Problems with UI running Eclipse 3.0 M6 (GTK) on RHEL 3.0 Linux [message #193087] |
Thu, 12 February 2004 04:16  |
I'm running Eclipse 3.0 M6 x86/GTK 2 build on Red Hat EL 3.0, using the
IBM 1.4.1 SR1 Java SDK using the J9 JVM (-Xj9 option).
As I use Eclipse, I get messages in the Error Log which seem to relate
to the user interface. These messages arrive in pairs:
1) "Unhandled event loop exception"
2) "Widget is disposed"
Once these messages start to appear, the user interface quickly becomes
unusable and the only solution I have found is to close Eclipse and
start it again.
Does anyone know the cause of this problem and if there is a fix that I
can apply?
Thanks in advance,
Yours, Mike Edwards.
Re: Problems with UI running Eclipse 3.0 M6 (GTK) on RHEL 3.0 Linux [message #193562 is a reply to message #193087] |
Thu, 12 February 2004 16:02  |
Originally posted by: douglas.pollock.magma.ca
> can apply?
My advice would be to update to M7 (probably out today or tomorrow), and
see if the problem still occurs. M6 was a shaky build all-round, and --
though I haven't heard of your specific bug -- it wouldn't surprise me if
the problem you describe has been fixed.
If the problem is still happening for you in M7, please file a bug and
inclue the Exception traces as an attachment.
Doug.
FUDForum. Page generated in 0.06342 seconds
