Home » Archived » BIRT » params["DateParam"].getYear() doesn't work in 2.1.1
params["DateParam"].getYear() doesn't work in 2.1.1 [message #197582] Wed, 25 October 2006 05:02 Go to next message
Something is changes in dates handling in JavaScript in BIRT v.2.1.1
following code works Ok in v.2.1.0:
in v.2.1.1 (and v.2.2M1 too) it returns an error.
Could anybody suggest - what to do?
Pavel
Re: params["DateParam"].getYear() doesn't work in 2.1.1 [message #197863 is a reply to message #197582] Thu, 26 October 2006 11:49 Go to previous messageGo to next message
Pavel,
Try params["DateParam"].value.getYear()
Jason
"Pavel Severov" <severov@gmail.com> wrote in message
news:cf76bc10a47e569ee2dc67a938b32305$1@www.eclipse.org...
> Hello,
> Pavel
Re: params["DateParam"].getYear() doesn't work in 2.1.1 [message #197931 is a reply to message #197863] Fri, 27 October 2006 02:36 Go to previous messageGo to next message
Thank you, Jason! Now it works.
Pavel
Re: params["DateParam"].getYear() doesn't work in 2.1.1 [message #198371 is a reply to message #197863] Mon, 30 October 2006 14:56 Go to previous messageGo to next message
Originally posted by: lingtai.earthlink.net
Jason:
I have encountered the same problem in my reports, i.e. the following
script worked in Birt 2.1.0 but failed in Birt 2.1.1.
params["rpCsLabels"].replace("-", " ", "gi");
after I changed it to the following as suggested
params["rpCsLabels"].value.replace("-", " ", "gi");
then I was able to create my report successfully.
However, I am not able to preview my dataset result any more after the
change. I will get following exception:
A BIRT exception occurred.
Plug-in Provider:Eclipse.org
Plug-in Name:BIRT Data Engine
Plug-in ID:org.eclipse.birt.data
Version:2.1.1.v20060922-1058
Error Code:data.engine.BirtException
Error Message:A BIRT exception occurred: Error evaluating Javascript
expression. Script engine error: TypeError: Cannot call method "replace"
of undefined (DataSet[getTotalConfigUnchanged].__bm_beforeOpen#9)
Script source: DataSet[getTotalConfigUnchanged].__bm_beforeOpen, line:
1, text:
__bm_beforeOpen(). See next exception for more information.
Error evaluating Javascript expression. Script engine error: TypeError:
Cannot call method "replace" of undefined
1, text:
__bm_beforeOpen()
Is this a bug? Is it right that the same script code work differently
in dataset preview and in reporting preview?
Ling
Jason Weathersby wrote:
> Pavel,
> Jason
>> Hello,
>> Pavel
Re: params["DateParam"].getYear() doesn't work in 2.1.1 [message #198443 is a reply to message #198371] Tue, 31 October 2006 14:47 Go to previous messageGo to next message
Ling,
Can you log a bug for this?
I assume the report runs correctly?
Jason
"Ling Tai" <lingtai@earthlink.net> wrote in message
news:454658E7.3000307@earthlink.net...
> Jason:
> Script source: DataSet[getTotalConfigUnchanged].__bm_beforeOpen, line: 1,
> text:
> text:
> __bm_beforeOpen()
> Is this a bug? Is it right that the same script code work differently in
> Best regards,
> Ling
>> Pavel,
>> Jason
>>> Hello,
>>> Pavel
Re: params["DateParam"].getYear() doesn't work in 2.1.1 [message #198541 is a reply to message #198443] Tue, 31 October 2006 16:03 Go to previous message
Jason:
Yes, the report runs correctly except when I try to preview the result
of the dataset, I will get the exception.
I will log the bug. Thank you so much for your help.
Ling
> Ling,
> Jason
>> Jason:
>> text:
>> text:
>> __bm_beforeOpen()
>> Best regards,
>> Ling
>>> Pavel,
>>> Jason
>>>> Hello,
>>>> Pavel
Previous Topic:Hiding / Reordering Columns
Next Topic:Javascript function getColumnMetaData() does not work on dataset open method
Current Time: Sun May 11 04:52:39 EDT 2025
Powered by FUDForum. Page generated in 0.04047 seconds
