Home » Eclipse Projects » JFace » TreeViewer getItems
TreeViewer getItems [message #18468] Wed, 01 July 2009 07:09 Go to next message
Hi all,
I need programatically follow a tree from the root.
I'm using the getItems method but it returns TreeItem[0] when the node
isn't expanded.
How I can get the children even if the parent node is collapsed?
Thank you in advance.
Re: TreeViewer getItems [message #18490 is a reply to message #18468] Wed, 01 July 2009 07:41 Go to previous message
See my post from above. DO NOT operate on the Tree-Widget when you have
viewer.
TreeViewer is creating sub-trees lazily (you might findout that once you
expanded and collapsed you get sub-items).
You should walk through your Domain-Object Tree not the one presented in
the Viewer!
Tom
David Crecente schrieb:
> Hi all,
> isn't expanded.
Previous Topic:[DataBinding] master-detail binding with non-String properties
Next Topic:TableViewerFocusCellManager and Using Tabulator to Navigate
Current Time: Tue Jul 22 12:04:07 EDT 2025
Powered by FUDForum. Page generated in 0.03269 seconds
