Home » Archived » Visual Editor (VE) » is too complicated to be evaluated
is too complicated to be evaluated [message #18368] |
Wed, 11 February 2004 10:35  |
------=_NextPart_000_0166_01C3F0BD.0340A800
Content-Type: multipart/alternative;
boundary="----=_NextPart_001_0167_01C3F0BD.0340A800"
------=_NextPart_001_0167_01C3F0BD.0340A800
Content-Type: text/plain;
charset="iso-8859-1"
We have developed more then 2 thousand panels with VisualAge-VCE. Now we =
are going to use Visual Editor.
=20
Several subclassed Swing-Beans were extended with a String-Property =
(propertyName). This property is only set by constants. To set a =
String-Property with constants, we developed a corresponding =
Property-Editor (PropertryNameEditor).=20
The Source Code Patterns used by VE are well known. In our cases the =
constants can't be evaluated, the constants are defined in a separate =
interface (IDs).
Actually, there is no need to evaluate the constant it could be set =
directly like a quoted String.
Is there any solution for this case?
regards
peter
ps: The distinction between quoted String and a constant is done in =
class org.eclipse.jem.internal.proxy.remote.REMStringBeanTypeProxy =
method #newInstance(String).
Content-Type: text/html;
<HTML><HEAD>
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2800.1106" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff background=3D"">
<DIV><FONT face=3DArial size=3D2>We have developed more then 2 thousand =
panels with=20
VisualAge-VCE. Now we are going to use Visual Editor.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2> <BR>Several subclassed =
Swing-Beans were=20
extended with a String-Property (propertyName). This property is only =
set by=20
constants. To set a String-Property with constants, we developed a =
corresponding=20
Property-Editor (PropertryNameEditor). </FONT></DIV><FONT face=3DArial =
size=3D2>
<DIV><BR>The Source Code Patterns used by VE are well known. In our =
cases the=20
interface=20
(IDs).</DIV>
<DIV><BR>Actually, there is no need to evaluate the constant it could be =
set=20
directly like a quoted String.<BR></DIV>
<DIV>Is there any solution for this case?<BR></DIV>
<DIV>regards<BR>peter<BR></DIV>
<DIV>ps: The distinction between quoted String and a constant is done in =
class=20
org.eclipse.jem.internal.proxy.remote.REMStringBeanTypeProxy method=20
#newInstance(String).<BR></FONT></DIV></BODY></HTML>
------=_NextPart_001_0167_01C3F0BD.0340A800--
Content-Type: text/x-java;
name="TextFieldViewBeanInfo.java"
Content-Disposition: attachment;
filename="TextFieldViewBeanInfo.java"
* Created on 11.02.2004
* To change the template for this generated file go to
* Window>Preferences>Java>Code Generation>Code and Comments
package ch.suva.ve.test;
* @author pev
* To change the template for this generated type comment go to
public class TextFieldViewBeanInfo extends java.beans.SimpleBeanInfo {
* Find the method by comparing (name & parameter size) against the =
methods in the class.
* @return java.lang.reflect.Method
* @param aClass java.lang.Class
* @param methodName java.lang.String
* @param parameterCount int
public static java.lang.reflect.Method findMethod(java.lang.Class =
aClass, java.lang.String methodName, int parameterCount) {
try {
/* Since this method attempts to find a method by getting all methods =
from the class,
this method should only be called if getMethod cannot find the method. =
java.lang.reflect.Method methods[] =3D aClass.getMethods();
for (int index =3D 0; index < methods.length; index++){
java.lang.reflect.Method method =3D methods[index];
if ((method.getParameterTypes().length =3D=3D parameterCount) && =
(method.getName().equals(methodName))) {
return method;
} catch (java.lang.Throwable exception) {
return null;
return null;
* Returns the BeanInfo of the superclass of this bean to inherit its =
features.
* @return java.beans.BeanInfo[]
public java.beans.BeanInfo[] getAdditionalBeanInfo() {
java.lang.Class superClass;
java.beans.BeanInfo superBeanInfo =3D null;
try {
superClass =3D getBeanDescriptor().getBeanClass().getSuperclass();
return null;
try {
superBeanInfo =3D java.beans.Introspector.getBeanInfo(superClass);
} catch (java.beans.IntrospectionException ie) {}
if (superBeanInfo !=3D null) {
java.beans.BeanInfo[] ret =3D new java.beans.BeanInfo[1];
ret[0] =3D superBeanInfo;
return ret;
return null;
* Gets the bean class.
* @return java.lang.Class
public static java.lang.Class getBeanClass() {
return TextFieldView.class;
* Gets the bean class name.
