Home » Language IDEs » AspectJ » WSAD 5.0 / ANT 1.5.1 / AJDT 1.1.1
WSAD 5.0 / ANT 1.5.1 / AJDT 1.1.1 [message #18677] Fri, 21 March 2003 09:25 Go to next message
I am trying to build using the above configuration, but I fail to do so.
The ANT script I use runs perfectly when invoked from the DOS prompt, but
fails when invoked from WSAD.
When run under WSAD, I get
java.lang.NoClassDefFoundError:
org/aspectj/ajdt/internal/core/builder/ClasspathContainer
at org.aspectj.ajdt.ajc.AjdtCommand.runCommand(AjdtCommand.java :50)
at org.aspectj.tools.ajc.Main.run(Main.java:216)
at org.aspectj.tools.ant.taskdefs.Ajc10.spoon(Ajc10.java:598)
at org.aspectj.tools.ant.taskdefs.Ajc10.execute(Ajc10.java:484)
at org.apache.tools.ant.UnknownElement.execute(UnknownElement.j ava:193)
at org.apache.tools.ant.Task.perform(Task.java:341)
at org.apache.tools.ant.Target.execute(Target.java:309)
at org.apache.tools.ant.Target.performTasks(Target.java:336)
at org.apache.tools.ant.Project.executeTarget(Project.java:1339 )
at org.apache.tools.ant.taskdefs.Ant.execute(Ant.java:397)
at org.apache.tools.ant.taskdefs.CallTarget.execute(CallTarget. java:143)
at org.apache.tools.ant.Project.executeTargets(Project.java:125 5)
org.eclipse.ant.internal.core.ant.InternalAntRunner.run(Inte rnalAntRunner.java:262)
at org.eclipse.ant.core.AntRunner.run(AntRunner.java:234)
org.eclipse.ui.externaltools.internal.core.AntFileRunner.exe cute(AntFileRunner.java:56)
org.eclipse.ui.externaltools.internal.core.DefaultRunnerCont ext.executeRunner(DefaultRunnerContext.java:428)
org.eclipse.ui.externaltools.internal.core.DefaultRunnerCont ext.run(DefaultRunnerContext.java:479)
org.eclipse.ui.externaltools.internal.ui.AntLaunchWizard$1.r un(AntLaunchWizard.java:117)
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:98)
Any clues anybody?
Re: WSAD 5.0 / ANT 1.5.1 / AJDT 1.1.1 [message #18909 is a reply to message #18677] Tue, 01 April 2003 09:09 Go to previous message
WSAD 5.0 is based on Eclipse 2.0.2 which, I think, only supports Ant 1.4.1.
So you are running Ant 1.5.1 on the command line but Ant 1.4.1 in WSAD 5.0.
Does your Ant script run cleanly on the command line when using Ant 1.4.1 ?
George
On Fri, 21 Mar 2003 14:25:45 +0000 (UTC), Peter Friese
<peter.friese@lhsystems.com> wrote:
> at
> at
> at
> at
> at
> at
> Any clues anybody?
Re: WSAD 5.0 / ANT 1.5.1 / AJDT 1.1.1 [message #565322 is a reply to message #18677] Tue, 01 April 2003 09:09 Go to previous message
George
> at
> at
> at
> at
> at
> at
> Any clues anybody?
Previous Topic:Where is the source code for ajde1.1.1?
Next Topic:Problems (bugs?) in building and running AspectJ programs in AJDT 1.1.1
Current Time: Fri Jul 18 00:49:30 EDT 2025
Powered by FUDForum. Page generated in 0.06167 seconds
