Need help [message #193842] |
Tue, 13 February 2007 19:45 |
Originally posted by: Marta.Polanco.directenergy.com
How to enable Eclipse to use new installed JDK?
Re: Need help [message #193850 is a reply to message #193842] |
Tue, 13 February 2007 20:00 |
Originally posted by: csae7511.uibk.ac.at
Window --> Preferences --> Java --> Installed JREs
HTH,
Stefan
Re: Need help [message #193889 is a reply to message #193842] |
Tue, 13 February 2007 20:50 |
Originally posted by: eclipse5.rizzoweb.com
If you want to have Eclipse itself run in a particular JVM, you need to
specify it either on the command line or in a eclipse.ini file.
This question is asked/answered a lot so just search the newsgroup
archives and/or Google.
If you only want o run your programs from in Eclipse with a different
JDK/JVM, you can add it via Preferences > Java > Installed JREs
Hope this helps,
Eric
FUDForum. Page generated in 0.07938 seconds
