Post-Build Step [message #195377] |
Wed, 21 February 2007 16:06 |
Originally posted by: jonathan.orditz.selectron.ch
I want to use the Post-Build Step in order to modify some things on my
executable.
To make these changes I need to call to different tools, but I can only
write one line in the Post-Build Step ! So the question: it is possible to
write more than one line for the Post-Build Step:
Command1.exe
Command2.exe, etc...
I have tried to call a batch File but then the ${variables} are not
replaced by their values...
Could someone help me to solve this problem ?
Thanks in advance...
Jonathan
Re: Post-Build Step [message #195415 is a reply to message #195377] |
Wed, 21 February 2007 17:50 |
Originally posted by: jacek.pospychala.pl.ibm.com
Jonathan,
do you mean Post-Build Step featured by Eclipse C/C++ Development
Tooling (CDT)?
It's best to ask on platform.tools.cdt then.
Anyway if the ${variables} are replaced only on command line, then you
could try call your bach file with them as an argument, and then inside
the batch refer to command line arguments.
Jonathan napisał(a):
> executable.
> to write more than one line for the Post-Build Step:
> Command1.exe
> Jonathan
FUDForum. Page generated in 0.08586 seconds
