Home » Archived » BIRT » pie chart and translation table for categories defined by code
pie chart and translation table for categories defined by code [message #196817] Fri, 20 October 2006 10:24
my dataset returns such data:
a|b
1|6
2|1
3|3
I put a column into categories and b column as
y axis (values). Of course, resulting chart is
totally unreadable, so I need to provide labels
for the codes from a column.
I worked around this issue with javascript:
switch(row["a"]) {
case 1: "Correct"; break;
case 2: "Incorrect"; break;
default: "Unknown";
Do you have better idea how to eachieve similar effect?
Is it possible to specify some translation table for
categories?
Thanks, have a nice weekend
Leos
Previous Topic:Numbering a grouped table
Next Topic:Rendering multiple series with different numbers of data points
Current Time: Mon Jul 21 22:52:30 EDT 2025
Powered by FUDForum. Page generated in 0.03324 seconds
