Home » Archived » BIRT » ODA for search engine
ODA for search engine [message #18473] Mon, 14 March 2005 10:45 Go to next message
Originally posted by: torgeir.fast.no
I've fooled around with BIRT a bit and must say I'm very impressed so far!
So I started out to write a ODA plugin for our search engine to see if that
is possible. This is how far I've gotten:
- DataSource and DataSet wizards to configure the search engine connections
- ODA implementation for our search engine up to the point where I get:
a) All column-names available in the Data Explorer
b) Preview results in the "Edit Data Set" dialog
When I construct a report however I get an error message when trying to
preview the report:
Error Message
Semantic errors in
C:\eclipse\runtime-workspace\test\reports\baz.rptdesign.
The value of the property "keyExpr" is required.
Any help is greatly appreciated!
Torgeir,
Architect
Fast Search & Transfer, Inc. http://www.fastsearch.com/
Re: ODA for search engine [message #20587 is a reply to message #18473] Fri, 18 March 2005 10:12 Go to previous messageGo to next message
I've gotten a step further, it's unclear how, but I still don't get any data
the previewed reports. As far as I can see no query is ever executed
although the table is bound to the correct Data Set. For a JDBC Data Set
things work fine.
Any ideas? How can I best debug this? Is there any sequence diagrams or
simular available that shows the highlevel execution of report generation in
relation to the data sets / sources?
Torgeir
"Torgeir Hovden" <torgeir@fast.no> wrote in message
news:d14bjc$1kq$1@www.eclipse.org...
> that is possible. This is how far I've gotten:
> connections
> preview the report:
> Error Message
> Semantic errors in
> Torgeir,
> Architect
Re: ODA for search engine [message #20631 is a reply to message #20587] Sat, 19 March 2005 00:45 Go to previous messageGo to next message
Torgeir,
The development team is reworking the ODA interfaces. They'll be creating
Javadoc that should be the only documentation you need to create a custom
driver.
At present, the BIRT engine runs within your Eclipse process. To debug a
driver within BIRT, you'll have to launch a separate Eclipse instance for
the BIRT designer the same as if you were debugging an Eclipse plugin. Then,
preview your report (using the Preview tab) and execution should stop at
breakpoints within your driver. I've not tried this, but based on
discussions with the developers, it seems that this should work.
Once the updated ODA is available, perhaps someone in the community can
create a simple ODA unit test framework. It should be relatively easy to
test an ODA driver by itself without the complexity of debugging your driver
within the context of the overall BIRT engine.
- Paul
Paul Rogers
BIRT PMC
news:d1er5t$t2j$1@www.eclipse.org...
> data the previewed reports. As far as I can see no query is ever executed
> things work fine.
> in relation to the data sets / sources?
> Torgeir
>> far! So I started out to write a ODA plugin for our search engine to see
>> if that is possible. This is how far I've gotten:
>> connections
>> preview the report:
>> Error Message
>> Semantic errors in
>> Torgeir,
>> Architect
Re: ODA for search engine [message #25145 is a reply to message #20631] Wed, 06 April 2005 09:08 Go to previous messageGo to next message
Paul,
A driver test framework sounds great. I already debug within Eclipse, but
find it difficult since it seems like my driver is not called at all during
report preview (but works fine up to that point including data-set preview).
I've updated to the latest stable build and have the same issues.
Torgeir
"Paul Rogers" <progers@actuate.com> wrote in message
news:d1geak$645$1@www.eclipse.org...
> Torgeir,
> driver.
> Then, preview your report (using the Preview tab) and execution should
> stop at breakpoints within your driver. I've not tried this, but based on
> driver within the context of the overall BIRT engine.
> - Paul
> Paul Rogers
> BIRT PMC
>> things work fine.
>> Thanks,
>> Torgeir
>>> Hi,
>>> connections
>>> preview the report:
>>> Error Message
>>> Semantic errors in
>>> Torgeir,
>>> Architect
Re: ODA for search engine [message #25185 is a reply to message #25145] Wed, 06 April 2005 17:22 Go to previous messageGo to next message
This has bitten me as well and seems to be plugin classloader issue.
Preview works after adding database driver jar to boot class path.
Torgeir Hovden wrote:
>Paul,
>Torgeir
Re: ODA for search engine [message #25306 is a reply to message #25185] Thu, 07 April 2005 07:38 Go to previous messageGo to next message
Aleksander,
Thanks - that lead me on the right path. It seems that
org.eclipse.birt.report.viewer requires the drivers under it's directory
hierarchy - e.g.
C:\eclipse\plugins\org.eclipse.birt.report.viewer_0.0.1\birt -viewer\WEB-INF\plugins\drivers\.
Dropping it in there solved the problem!
This seems somewhat inconsistent with the designer, which works with the
plug-in directly. BIRT gurus: where should the driver reside? I don't like
duplicating the jars all over...
Torgeir
"Aleksander Bandelj" <aleksander.bandelj@academa.si> wrote in message
news:d31k8t$v7$1@news.eclipse.org...
>>Paul,
>>during report preview (but works fine up to that point including data-set
>>preview).
>>Torgeir
Re: ODA for search engine [message #25954 is a reply to message #25306] Tue, 12 April 2005 02:11 Go to previous message
Torgeir,
The solution today is to make multiple copies of the JDBC driver (or
configure ODA to find your driver in a single location, but you still must
make the ODA entry thee times.) The team is aware of this issue and is
looking into ways to resolve it before Release 1 next month.
- Paul
Paul Rogers
BIRT PMC
news:d336al$t2m$1@news.eclipse.org...
> Aleksander,
> hierarchy - e.g.
> Torgeir
>>>Paul,
>>>preview).
>>>Torgeir
Previous Topic:Still having issues with page number
Next Topic:Oracle Driver
Current Time: Tue Jul 22 12:02:25 EDT 2025
Powered by FUDForum. Page generated in 0.04345 seconds
