Home » Eclipse Projects » Eclipse Platform » FileEditorInput works only on IFile?
FileEditorInput works only on IFile? [message #18485] Sun, 27 April 2003 21:57 Go to next message
Originally posted by: karutla.hotmail.com
Hello All,
I am working on writing a plugin that requires me to edit a file that is
outside the workspace directory. I see that the editor extensions only work
with IFile interface, which I think represents a resource inside workspace
directory. So here are my questions.
Is there a way to create eclipse File Object
(org.eclipse.core.internal.resources.File) for a file that is outside the
workspace directory?
Is there a way to create a FileEditorInput
(org.eclipse.ui.part.FileEditorInput) which takes java.io.File Object?
I suggestions/directions would be greatly appreciated.
-Keerthi
Re: FileEditorInput works only on IFile? [message #18517 is a reply to message #18485] Mon, 28 April 2003 03:35 Go to previous messageGo to next message
sounds like this goes squarely against eclipses philosophy. The
"internal" package name already indicates you are treading on prohibited
ground.
My guess is you will have to create a temporary resource, and copy that
out to the external location.
Keerthi Arutla wrote:
> Hello All,
> Thanks
> -Keerthi
Re: FileEditorInput works only on IFile? [message #18557 is a reply to message #18485] Mon, 28 April 2003 06:09 Go to previous messageGo to next message
> Hello All,
> work
Eclipse APIs are targeted for resources that are inside the workspace.
> directory.
correct
no
no
write your own IStorageEditorInput implementation
HTH
Dani
Re: FileEditorInput works only on IFile? [message #20061 is a reply to message #18557] Mon, 28 April 2003 12:08 Go to previous message
Originally posted by: bob.objfac.com
"Daniel Megert" <daniel.megert@gmx.net> wrote in message
news:b8iuk5$gdp$2@rogue.oti.com...
the
> no
Well, actually, there is You can create a linked resource.
> no
Not as phrased, but file.createLink() will return an IFile, from which you
can create a FileEditorInput.
An excellent example of how to use this is in the filedrag plug-in. You can
download the plug-in and the source from
http://sourceforge.net/projects/sunshade. See FileDragPlugin.java.
Not sure why people are so in love with that solution (which, of course,
nobody ever gets around to implementing). In order to participate in
standard views like PackageExplorer, be searchable, etc. an object under
edit needs to be an IResource. The IStorageEditorInput way would get you an
open editor, period. Furthermore, IStorageEditorInput is not editable by
design. So you really need a subclass that extends it to allow editing. Then
you need a DocumentProvider that knows how to deal with the subclass. (And
subclassing FileDocumentProvider is no fun.) Even if I had the code to do
this, I wouldn't want to use it.
Bob
> HTH
> Dani
Previous Topic:display problem in WizardDialog
Next Topic:shared launch configuration
Current Time: Sun Aug 31 19:07:07 EDT 2025
Powered by FUDForum. Page generated in 0.59173 seconds
