Home » Eclipse Projects » Technology Project and PMC » CVS Setup error ....
CVS Setup error .... [message #18308] |
Fri, 23 August 2002 17:56  |
I am trying to setup a CVS location in Eclipse 2.0.
I am attempting to setup a CVS location on a network drive. The drive is a
mapped drive in Windows 2000 to the IFS on an AS400.
From a command line it works fine, but when I try to use the Eclipse
integration it gives me an error that I don't have authority to CVS/config.
I do have access and authority and it works from the command line but from
inside Eclipse is doesn't.
Any ideas?
Robert
Re: CVS Setup error .... [message #18341 is a reply to message #18324] |
Sat, 24 August 2002 13:40   |
Sorry about posting here, it seemed like the best place out of all the
eclipse.org newsgroups.
I am using a local pserver connection to a mapped network drive.
If I put the CVSROOT at C:\cvs, it works fine with eclipse .. ie. I know my
pserver is working for my local machine. So cvs and eclipse are both
working,
But if I use h:\cvsroot, h: is my network drive, cvs does work from a
command line, ie. I can set my cvs root and do a cvs init and it
initializes, I can checkout and commit from the command line fine. So cvsnt
allows me to work fine, I have all the authority I need.
Why does eclipse care that it is a mapped drive? Shouldn't it only matter
that pserver it setup correctly and that I have access to the repository?
Robert
"Stein M. Eliassen" <dulci@start.no> wrote in message
news:ak6cc9$dsv$1@rogue.oti.com...
> Robert Upshall wrote:
> > Hi,
> drive is a
> CVS/config.
> from
> > Any ideas?
> First off, eclipse.tools is the correct newsgroup for these types of
> questions. The the ng-names are a bit confusing, but hopefully something
> is done about it:
> http://bugs.eclipse.org/bugs/show_bug.cgi?id=19399
> Anyways, a mapped drive you say?
> That means you are trying to use 'local' connection-type wich are not
> supported by Eclipse, dunno if it's going be in the future either.
> Eclipse support pserver, ext and extssh for cvs connection-types.
> Can you connect to cvs on AS400 with any of these connection-types?
> Stein
Re: CVS Setup error .... [message #18375 is a reply to message #18341] |
Mon, 26 August 2002 10:23  |
Originally posted by: Michael_Valenta.oti.com
Robert,
Yes, Eclipse shouldn't care about where CVSNT puts it's repositories.
However, the Eclipse CVS client works a bit differently then the cvs
command line client. This will often expose bugs in CVSNT that do not
surface when used with the command line client. Please enter a bug
report in bugzilla to track this issue. Please include the error message
that occurs and anything that appears in the .metadata/.log file in your
workspace directory.
Michael
> working,
> Robert
>> > Hi,
>>drive is a
>>CVS/config.
>>from
>> > Any ideas?
>>is done about it:
>>Stein
Re: CVS Setup error .... [message #573590 is a reply to message #18308] |
Fri, 23 August 2002 18:27  |
drive is a
CVS/config.
from
> Any ideas?
is done about it:
Stein
Re: CVS Setup error .... [message #573597 is a reply to message #18324] |
working,
Robert
> > Hi,
> drive is a
> CVS/config.
> from
> > Any ideas?
> is done about it:
> Stein
Re: CVS Setup error .... [message #573685 is a reply to message #18341] |
Robert,
Michael
> working,
> Robert
>> > Hi,
>>drive is a
>>CVS/config.
>>from
>> > Any ideas?
>>is done about it:
>>Stein
Current Time: Thu Jul 17 00:35:25 EDT 2025
Powered by FUDForum. Page generated in 0.07648 seconds