* @return java.lang.String
public static java.lang.String getBeanClassName() {
return "ch.suva.ve.test.TextFieldView";
public java.beans.BeanDescriptor getBeanDescriptor() {
java.beans.BeanDescriptor aDescriptor =3D null;
try {
/* Create and return the TextFieldViewBeanInfo bean descriptor. */
aDescriptor =3D new =
java.beans.BeanDescriptor(ch.suva.ve.test.TextFieldView.clas s);
aDescriptor.setDisplayName("ch.suva.ve.test.TextFieldView");
aDescriptor.setShortDescription("ch.suva.ve.test.TextFieldView ");
/* aDescriptor.setExpert(false); */
/* aDescriptor.setHidden(false); */
/* aDescriptor.setValue("hidden-state", Boolean.FALSE); */
} catch (Throwable exception) {
return aDescriptor;
* Return the event set descriptors for this bean.
* @return java.beans.EventSetDescriptor[]
public java.beans.EventSetDescriptor[] getEventSetDescriptors() {
try {
java.beans.EventSetDescriptor aDescriptorList[] =3D {};
return aDescriptorList;
handleException(exception);
return null;
* Return the method descriptors for this bean.
* @return java.beans.MethodDescriptor[]
public java.beans.MethodDescriptor[] getMethodDescriptors() {
try {
java.beans.MethodDescriptor aDescriptorList[] =3D {
getPropertyNameMethodDescriptor()
,setPropertyName_javalangStringMethodDescriptor()
return null;
* Return the property descriptors for this bean.
* @return java.beans.PropertyDescriptor[]
public java.beans.PropertyDescriptor[] getPropertyDescriptors() {
try {
java.beans.PropertyDescriptor aDescriptorList[] =3D {
propertyNamePropertyDescriptor()
return null;
* Gets the getPropertyName() method descriptor.
public java.beans.MethodDescriptor getPropertyNameMethodDescriptor() {
java.beans.MethodDescriptor aDescriptor =3D null;
try {
/* Create and return the getPropertyName() method descriptor. */
java.lang.reflect.Method aMethod =3D null;
try {
/* Attempt to find the method using getMethod with parameter types. =
java.lang.Class aParameterTypes[] =3D {};
aMethod =3D getBeanClass().getMethod("getPropertyName", =
aParameterTypes);
/* Since getMethod failed, call findMethod. */
aMethod =3D findMethod(getBeanClass(), "getPropertyName", 0);
try {
/* Try creating the method descriptor with parameter descriptors. */
java.beans.ParameterDescriptor aParameterDescriptors[] =3D {};
aDescriptor =3D new java.beans.MethodDescriptor(aMethod, =
aParameterDescriptors);
/* Try creating the method descriptor without parameter descriptors. =
aDescriptor =3D new java.beans.MethodDescriptor(aMethod);
/* aDescriptor.setDisplayName("getPropertyName()"); */
/* aDescriptor.setShortDescription("getPropertyName()"); */
/* aDescriptor.setValue("preferred", new Boolean(false)); */
return aDescriptor;
* Called whenever the bean information class throws an exception.
* @param exception java.lang.Throwable
private void handleException(java.lang.Throwable exception) {
/* Uncomment the following lines to print uncaught exceptions to stdout =
// System.out.println("--------- UNCAUGHT EXCEPTION ---------");
// exception.printStackTrace(System.out);
* Gets the propertyName property descriptor.
public java.beans.PropertyDescriptor propertyNamePropertyDescriptor() {
java.beans.PropertyDescriptor aDescriptor =3D null;
try {
try {
/* Using methods via getMethod is the faster way to create the =
propertyName property descriptor. */
java.lang.reflect.Method aGetMethod =3D null;
try {
java.lang.Class aGetMethodParameterTypes[] =3D {};
aGetMethod =3D getBeanClass().getMethod("getPropertyName", =
aGetMethodParameterTypes);
aGetMethod =3D findMethod(getBeanClass(), "getPropertyName", 0);
java.lang.reflect.Method aSetMethod =3D null;
try {
java.lang.Class aSetMethodParameterTypes[] =3D {
java.lang.String.class
aSetMethod =3D getBeanClass().getMethod("setPropertyName", =
aSetMethodParameterTypes);
aSetMethod =3D findMethod(getBeanClass(), "setPropertyName", 1);
aDescriptor =3D new java.beans.PropertyDescriptor("propertyName"
, aGetMethod, aSetMethod);
/* Since we failed using methods, try creating a default property =
descriptor. */
, getBeanClass());
aDescriptor.setBound(true);
/* aDescriptor.setConstrained(false); */
aDescriptor.setPropertyEditorClass(java.lang.Class.forName("ch.suva.ve.te=
st.PropertyNameEditor"));
/* aDescriptor.setDisplayName("propertyName"); */
/* aDescriptor.setShortDescription("propertyName"); */
/* aDescriptor.setValue("ivjDesignTimeProperty", new Boolean(true)); =
return aDescriptor;
* Gets the setPropertyName(java.lang.String) method descriptor.
