on 07/30/2007 03:22 PM:
> I found a problem where class files weren't getting updated properly. So
> Noel
>> Projects?
>> Cheers,
>> Larry
>>> there any workarounds? I can't find anything in the bug you link to
>>> that describes the problem I'm encountering.
>>> Thanks.....
Re: files not getting published [message #197659 is a reply to message #197644] Mon, 30 July 2007 16:24 Go to previous message
There is some publish info that is cached so that multiple publishes
don't publish unchanged files over and over. To clear this cached
information, the easiest way is to remove the project, publish the
server, and then re-add the project to the server. If you only delete
the published files on the server, they won't automatically reappear
without this.
Larry
> Noel
>> today I found a problem where class files weren't getting updated
>> properly. So I tried re-creating the project, and that's where the
>> trouble started.
>> Noel
>>> folder for the Java classes in src/main/java and is this the only
>>> source folder? Do you know how this Java source folder came about
>>> since you normally get "src" as the default Java source folder for
>>> Dynamic Web Projects?
>>> Cheers,
>>> Larry
>>>> Thanks.....
Previous Topic:Servlet creation problem
Next Topic:beginer: converting non-web project into web project
Current Time: Sun May 11 14:33:22 EDT 2025
Powered by FUDForum. Page generated in 0.07799 seconds
