Home » Language IDEs » ServerTools (WTP) » Problem with FTP client
Problem with FTP client [message #18355] Fri, 05 March 2004 08:24 Go to next message
Originally posted by: mchojrin.yahoo.com
Hi:
I'm new to Eclipse, I'm developing a PHP application against a remote
Web Server.
The problem I have is I can not connect to the ftp server, though I can
connect using an external tool.
I'm using the ftp plugin, the error I get is something like "the
response message,0, was too short, it should be tree bytes long"
Any idea?
Re: Problem with FTP client [message #23770 is a reply to message #18355] Tue, 18 May 2004 13:05 Go to previous message
Originally posted by: tp.akitogo.com
Hi Mauro,
i just started with eclipse 3.0M8. The ftp/webdav plugin
(eclipse-FTP-WebDAV-3.0M7) didn't work with SDK 3.0M8. At the end i've tried
to use SDK 3.0M7 whith this plugin, and it works. maybe this information
helps you...
cu
Tomek
Previous Topic:JSTL 1.1 sql query tag problem
Next Topic:How to upload to FTP team Server with a shortcut?
Current Time: Sat Jul 26 07:39:53 EDT 2025
Powered by FUDForum. Page generated in 0.05664 seconds
