Home » Eclipse Projects » Buckminster dev » Re: [buckminster-dev] Strange resolver behaviour when resolving PDE plugins - using "native&quo
Re: [buckminster-dev] Strange resolver behaviour when resolving PDE plugins - using "native&quo [message #18816] |
Tue, 27 May 2008 10:26 |
------=_Part_9241_27684446.1211898395648
Content-Type: text/plain; charset=UTF-8
Content-Disposition: inline
Hi.
Found another strange issue.
In my target platform I have two versions of "org.eclipse.emf.common":
1) 2.3.0
2) 2.3.2
Issue #1: When I try to resolve "org.eclipse.emf.common" w/o version
specification, Buckminster gives me "2.3.0" version. Strange, cause it has
to give me the latest version, am I right?
Issue #2: When I try to resolve "org.eclipse.emf.common" with version
specification set to "[2.3.1,3.0.0)", Buckminster returns an error. Log
says:
org.eclipse.emf.common:osgi.bundle/[2.3.1,3.0.0)#OSGi: Using resolver rmap
org.eclipse.emf.common:osgi.bundle/[2.3.1,3.0.0)#OSGi: Version
2.3.0.v200709252135 rejected: not designated by [2.3.1,3.0.0)
org.eclipse.emf.common:osgi.bundle/[2.3.1,3.0.0)#OSGi: Rejecting provider
eclipse.platform(plugin/${buckminster.component}): No component match was
found
org.eclipse.emf.common:osgi.bundle/[2.3.1,3.0.0)#OSGi: Using resource map
file:/C:/Work/workspaces/xdoc/bm/xdoc.rmap
org.eclipse.emf.common:osgi.bundle/[2.3.1,3.0.0)#OSGi: No searchPath was
found with a matching pattern
cloudsmith
So, based on this two issues, I think Buckminster ignores my second plugin.
I guess Buckminster's "eclipse.platform" support only one version of plugin,
and he takes the first one in lexicographical order?
What can be done to fix this issue? Or I just have to remove old plugins
from my target platform? :-)
Thanks.
ps I've used "Refresh Meta-data" button from Buckminster preferences, but it
didn't help too :'(
2008/5/26, Thomas Hallgren <thomas@tada.se>:
> Hi Mikhail,
> Mikhail Kadan wrote:
>> So I can made a conclusion, that Buckminster also searches his "native"
>> target platform (target platform which was used to start Eclipse), and if it
>> finds a match here, which has bigger version than others, it will try to
>> materialize this plugin from "native" platform.
> Yes, your conclusion is correct.
> How can I set Buckminster not to look in his "native" target platform for
>> plugins?
> You declare an advisory node in the component query where you omit the
> target platform from the resolution scope (see the "Resolution Scope" pane
> under the "Advisor node" tab in the CQUERY editor.
>> ps By the way, can anyone provide example how "eclipse.platform" reader
>> works? I've tried such RMAP but couldn't get it to work:
>> The "eclipse.platform" reader type is for internal use only. You should
> not use it in an RMAP.
