Home » Eclipse Projects » JFace » [Esc]-, [Enter]- and Close functions for a Dialog class
[Esc]-, [Enter]- and Close functions for a Dialog class [message #18586] Fri, 03 July 2009 08:41 Go to next message
in a subclass of org.eclipse.jface.dialogs.Dialog I've 2 buttons MyButton1
and MyButton2.
I'd like that
- MyButton1 is triggered by pressing [Enter] and
- MyButton2 is triggered by pressing [Esc] or by clicking the X
[Close]-IconButton right above the dialog
besides their usual behaviour on mouse clicks.
How can this behaviour be implemented for the 2 buttons in Dialog?
And by the way:
Where can a find a comprehensive online description/manual for the features
and implementation of org.eclipse.jface.dialogs.Dialog?
Thomas Wiedmann
Re: [Esc]-, [Enter]- and Close functions for a Dialog class [message #18594 is a reply to message #18586] Mon, 06 July 2009 13:15 Go to previous messageGo to next message
Thomas Wiedmann wrote:
> Hello,
> MyButton1 and MyButton2.
> I'd like that
The [Enter] behaviour is the default button behaviour. There can be one
per dialog, and there is support code for it:
org.eclipse.jface.dialogs.Dialog.createButton(Composite, int, String,
boolean)
[Esc] is a window manager default that will close the shell. You get
the same behaviour by having your
org.eclipse.swt.events.ShellListener.shellClosed(ShellEvent) and your
button selection listener call the same method.
The documentation is mostly javadocs (also available from the help
link),
http://wiki.eclipse.org/JFaceSnippets#Snippet012DialogWithIm ageButtons
and
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/dialogs.htm
PW
Paul Webster
Re: [Esc]-, [Enter]- and Close functions for a Dialog class [message #19370 is a reply to message #18594] Wed, 08 July 2009 01:56 Go to previous messageGo to next message
"Paul Webster" <pwebster@ca.ibm.com> schrieb im Newsbeitrag
news:h2tbfv$7q9$1@build.eclipse.org...
>> Hello,
>> I'd like that
> [Esc] is a window manager default that will close the shell. You get the
The 2nd info concerning the [Esc] function I couldn't yet realize, because I
didn't understand it in detail.
How can a button, e. g. myButton2 as instance of
org.eclipse.swt.widgets.Button, be combined with the [Esc], that it's
action[s] are triggered after pressing [Esc]?
Furthermore the method
org.eclipse.swt.events.ShellListener.shellClosed(ShellEvent) was not
triggered when I pressed the x (Close) button right above the dialog.
I tried with:
System.out.println("### 1");
view.getShell().addShellListener(new ShellAdapter() {
public void shellClosed(ShellEvent ev) {
System.out.println("### 2");
view.getShell() really addressed the Shell.
I saw ### 1 in the output, but not ### 2 after clicking on X. What is
missing or wrong?
Thomas Wiedmann
Re: [Esc]-, [Enter]- and Close functions for a Dialog class [message #19462 is a reply to message #19370] Wed, 08 July 2009 08:27 Go to previous messageGo to next message
> I tried with:
> missing or wrong?
> Thomas Wiedmann
I think Paul meant attaching the listener to your dialog's shell, and
not your view. Something close to this:
myButton2.addSelectionListener(new SelectionAdapter()
public void widgetSelected(SelectionEvent e)
myMethod();
dialog.getShell().addShellListener(new ShellAdapter()
myMethod();
private void myMethod()
Hope this helps.
Pascal Gélinas | Software Developer
*Nu Echo Inc.*
http://www.nuecho.com/ | http://blog.nuecho.com/
*Because performance matters.*
Re: [Esc]-, [Enter]- and Close functions for a Dialog class [message #19597 is a reply to message #19462] Thu, 09 July 2009 03:05 Go to previous message
> @Override
> myMethod();
> @Override
> myMethod();
No, it didn't work for me. The method shellClosed(ShellEvent ev)
is not called, when I close the dialog. Is there any other listener
suitable for catching the event of closing a dialog?
Thomas Wiedmann
Previous Topic:Changing the expand and collapse icon for TreeViewer
Next Topic:How to implement a on-the-fly compiler?
Current Time: Fri Oct 24 15:52:59 EDT 2025
Powered by FUDForum. Page generated in 0.08203 seconds
