Re: About XSD Model Tool [message #195567 is a reply to message #195513] |
Thu, 22 February 2007 13:39 |
--------------050604020707050402030406
Olfa,
You asked the same question separately on the EMF newsgroup, which is a
better place to ask this. My answer there was:
I'm not sure which things you are pointing at so I'll answer in a
general way. In order to load from an IFile x, you should create a
URI as follows
URI.createPlatformResourceURI(x.getFullPath().toString(), true);
The resulting URI will load and save using the platform's resource APIs.
If it makes sense to post a question to multiple groups (which is almost
always not the case), you should do so with a single posting to the
multiple newsgroups so that an answer on any one newsgroup will appear
on all the newsgroups. This avoids multiple people answering the same
question in parallel.
Olfa wrote:
> Hi, I used the example of package "org.eclipse.xsd.examples.command"
> : the
> class "CreateXSDWithNoTNSOperation". I want to use the method "
> XSDSchema createXSDSchema(IFile xsdFile)" in the classe's main but i
> don't
> know how to use or call the parameter "IFile" !
> Could you give me an example please where you used the
> method "createXSDSchema(IFile xsdFile)" ?
> Can I use File in the place of IFile , can I use the library in
> another IDE
> Thank you
<html>
<head>
http-equiv="Content-Type">
</head>
Olfa,<br>
<br>
FUDForum. Page generated in 0.08369 seconds