> Thomas Hallgren
> _______________________________________________
> buckminster-dev mailing list
> buckminster-dev@eclipse.org
> https://dev.eclipse.org/mailman/listinfo/buckminster-dev
Content-Type: text/html; charset=UTF-8
Hi.<br><br>Found another strange issue.<br><br>In my target platform I have two versions of "org.eclipse.emf.common":<br>1) 2.3.0<br>2) 2.3.2<br><br>Issue #1: When I try to resolve "org.eclipse.emf.common" w/o version specification, Buckminster gives me "2.3.0" version. Strange, cause it has to give me the latest version, am I right? <br>
<br>Issue #2: When I try to resolve "org.eclipse.emf.common" with version specification set to "[2.3.1,3.0.0)", Buckminster returns an error. Log says:<br><br>...<br>org.eclipse.emf.common:osgi.bundle/[2.3.1,3.0.0)#OSGi: Using resolver rmap<br>
org.eclipse.emf.common:osgi.bundle/[2.3.1,3.0.0)#OSGi: Version 2.3.0.v200709252135 rejected: not designated by [2.3.1,3.0.0)<br>org.eclipse.emf.common:osgi.bundle/[2.3.1,3.0.0)#OSGi: Rejecting provider eclipse.platform(plugin/${buckminster.component}): No component match was found<br>
org.eclipse.emf.common:osgi.bundle/[2.3.1,3.0.0)#OSGi: Using resource map file:/C:/Work/workspaces/xdoc/bm/xdoc.rmap<br>org.eclipse.emf.common:osgi.bundle/[2.3.1,3.0.0)#OSGi: No searchPath was found with a matching pattern<br>
org.eclipse.emf.common:osgi.bundle/[2.3.1,3.0.0)#OSGi: Using resolver cloudsmith<br>...<br><br>So, based on this two issues, I think Buckminster ignores my second plugin. I guess Buckminster's "eclipse.platform" support only one version of plugin, and he takes the first one in lexicographical order? <br>
<br>What can be done to fix this issue? Or I just have to remove old plugins from my target platform? :-)<br><br>Thanks.<br><br><br>ps I've used "Refresh Meta-data" button from Buckminster preferences, but it didn't help too :'( <br>
<br><div><span class="gmail_quote">2008/5/26, Thomas Hallgren <<a href="mailto:thomas@tada.se">thomas@tada.se</a>>:</span><blockquote class="gmail_quote" style="margin-top: 0; margin-right: 0; margin-bottom: 0; margin-left: 0; margin-left: 0.80ex; border-left-color: #cccccc; border-left-width: 1px; border-left-style: solid; padding-left: 1ex">
Hi Mikhail,<span class="q"><br><br> Mikhail Kadan wrote:<br><blockquote class="gmail_quote" style="margin-top: 0; margin-right: 0; margin-bottom: 0; margin-left: 0.80ex; border-left-color: #cccccc; border-left-width: 1px; border-left-style: solid; padding-left: 1ex">
<br> So I can made a conclusion, that Buckminster also searches his "native" target platform (target platform which was used to start Eclipse), and if it finds a match here, which has bigger version than others, it will try to materialize this plugin from "native" platform.<br>
</blockquote></span> Yes, your conclusion is correct.<span class="q"><br><br><blockquote class="gmail_quote" style="margin-top: 0; margin-right: 0; margin-bottom: 0; margin-left: 0.80ex; border-left-color: #cccccc; border-left-width: 1px; border-left-style: solid; padding-left: 1ex">
How can I set Buckminster not to look in his "native" target platform for plugins?<br></blockquote></span> You declare an advisory node in the component query where you omit the target platform from the resolution scope (see the "Resolution Scope" pane under the "Advisor node" tab in the CQUERY editor.<span class="q"><br>
<br><blockquote class="gmail_quote" style="margin-top: 0; margin-right: 0; margin-bottom: 0; margin-left: 0.80ex; border-left-color: #cccccc; border-left-width: 1px; border-left-style: solid; padding-left: 1ex"><br><br> ps By the way, can anyone provide example how "eclipse.platform" reader works? I've tried such RMAP but couldn't get it to work:<br>
<br></blockquote></span> The "eclipse.platform" reader type is for internal use only. You should not use it in an RMAP.<br><br><br> Regards,<br> Thomas Hallgren<br><br> _______________________________________________<br>
buckminster-dev mailing list<br><a href="mailto:buckminster-dev@eclipse.org" target="_blank" onclick="return top.js.OpenExtLink(window,event,this)">buckminster-dev@eclipse.org</a><br><a href="https://dev.eclipse.org/mailman/listinfo/buckminster-dev" target="_blank" onclick="return top.js.OpenExtLink(window,event,this)">https://dev.eclipse.org/mailman/listinfo/buckminster-dev</a><br>
</blockquote></div><br>
------=_Part_9241_27684446.1211898395648--
Current Time: Tue Jul 15 16:23:06 EDT 2025
Powered by FUDForum. Page generated in 0.06693 seconds
