Re: How do I remove plugins and features [message #197372 is a reply to message #197256] |
Thu, 01 March 2007 23:57 |
Originally posted by: eclipse5.rizzoweb.com
Hendrik Maryns wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Mikael Ståldal schreef:
>> How do I remove plugins/features installed in Eclipse?
> Window -> Find and install updates -> Manage Configuration
> (or something close to that, I have Eclipse shut down right now)
Close; it is Help > Software Updates > Manage Configuration.
From there you can locate the feature/plugin you don't want, select it,
and use the Disable link in the right pane.
Hope this helps,
Eric
Re: How do I remove plugins and features [message #197465 is a reply to message #197449] |
Fri, 02 March 2007 10:04 |
Originally posted by: eiben.weite-welt.com
Sophie schrieb:
> Help > Software Updates > Manage Configuration and select the plgin you
> want to uninstall, right click on it and select uninstall => the plugin
> and feature will be remove into the plugins and fetaures folders.
well, I suppose this only works, if the plugins got installed this way.
If you just copied the plugins into the plugin/features folder this
command is not available.
.... Gentlemen: Start your debuggers...
Re: How do I remove plugins and features [message #197482 is a reply to message #197475] |
Fri, 02 March 2007 10:43 |
This is an OpenPGP/MIME signed message (RFC 2440 and 3156)
--------------enig77A5BACC1764E26C2F6F0577
Content-Type: text/plain; charset=ISO-8859-15
Sophie schrieb:
>> well, I suppose this only works, if the plugins got installed this way=
=2E
>=20
>=20
>=20
> Yes, you're right...
well, so is there any way of easily removing *those* plugins? :)
-=3D-=3D-
=2E.. Black holes suck.
Content-Type: application/pgp-signature; name="signature.asc"
Content-Description: OpenPGP digital signature
Content-Disposition: attachment; filename="signature.asc"
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.5 (MingW32)
iQEVAwUBRef/wqeyVuH0oyzFAQI/IAgAhx7q19QRoCFsBdxo6bk3ryhxyhk4 a3Yv
eMlQCFHekJbA7G0ApmyZgPitMhvF2YHp4bl9GX/NhnZptZDlgMXvSdzso86h FovN
vuEXZjecpaGhwag55VNpv9FljH6IA+Ik0PyNY7Jm2Yc+PnRRo78y7CgSTWLW hnIk
eWuWXOOX0wvC9vbqtPXtjnXrOYEVHvifepog76aWPXlfzVW+f7XpM6qoH9Wf RdvB
mQwBS1xQd5z4aQ7m2cZjbktwhBX4sYQ249EFBvl3E5f8xI5yySvnqu1UQELi YotB
Xm0Qc/KnJfOuWsVivkYEWoChUfEHSm4CkEzlKeqHO8LTB/h7lFpnqw==
=WXgP
-----END PGP SIGNATURE-----
--------------enig77A5BACC1764E26C2F6F0577--
Re: How do I remove plugins and features [message #197514 is a reply to message #197490] |
Fri, 02 March 2007 12:58 |
> The way to do is that if you have installed plugins manually, you must
> also remove them manually... I don't think there is another solution...
I was afraid you would say something like this; but the question is: how
do I identify which folders and jar files belong to a certain plugin :)
Well, I could of course look at the archiv, that I installed previously
and then search for all matching files :)
.... There are 10 kinds of people. Those who know binary code, and those
who don't.
Re: How do I remove plugins and features [message #197606 is a reply to message #197514] |
Fri, 02 March 2007 18:01 |
Look in the plugins and features directories - each one has a name that
indicates what it is. It should be pretty straightforward to determine
which ones you don't want anymore.
One more thing: after deleting plugins and/or features, you should
restart Eclipse with the -clean command-line argument one time to force
it to flush its cache of plugins.
Hope this helps,
Eric
Re: How do I remove plugins and features [message #198486 is a reply to message #197449] |
Thu, 08 March 2007 13:36 |
Originally posted by: SB.Prasad.lycos.co.uk
I have downloaded two versions of EclipseUML_E320 as below. I will
appreciate answers to following as a newcomer.
1. Are both of these versions open source and free?
2. What are the differences?
3. Do these work with JDK SE6 or any compatibility issues?
4. Can I use these to reverse engineer JDBC and Java projects?
5. What does Callisto do from a UML2 perspective?
6. Are imports using MDL and XMI allowed for tranfer from Rational Rose?
7. Can these tools open/import Borland Together Projects in UML2?
Thank you.
Sanjeev.
____________________________________________________________ ________
EclipseUML_E320_Free_Edition_2.1.0.20061007_including_Callis to
EclipseUML_E320-J2EE-SDK-Callisto-Christmas-Maintenance-win3 2
Re: How do I remove plugins and features [message #198580 is a reply to message #198486] |
Thu, 08 March 2007 15:51 |
It appears you are talking about the Omondo product. You should go to
whatever user forums they provide, as that is a commercial company
separate from Eclipse.
Eric
FUDForum. Page generated in 0.09615 seconds
