WSAD 5.0 / ANT 1.5.1 / AJDT 1.1.1 [message #18677] |
Fri, 21 March 2003 09:25  |
I am trying to build using the above configuration, but I fail to do so.
The ANT script I use runs perfectly when invoked from the DOS prompt, but
fails when invoked from WSAD.
When run under WSAD, I get
java.lang.NoClassDefFoundError:
org/aspectj/ajdt/internal/core/builder/ClasspathContainer
at org.aspectj.ajdt.ajc.AjdtCommand.runCommand(AjdtCommand.java :50)
at org.aspectj.tools.ajc.Main.run(Main.java:216)
at org.aspectj.tools.ant.taskdefs.Ajc10.spoon(Ajc10.java:598)
at org.aspectj.tools.ant.taskdefs.Ajc10.execute(Ajc10.java:484)
at org.apache.tools.ant.UnknownElement.execute(UnknownElement.j ava:193)
at org.apache.tools.ant.Task.perform(Task.java:341)
at org.apache.tools.ant.Target.execute(Target.java:309)
at org.apache.tools.ant.Target.performTasks(Target.java:336)
at org.apache.tools.ant.Project.executeTarget(Project.java:1339 )
at org.apache.tools.ant.taskdefs.Ant.execute(Ant.java:397)
at org.apache.tools.ant.taskdefs.CallTarget.execute(CallTarget. java:143)
at org.apache.tools.ant.Project.executeTargets(Project.java:125 5)
org.eclipse.ant.internal.core.ant.InternalAntRunner.run(Inte rnalAntRunner.java:262)
at org.eclipse.ant.core.AntRunner.run(AntRunner.java:234)
org.eclipse.ui.externaltools.internal.core.AntFileRunner.exe cute(AntFileRunner.java:56)
org.eclipse.ui.externaltools.internal.core.DefaultRunnerCont ext.executeRunner(DefaultRunnerContext.java:428)
org.eclipse.ui.externaltools.internal.core.DefaultRunnerCont ext.run(DefaultRunnerContext.java:479)
org.eclipse.ui.externaltools.internal.ui.AntLaunchWizard$1.r un(AntLaunchWizard.java:117)
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:98)
Any clues anybody?
Re: WSAD 5.0 / ANT 1.5.1 / AJDT 1.1.1 [message #18909 is a reply to message #18677] |
Tue, 01 April 2003 09:09  |
WSAD 5.0 is based on Eclipse 2.0.2 which, I think, only supports Ant 1.4.1.
So you are running Ant 1.5.1 on the command line but Ant 1.4.1 in WSAD 5.0.
Does your Ant script run cleanly on the command line when using Ant 1.4.1 ?
George
On Fri, 21 Mar 2003 14:25:45 +0000 (UTC), Peter Friese
<peter.friese@lhsystems.com> wrote:
> at
> at
> at
> at
> at
> at
> Any clues anybody?
Re: WSAD 5.0 / ANT 1.5.1 / AJDT 1.1.1 [message #565322 is a reply to message #18677] |
George
> at
> at
> at
> at
> at
> at
> Any clues anybody?
FUDForum. Page generated in 0.05040 seconds
