update the classpath [message #195470] |
Thu, 22 February 2007 06:54 |
Originally posted by: gabi.mordov.kodak.com
i need to update the classpath in eclipse.
where should i do it???
Tia
Re: update the classpath [message #195478 is a reply to message #195470] |
Thu, 22 February 2007 07:59 |
Originally posted by: wharley.bea.com
"gabi" <gabi.mordov@kodak.com> wrote in message
news:3237975bb5add25e367907478474200d$1@www.eclipse.org...
Do you mean the classpath that you compile your Java code against? That is
in Project -> Properties -> Java Build Path.
Or do you mean the classpath that you run your code against? That depends
on what you're writing, but take a look in the launch configuration dialog
(e.g., Run As...).
Or do you mean the classpath that Eclipse itself sees? You shouldn't really
have to worry about that, since the Eclipse launcher takes care of it.
If you mean something other than those, please be more specific.
Re: update the classpath [message #195492 is a reply to message #195478] |
Thu, 22 February 2007 08:33 |
Hi Walter,
my mission was add and mysql_connector_java.... .
so i figure it out i should put it under:
Project->Properties->Java Build Path->Libraries->add external JARSs==>add
mysql-connector-java5.0.0-beta-bin.jar
Thanks for your replay.
Have a nice day
FUDForum. Page generated in 0.09369 seconds