public java.beans.MethodDescriptor =
setPropertyName_javalangStringMethodDescriptor() {
try {
/* Create and return the setPropertyName(java.lang.String) method =
descriptor. */
try {
aMethod =3D getBeanClass().getMethod("setPropertyName", =
aParameterTypes);
aMethod =3D findMethod(getBeanClass(), "setPropertyName", 1);
try {
java.beans.ParameterDescriptor aParameterDescriptor1 =3D new =
java.beans.ParameterDescriptor();
aParameterDescriptor1.setName("arg1");
aParameterDescriptor1.setDisplayName("name");
/* aDescriptor.setDisplayName("setPropertyName(java.lang.String) "); */
aDescriptor.setShortDescription("setPropertyName(java.lang.String) "); */
return aDescriptor;
name="MyPanel.java"
filename="MyPanel.java"
import javax.swing.JPanel;
* @author pev
public class MyPanel extends JPanel implements IDs {
=09
protected TextFieldView ivjTextFieldView1 =3D null;
private TextFieldView getTextFieldView1() {
if (ivjTextFieldView1 =3D=3D null) {
try {
ivjTextFieldView1 =3D new TextFieldView();
ivjTextFieldView1.setName("TextFieldView1");
ivjTextFieldView1.setColumns(5);
ivjTextFieldView1.setPropertyName(CONST_2);
// user code begin {1}
// user code end
} catch (java.lang.Throwable ivjExc) {
// user code begin {2}
// user code end
handleException(ivjExc);
return ivjTextFieldView1;
private void initialize() {
try {
// user code end
setName("MyPanel");
setSize(572, 348);
java.awt.GridBagConstraints constraintsTextFieldView1 =3D new =
java.awt.GridBagConstraints();
constraintsTextFieldView1.gridx =3D 0;=20
constraintsTextFieldView1.gridy =3D 0;
constraintsTextFieldView1.anchor =3D =
java.awt.GridBagConstraints.WEST;
constraintsTextFieldView1.insets =3D new java.awt.Insets(4, 4, 4, =
4);
add(getTextFieldView1 (),constraintsTextFieldView1);
=09
}=20
// user code end
/* Uncomment the following lines to print uncaught exceptions to =
stdout */
=09
name="PropertyNameEditor.java"
filename="PropertyNameEditor.java"
* @author pev
public class PropertyNameEditor extends java.beans.PropertyEditorSupport =
=09
protected PropertyNameEditor() {
super();
protected PropertyNameEditor(Object source) {
super(source);
* Insert the method's description here.
* Creation date: (17.07.00 17:35:53)
public String getJavaInitializationString() {
try
if(getValue() !=3D null)
return (String)getValue();
catch (Exception e)
//e.printStackTrace();
//Falls das nicht moeglich ist
try
return getValue().toString();
catch (Exception e)
//Falls das auch nicht moeglich ist
return "";
* Sets the property value by parsing a given String. May raise
* java.lang.IllegalArgumentException if either the String is
* badly formatted or if this kind of property can't be expressed
* as text.
* @param text The string to be parsed.
public void setAsText(String text) throws =
java.lang.IllegalArgumentException {
if (text !=3D null && text instanceof String)=20
setValue(text);
else
setValue("");
}=09
name="TextFieldView.java"
filename="TextFieldView.java"
import javax.swing.JTextField;
* @author pev
public class TextFieldView extends JTextField {
protected String propertyName = null;
public void setPropertyName(String name) {
propertyName = name;
public String getPropertyName() {
return propertyName;
name="IDs.java"
filename="IDs.java"
* @author pev
public interface IDs {
public static final String CONST_1 = "const1";
public static final String CONST_2 = "const2";
------=_NextPart_000_0166_01C3F0BD.0340A800--
Re: is too complicated to be evaluated [message #18392 is a reply to message #18368] |
Wed, 11 February 2004 11:08   |
------------ PanelView -------------
protected TextFieldView ivjTextFieldView1 = null;
if (ivjTextFieldView1 == null) {
try {
ivjTextFieldView1 = new TextFieldView();
// user code end
// user code end
try {
// user code end
setName("MyPanel");
setSize(572, 348);
java.awt.GridBagConstraints constraintsTextFieldView1 = new
constraintsTextFieldView1.gridx = 0;
constraintsTextFieldView1.gridy = 0;
constraintsTextFieldView1.anchor = java.awt.GridBagConstraints.WEST;
constraintsTextFieldView1.insets = new java.awt.Insets(4, 4, 4, 4);
// user code end
------------ TextFieldView -------------
------------ IDs -------------
------------ PropertyNameEditor -------------
public class PropertyNameEditor extends java.beans.PropertyEditorSupport {
