Wizards and disappearing controls pt 2 [message #194505] |
Thu, 15 February 2007 17:18 |
Originally posted by: jamarijr.gmail.com
Ok, I have tried many different things, but when I add this certain page
that I build to my wizard pages all the other pages lose their controls
(screen blank only description available).
Basically here is the code:
package whynot.wizards;
import org.eclipse.jface.viewers.ISelection;
import org.eclipse.jface.wizard.WizardPage;
import org.eclipse.swt.SWT;
import org.eclipse.swt.layout.*;
import org.eclipse.swt.widgets.*;
//import com.ibm.jpos.utils.WizComposite;
* @author Bobby Hargett
* TODO To change the template for this generated type comment go to
* Window - Preferences - Java - Code Generation - Code and Comments
public class DevSelPage extends WizardPage
ISelection selection;
//WizComposite wiz = null;
* Constructor for SampleNewWizardPage.
* @param pageName
public DevSelPage( ISelection selection )
super("wizardPage2");
setTitle("Add Devices manually");
setDescription("The devices selected here will have template code
generated for your application.");
this.selection = selection;
* (non-Javadoc)
* @see
org.eclipse.jface.dialogs.IDialogPage#createControl(org.ecli pse.swt.widgets.Composite)
public void createControl(Composite parent)
createSShell(parent);
public void setStartDevices( String[] devs )
//wiz.setInitDevices( devs );
* This method initializes sShell
private void createSShell(Composite parent)
Composite devicePanel = new Composite(parent, SWT.NULL);
GridLayout gl = new GridLayout(1,true);
gl.makeColumnsEqualWidth = false;
devicePanel.setLayout( gl );
GridData gld = new GridData(GridData.FILL, GridData.FILL, true,
true);
devicePanel.setLayoutData(gld);
//wiz = new WizComposite(devicePanel,SWT.NULL);
setControl(parent);
Help?
Re: Wizards and disappearing controls pt 2 [message #194511 is a reply to message #194505] |
Thu, 15 February 2007 17:45 |
Originally posted by: dmsubs.NOSPAM.consertum.com
I think it is your setControl(parent) that is the problem. It should be
setControl(devicePanel). I fell for that one too!
Derek
> * @param pageName
> * (non-Javadoc)
> * @see
> true);
> setControl(parent);
> Help?
Re: Wizards and disappearing controls pt 2 [message #194519 is a reply to message #194517] |
Thu, 15 February 2007 17:52 |
"zakir" <zakir.hussain@in.bosch.com> wrote in message
news:165aba3be16ca1f9ce22208f005c6893$1@www.eclipse.org...
> Inside the createControl... method of the wizard page...
> You need to create a new composite... xyz
> and then you need to pass the newly created composite xyz to your
> createShell method..
> and finally at the end of createControl method
> add a line setControl(composite xyz);
> The main reason for your problem is .. ... you should not
> add the setControl() to the composite which is coming from
> createControl() method
I know you feel like you are repeating yourself. But I thought I looked at
that part "Devils in the detail".
FUDForum. Page generated in 0.07980 seconds
