Home » Archived » BIRT » Build from CVS
Build from CVS [message #18513] Mon, 14 March 2005 17:13 Go to next message
Hello!
I try to rebuild the latest version from CVS as mentioned in
http://www.eclipse.org/birt/index.php?page=build/build_instr .html , but
unfortunately I'm unlucky.
I stuck at errors with draw2d:
BUILD FAILED: in org.eclipse.birt.report.viewer\build.xml:235: The
following error occurred while executing this line:
[javac] package org.eclipse.draw2d does not exist
[javac] import org.eclipse.draw2d.Figure;
I've check for draw2d plug-in. It lives at org.eclipse.draw2d_3.0.1 folder.
Can anybody clarify me the situation with it?
Re: Build from CVS [message #18524 is a reply to message #18513] Mon, 14 March 2005 17:23 Go to previous message
If you have installed a GEF version which is different from the version of
ECLIPSE that is installed, try setting the 'gef.version' property
(associated with the script) to the version of GEF that is installed.
e.g.
"eclipse.version" = "3.1.0"
"gef.version" = "3.0.1"
If that seems correct, open the draw2d.jar file using a ZIP file viewer
and ensure that it contains the class 'org.eclipse.draw2d.Figure'.
Hope that helps.
Rohit Colaco
ECE Project Lead
FoxyBOA wrote:
> Hello!
> BUILD FAILED: in org.eclipse.birt.report.viewerbuild.xml:235: The
Previous Topic:PropertyDefnFake in current CVS
Next Topic:Stable Build
Current Time: Tue Jul 22 17:50:00 EDT 2025
Powered by FUDForum. Page generated in 0.03948 seconds
