Home » Newcomers » Newcomers » Line Numbers Not Displaying
Line Numbers Not Displaying [message #18343] Thu, 27 January 2005 17:15 Go to next message
Originally posted by: chris.montgomery.lackland.af.mil
I have the option checked to show line numbers under Text Editors in
Preferences, however, the line numbers aren't displaying. Anyone else
having this problem? Is there a fix?
Running Eclipse Version: 3.1.0, Build id: 200412162000 on Windows 2000.
Re: Line Numbers Not Displaying [message #18360 is a reply to message #18343] Thu, 27 January 2005 17:19 Go to previous messageGo to next message
Which editor are the line numbers not showing in?
Darins
"Chris Montgomery" <chris.montgomery@lackland.af.mil> wrote in message
news:ctbp6m$rcc$1@www.eclipse.org...
Re: Line Numbers Not Displaying [message #18376 is a reply to message #18360] Thu, 27 January 2005 17:31 Go to previous messageGo to next message
> Darins
I dunno, I'm new to Eclipse. I guess it's the default editor. Are there
more?
Thanks.
Re: Line Numbers Not Displaying [message #18389 is a reply to message #18376] Thu, 27 January 2005 18:05 Go to previous messageGo to next message
news:ctbq3f$v02$1@www.eclipse.org...
> > Darins
> more?
> Thanks.
What type of file are you opening? Java source code? Ant buildfile, text
file etc
In Eclipse, editors are opened based on file content and/or file extension
as set in the Window>Preferences>General>File Assocations
I am not trying to be difficult :-) but in M4 the preferences were in a
state of flux (the specific editor settings were being replaced by general
editor settings for things like displaying line numbers). So we might have
introduced a bug (scanning the Eclipse bugzilla I could not find any current
report).
Knowing exactly what you are trying to open in an editor, I can reproduce
your problem (or not).
Darins
Re: Line Numbers Not Displaying [message #19646 is a reply to message #18389] Fri, 28 January 2005 09:47 Go to previous messageGo to next message
> file etc
> report).
Thanks for the comeback, Darins. Ok, I was opening .cfm (ColdFusion)
templates before. I just tried opening plain ascii text (.txt), .asp, and
htm files. Of those, the .txt and .asp files DO show line numbers, the
cfm and .htm DO NOT show line numbers.
Thanks again!
Re: Line Numbers Not Displaying [message #25159 is a reply to message #18389] Fri, 04 February 2005 13:12 Go to previous messageGo to next message
> ... in M4 the preferences were in a
> report).
Darin,
Has there been any resolution on how to fix this yet? Thanks.
Re: Line Numbers Not Displaying [message #25199 is a reply to message #25159] Fri, 04 February 2005 13:36 Go to previous messageGo to next message
My apologies...let this one slip.
If I remember you were opening files that I did not recognize the extensions
of.
(Can you remind me what the exensions where?)
Do the editors that these are opened within support line numbers?
Darins
news:cu0dth$sle$1@www.eclipse.org...
general
have
current
> > report).
reproduce
> Darin,
Re: Line Numbers Not Displaying [message #26426 is a reply to message #25199] Mon, 07 February 2005 17:25 Go to previous message
No problem.
> of.
Per my previous post (
http://www.eclipse.org/newsportal/article.php?id=234&gro up=eclipse.newcomer
), I was opening .cfm (ColdFusion) templates. I also tried opening plain
ascii text (.txt), .asp, and htm files. Of those, the .txt and .asp files
DO show line numbers, the cfm and .htm DO NOT show line numbers.
I suppose they do, I was using the default editor in Eclipse.
Thanks.
Previous Topic:Java newbie requesting advice
Next Topic:Writing to log
Current Time: Sun Aug 31 15:04:28 EDT 2025
Powered by FUDForum. Page generated in 0.09371 seconds
