Home » Eclipse Projects » GEF » reference GraphicalEditor from an EditPart
reference GraphicalEditor from an EditPart [message #195975] Wed, 14 September 2005 13:05 Go to next message
Originally posted by: pbeagan.yahoo_dontspamme_.com
I need to be able to get a reference to my GraphicalEditor from an EditPart.
Is there a way to do this?
I wrote a custom view which is a ISelectionListener listening for EditPart
selections. It makes updates to my model without using the command stack.
I need to be able to setDirty() on my GraphicalEditor.
Re: reference GraphicalEditor from an EditPart [message #195983 is a reply to message #195975] Wed, 14 September 2005 14:16 Go to previous messageGo to next message
Why don't you use the command stack?
Re: reference GraphicalEditor from an EditPart [message #195991 is a reply to message #195983] Wed, 14 September 2005 17:02 Go to previous messageGo to next message
Well My view knows nothing about the command stack or the GraphicalEditor,
it only knows about selected objects that implement my interface. I will
look into hooking it into using the command stack, but right now I'm really
not sure how to do this as loading the view does not seem to pass through
the GraphicalEditor.getAdapter() method. If it did, I would be able to
grab the reference to the GraphicalEditor.
>> EditPart. Is there a way to do this?
>> EditPart
>> stack. I need to be able to setDirty() on my GraphicalEditor.
Re: reference GraphicalEditor from an EditPart [message #196007 is a reply to message #195991] Thu, 15 September 2005 02:12 Go to previous message
Originally posted by: mvsteenbergen.eljakim.scratch-this.nl
You can register your view as a part listener to the current workbench
page. Then you get notified whenever an editor get (de)activated (or
more generally, whenever a part (=editor/view) gets (de)activated). Use
this to track the active editor. Whenever the active editor changes, ask
the new active editor for a command stack:
editor.getAdapter(CommandStack.class)
Then it doesn't really matter anymore whether the editor is an instance
of your GraphicalEditor so you won't even have to cast to
(YourGraphicalEditor). Make sure your GraphicalEditor returns its
command stack in its getAdapter() method. It might already do this (I'm
not sure); else you'll have to override.
Martijn.
Previous Topic:Getting abolute path
Next Topic:Gradient fill for ovals
Current Time: Sat Jul 26 08:31:24 EDT 2025
Powered by FUDForum. Page generated in 0.04627 seconds
