Home » Language IDEs » C / C++ IDE (CDT) » Multiple Configurations for Makefile Projects
Multiple Configurations for Makefile Projects [message #192580] Tue, 05 June 2007 10:57 Go to next message
Is it possible with CDT 4.0 to have multiple build configurations for
"Makefile" projects. All I see is the "Default" configuration and I am
not seeing an obvious way to add another.
Background: I am using cmake to manage my makefiles and I have both a
Release and Debug Directories for building. Each Directory has its own
Makefile. So I was wondering if I can have 2 configurations in my
Makefile project, one that points make to Debug and one that points
Make to Release.
Thanks for any Help
Mike Jackson
Re: Multiple Configurations for Makefile Projects [message #192615 is a reply to message #192580] Tue, 05 June 2007 15:19 Go to previous messageGo to next message
> Makefile project, one that points make to Debug and one that points Make
> to Release.
> Thanks for any Help
> Mike Jackson
Why not just add more make targets? Open up the Make Target view and
create as many targets as you want?
Re: Multiple Configurations for Makefile Projects [message #192632 is a reply to message #192615] Tue, 05 June 2007 22:08 Go to previous messageGo to next message
>> Make to Release.
>> Thanks for any Help
>> Mike Jackson
CMake (www.cmake.org) actually generates the makefiles so adding
anything to the makefile will get destroyed the next time the makefiles
are generated.
Re: Multiple Configurations for Makefile Projects [message #192671 is a reply to message #192632] Wed, 06 June 2007 03:57 Go to previous message
>>> Make to Release.
> are generated.
Using CMake should not be a problem. I use autotools and started my
configure script with different options in different build directories:
$ mkdir debug && cd debug/ && ../configure CXXFLAGS="-g -O0"
After this I added my various Makefile targets to Make Target view and am
now able to call "make all" for both debug und release mode.
Jens
Previous Topic:extend cdt to support my compiler.
Next Topic:debugger: wont step thru during debug, only runs till end
Current Time: Sat Jul 26 08:25:38 EDT 2025
Powered by FUDForum. Page generated in 0.03639 seconds
