Home » Archived » Maven Integration (M2E) » [tycho] hybrid dependencies
[tycho] hybrid dependencies [message #18633] |
Mon, 20 October 2008 13:09  |
Often, Eclipse plug-ins depend on third party (or in house) libraries
that are managed/understood by maven, but they are not OSGi bundles.
The typical Eclipse practice is to wrap the jar in a bundle manually,
but this has disadvantages. For example, I'm working on a project where
we have a core java library that is used both by pure Java apps and
Eclipse RCP ones. Currently, we jar it up and wrap it in a plug-in, but
this adds excessive complexity to the development environment (changing
the core library source is not visible to the RCP app until the jar is
rebuilt and re-wrapped).
Has Tycho considered a use case where a plug-in project has both OSGi
dependencies and regular POM dependencies? Could Tycho/m2e somehow
transparently do the wrapping step?
Will
Re: [tycho] hybrid dependencies [message #18699 is a reply to message #18633] |
Tue, 21 October 2008 13:42   |
If your team controls the build of the core java library, I would
recommend generating OSGi metadata as part of the build. Then, you can
tell tycho to use this library as part of build target platform and it
will resolve it from maven repository (see the message with subject "Re:
[m2eclipse-user] Tycho: Eclipse plugin dependency resolution from
local repository" I just forwarded from m2e user list). We're using
maven-osgi-packaging-plugin:generate-bundle mojo in m2e build to
generate OSGi metadata. You might be able to use felix/bnd mojos too,
but I have not had much success when I tried it earlier this year (this
was one of the reasons I started to work on tycho).
I looked at the problem of transparently adding plain jars to the build
target platform some time ago too. I came to conclusion it was not
possible without extra metadata that will tell tycho how to map maven
dependencies into osgi and what packages to export. But I'll be happy to
change my mind if we can come up with an approach that works completely
transparently.
Igor
Re: [tycho] hybrid dependencies [message #18722 is a reply to message #18699] |
Tue, 21 October 2008 16:37   |
> emaven-osgi-packaging-plugin:gnerate-bundle mojo in m2e build to
I have successfully used the felix maven-bundle-plugin to wrap jars in a
bundle. This works for static third party jars that can be dropped into
the target platform. However, with an in house core java library, I
would like to be able to modify the source in Eclipse and have it
understood by PDE immediately (without an extra step of generating
metadata and re-deploying to the target). Does Tycho have any mojo to
just generate the PDE files (build.properties, MANIFEST.MF, .project,
..classpath) for Eclipse without packaging and installing the bundle?
> transparently.
My project structure boils down to this:
core - java project with many third party (non OSGi) dependencies
managed by Maven
app1 - java project depending on core, managed by Maven
app2 - RCP application, depends on core (and thus indirectly on the
third party libraries)
(This is, in fact, a simplification - there are actually more than one
"core" libraries, and more than one pure java apps using the core libraries)
As you can see, with core and app1, there are no issues. Maven takes
care of everything. With app2 in the mix, I now need OSGi bundles to
make core and all of the third party libraries available to Eclipse
plug-ins.
It seems theoretically possible to walk the dependency tree and make
bundles for all non OSGi projects. The generated bundles could export
all packages and each maven dependency could be translated into a
Require-Bundle. In addition, there would need to be some bundle naming
conventions. That being said, without any mechanism to manually
customize the MANIFEST, you can quickly run into classloading issues
that could make the tool unusable.
I am more than happy to continue the discussion and help in any way I
can. Getting Eclipse and Maven working together for both development
and packaging is a big pain point, so thanks for your great work!
-Will
Re: [tycho] hybrid dependencies [message #18769 is a reply to message #18722] |
Wed, 22 October 2008 23:57  |
>> "Re: [m2eclipse-user] Tycho: Eclipse plugin dependency resolution
>> from local repository" I just forwarded from m2e user list). We're
>> using emaven-osgi-packaging-plugin:gnerate-bundle mojo in m2e build to
>> (this was one of the reasons I started to work on tycho).
There is generate-bundle mojo in
org.codehaus.tycho:maven-osgi-packaging-plugin that generates
MENIFEST.MF and build.properties files without packaging. It should not
be too difficult to write m2e project configurator that would nicely
integrate this into eclipse... I can show you examples and give you some
pointers, if you're interested to implement this yourself. Or submit an
enhancement request in m2e jira [2] and I will have a look, although I
can't tell when.
>> build target platform some time ago too. I came to conclusion it was
>> not possible without extra metadata that will tell tycho how to map
>> maven dependencies into osgi and what packages to export. But I'll be
>> happy to change my mind if we can come up with an approach that works
>> completely transparently.
> managed by Maven
> libraries)
> plug-ins.
I agree that mapping maven dependencies to OSGi is not trivial and in
many cases will require explicit configuration to properly represent
developers intent. (see [1] for a brief analysis of the problem I did
earlier this year). I also think that exporting all packages will be a
problem in some cases, particularly for applications that use
Import-Package and DynamicImport-Package.
So it seems like workable solution should have three things
1. have reasonable defaults that would generate proper OSGi metadata for
"conventional" artifacts
2. allow configuration of OSGi metadata generation on the consumer side
3. provide mechanism to push generation configuration to developers
responsible for the artifact
We've been talking about implementing something like this, but no
specific plans yet.
> -Will
[1]
http://docs.codehaus.org/display/M2ECLIPSE/Mapping+Maven+dep endencies+to+OSGi
[2] http://jira.codehaus.org/browse/MNGECLIPSE
Current Time: Mon Jul 07 05:19:21 EDT 2025
Powered by FUDForum. Page generated in 0.04067 seconds