super();
super(source);
try {
if(getValue() != null) {
catch (Exception e) {}
try {
return "";
if (text != null && text instanceof String)
setValue(text);
else
setValue("");
------------ BeanInfo ----------------
public static java.lang.reflect.Method findMethod(java.lang.Class aClass,
try {
java.lang.reflect.Method methods[] = aClass.getMethods();
for (int index = 0; index < methods.length; index++){
java.lang.reflect.Method method = methods[index];
if ((method.getParameterTypes().length == parameterCount) &&
return method;
return null;
return null;
java.beans.BeanInfo superBeanInfo = null;
try {
superClass = getBeanDescriptor().getBeanClass().getSuperclass();
return null;
try {
superBeanInfo = java.beans.Introspector.getBeanInfo(superClass);
if (superBeanInfo != null) {
java.beans.BeanInfo[] ret = new java.beans.BeanInfo[1];
ret[0] = superBeanInfo;
return ret;
return null;
java.beans.BeanDescriptor aDescriptor = null;
try {
aDescriptor = new
return aDescriptor;
try {
java.beans.EventSetDescriptor aDescriptorList[] = {};
return null;
try {
java.beans.MethodDescriptor aDescriptorList[] = {
return null;
try {
java.beans.PropertyDescriptor aDescriptorList[] = {
return null;
java.beans.MethodDescriptor aDescriptor = null;
try {
java.lang.reflect.Method aMethod = null;
try {
/* Attempt to find the method using getMethod with parameter types. */
java.lang.Class aParameterTypes[] = {};
aMethod = getBeanClass().getMethod("getPropertyName", aParameterTypes);
aMethod = findMethod(getBeanClass(), "getPropertyName", 0);
try {
java.beans.ParameterDescriptor aParameterDescriptors[] = {};
aDescriptor = new java.beans.MethodDescriptor(aMethod,
/* Try creating the method descriptor without parameter descriptors. */
aDescriptor = new java.beans.MethodDescriptor(aMethod);
return aDescriptor;
java.beans.PropertyDescriptor aDescriptor = null;
try {
try {
java.lang.reflect.Method aGetMethod = null;
try {
java.lang.Class aGetMethodParameterTypes[] = {};
aGetMethod = getBeanClass().getMethod("getPropertyName",
aGetMethod = findMethod(getBeanClass(), "getPropertyName", 0);
java.lang.reflect.Method aSetMethod = null;
try {
java.lang.Class aSetMethodParameterTypes[] = {
aSetMethod = getBeanClass().getMethod("setPropertyName",
aSetMethod = findMethod(getBeanClass(), "setPropertyName", 1);
aDescriptor = new java.beans.PropertyDescriptor("propertyName"
descriptor. */
, getBeanClass());
aDescriptor.setPropertyEditorClass(java.lang.Class.forName("ch.suva.ve.test.PropertyNameEditor "));
/* aDescriptor.setValue("ivjDesignTimeProperty", new Boolean(true)); */
return aDescriptor;
try {
descriptor. */
try {
aMethod = getBeanClass().getMethod("setPropertyName", aParameterTypes);
aMethod = findMethod(getBeanClass(), "setPropertyName", 1);
try {
java.beans.ParameterDescriptor aParameterDescriptor1 = new
/* aDescriptor.setShortDescription("setPropertyName(java.lang.String) ");
return aDescriptor;
Re: is too complicated to be evaluated [message #18407 is a reply to message #18368] |
Wed, 11 February 2004 11:20  |
Originally posted by: richkulp.NO.SPAM.us.ibm.com
Just ignore the too complicated msg. It doesn't cause any problems. It
simply doesn't set the text in the image. It doesn't prevent the editor
from being used and changing anything else.
The next release will be able to handle the constant.
Thanks, Rich Kulp
Re: is too complicated to be evaluated [message #580744 is a reply to message #18368] |
try {
// user code end
// user code end
try {
// user code end
setName("MyPanel");
setSize(572, 348);
// user code end
super();
super(source);
try {
try {
return "";
setValue(text);
else
setValue("");
try {
return method;
return null;
return null;
try {
return null;
try {
return ret;
return null;
try {
aDescriptor = new
return aDescriptor;
try {
return null;
try {
return null;
try {
return null;
try {
try {
try {
return aDescriptor;
try {
try {
try {
try {
descriptor. */
, getBeanClass());
return aDescriptor;
try {
descriptor. */
try {
try {
return aDescriptor;
Re: is too complicated to be evaluated [message #580767 is a reply to message #18368] |
Thanks, Rich Kulp
Current Time: Sun Jul 27 22:57:55 EDT 2025
Powered by FUDForum. Page generated in 0.04691 seconds
