Home » Newcomers » Newcomers » unable to import javax.mail.* into java files in Eclipse
unable to import javax.mail.* into java files in Eclipse [message #192573] Wed, 07 February 2007 17:01 Go to next message
Originally posted by: satsuv.msn.com
I am using the latest version of Java (jdk1.6) and Eclipse. I also
downloaded JavaMail API and the jaf framework. I added both the mail.jar and
activation.jar to the CLASSPATH variable in Windows XP. I am able to run the
javamail sample programs from the command prompt. However, I get an error
message in Eclipse - import of any classes from the javamail api gives me an
error message. What could be the reason? Anyone else run into the same
problem?
Su
Re: unable to import javax.mail.* into java files in Eclipse [message #192581 is a reply to message #192573] Wed, 07 February 2007 17:14 Go to previous messageGo to next message
Originally posted by: wharley.bea.com
"Suvarna Damodaran" <satsuv@msn.com> wrote in message
news:eqdi8j$rp0$1@utils.eclipse.org...
> and activation.jar to the CLASSPATH variable in Windows XP. I am able to
> run the javamail sample programs from the command prompt. However, I get
> an error message in Eclipse - import of any classes from the javamail api
> gives me an error message. What could be the reason? Anyone else run into
> the same problem?
I think you might be confusing your compile classpath (that is, the "Java
Build Path") with the execution classpath.
But I'm not sure what you mean by "I get an error message in Eclipse -
import of any classes...". Can you be more specific? Do you mean that you
have a Java project within Eclipse, and you are trying to add an "import
javax.mail.*" line into a Java source file and getting a syntax error?
If that is the case, you probably need to add those .jar files into your
Java Build Path. Look in Project -> Properties -> Java Build Path.
Re: unable to import javax.mail.* into java files in Eclipse [message #192610 is a reply to message #192573] Wed, 07 February 2007 18:11 Go to previous messageGo to next message
Originally posted by: eclipse5.rizzoweb.com
Suvarna Damodaran wrote:
> problem?
Eclipse does not use the system variable CLASSPATH. Each Project in
Eclipse has its own build classpath. You'll need to import/copy the JARs
into your project and then add them to the project's build path.
This is all explained in detail in the Tutorials. Open the Eclipse Help
Contents and navigate to Java Development User Guide > Getting Started
and you'll see a couple of tutorials that teach you all the basics.
Hope this helps,
Eric
Re: unable to import javax.mail.* into java files in Eclipse [message #192626 is a reply to message #192573] Wed, 07 February 2007 22:33 Go to previous messageGo to next message
Hi Su,
One solution is to use the PDE wizard to create a plugin from existing
jar files (mail and jaf). Then make your project dependent on the new
plugin.
This technique works well for me.
Hope this helps.
Charlie
> problem?
> Su
Re: unable to import javax.mail.* into java files in Eclipse [message #192849 is a reply to message #192626] Thu, 08 February 2007 15:13 Go to previous message
Charle Kelly wrote:
> Hi Su,
> plugin.
While it works, that is not the most direct or simplest way to go about
it. Most Eclipse users don't know anything about the PDE or creating
plugins.
Far simpler is to import the JARs into the project. If the same set of
JARs are needed by multiple projects, you can either create a User
Library and add that to each project's dependency, or create a small
Java Project that contains the JARs, add them to its build path, and
then make other projects depend on that one.
Hope this helps,
Eric
Previous Topic:Frame Focus
Next Topic:What is the hot key to copy the whole line in Eclipse?
Current Time: Thu Jul 17 19:47:03 EDT 2025
Powered by FUDForum. Page generated in 0.27658 seconds
