Home » Eclipse Projects » Eclipse Platform » Can't Launch under MacOS X
Can't Launch under MacOS X [message #1580] Mon, 21 April 2003 19:46 Go to next message
Originally posted by: bshive.comcast.net
I tried a previous version of Eclipse and just downloaded the 2.1 version.
It doesn't seem to launch under 10.2.5 with j1.4.4. I searched for any
similar problems and fixes, but nothing came up. Launched from the icon or
the command line it attempts to start, does a few bounces and then quits.
I've tried deleting Eclipse entirely and downloading it again with no
success.
Re: Can't Launch under MacOS X [message #2899 is a reply to message #1580] Tue, 22 April 2003 12:51 Go to previous messageGo to next message
Originally posted by: Andre_Weinand.oti.com
On 22.4.2003 1:46 Uhr, in article b81vse$4vs$1@rogue.oti.com, "Ben"
> success.
Is there any output on the Console ?
Any messages in workspace/.metadata/.log ?
Please make sure that you don't have any additional Java libraries
(e.g. xerces.jar) somewhere on your class path.
--andre
Re: Can't Launch under MacOS X [message #2917 is a reply to message #1580] Tue, 22 April 2003 12:56 Go to previous messageGo to next message
> success.
There is a known conflict with the Apache Xerces application. If you
have Xerces (specifically the xercesImpl.jar library) in your
classpath, Eclipse will not launch. Try removing that from your
classpath (it will probably be in the JDK lib/ext folder) and see if
that solves your problem.
There's a bug filed in the Eclipse bugzilla for this.
Jerry
Jerry Wilcox - Jerry.Wilcox@ucop.edu
All opinions are mine alone - the University can speak for itself.
-- After silence, that which comes nearest to expressing the inexpressible is
music. - Aldous Huxley
Re: Can't Launch under MacOS X [message #4932 is a reply to message #2917] Tue, 22 April 2003 19:36 Go to previous message
That was the problem. I\\\'d been working with httpunit (which includes
xercesImpl.jar) and had added it in /Library/Java/Extensions. Moved it
elsewhere and just added to the classpath for the one thing I need it for.
Thanks, wish I\\\'d been able to find this information elsewhere but
hopefully it helps someone else.
> > It doesn\\\'t seem to launch under 10.2.5 with j1.4.4. I searched for any
> > I\\\'ve tried deleting Eclipse entirely and downloading it again with no
> > success.
> There\\\'s a bug filed in the Eclipse bugzilla for this.
> Jerry
Previous Topic:How to untar using org.apache.tools.tar
Next Topic:how to install on win2000
Current Time: Mon Sep 08 01:51:39 EDT 2025
Powered by FUDForum. Page generated in 0.04607 seconds
