Home » Archived » BIRT » Build error
Build error [message #18591] Wed, 16 March 2005 00:19 Go to next message
Originally posted by: edlinoor.xgo.com.my
hi,
I try to build BIRT from CVS but unfortunately I get this error:
compile.src:
jar:
[copy] Copying 1 file to
H:\eclipse\workspace-BI\org.eclipse.birt.data\lib
build:
[mkdir] Created dir: H:\eclipse\workspace-BI\org.eclipse.birt.data\bin
[javac] Compiling 309 source files to
[javac] error: error reading
H:\eclipse\workspace-BI\org.eclipse.birt.data\test\drivers\d riversForMap\mappedDriver1\odaconfig.xml;
java.util.zip.ZipException: error in opening zip file
[javac] Note: * uses or overrides a deprecated API.
[javac] Note: Recompile with -Xlint:deprecation for details.
[javac] 1 error
BUILD FAILED:
H:\eclipse\workspace-BI\org.eclipse.birt.report.viewer\build .xml:128: The
following error occurred while executing this line:
H:\eclipse\workspace-BI\org.eclipse.birt.data\build.xml:87: Compile
failed; see the compiler error output for details.
Need help please...
Re: Build error [message #18605 is a reply to message #18591] Wed, 16 March 2005 04:04 Go to previous messageGo to next message
Ed,
Which version of JDK are you using in your build? Try with JDK 1.4.2.
Please also submit an entry in Bugzilla for this build issue. Thanks.
Linda
ed wrote:
> hi,
> compile.src:
> jar:
> H:eclipseworkspace-BIorg.eclipse.birt.datalib
> build:
> [mkdir] Created dir: H:eclipseworkspace-BIorg.eclipse.birt.databin
H:eclipseworkspace-BIorg.eclipse.birt.datatestdriversdrivers ForMapmappedDriver1odaconfig.xml;
> [javac] 1 error
> BUILD FAILED:
> H:eclipseworkspace-BIorg.eclipse.birt.report.viewerbuild.xml :128: The
> H:eclipseworkspace-BIorg.eclipse.birt.databuild.xml:87: Compile
> Need help please...
Re: Build error [message #18609 is a reply to message #18605] Wed, 16 March 2005 04:32 Go to previous messageGo to next message
You must use JDK 1.5.0. There are errors when building of
org.eclipse.birt.data with JDK 1.5.0.
Birt can be build with JDK 1.4.2.
The problem will be solved soonly
"Linda Chan" <lchan@actuate.com> wrote in message
news:d18sr2$uti$1@www.eclipse.org...
> Ed,
> Linda
> ed wrote:
>> hi,
>> compile.src:
>> jar:
>> build:
>> [javac] 1 error
>> BUILD FAILED:
>> H:eclipseworkspace-BIorg.eclipse.birt.databuild.xml:87: Compile failed;
>> Need help please...
Re: Build error [message #19948 is a reply to message #18591] Thu, 17 March 2005 08:43 Go to previous message
I got the same error when I tried to build it with jdk 5.0
But I could build it again(with jdk5.0) by checking out the
org.eclipse.birt.data separately.
Just check if you missed any files or jars..
-- Sridevi
ed wrote:
> hi,
> compile.src:
> jar:
> build:
> [javac] 1 error
> BUILD FAILED:
> Need help please...
Previous Topic:How to calculate value?
Next Topic:Oracle JDBC drivers
Current Time: Sat Jul 26 01:48:17 EDT 2025
Powered by FUDForum. Page generated in 0.08330 seconds
