Home » Eclipse Projects » Eclipse Platform » RCP - Trouble getting feature information
RCP - Trouble getting feature information [message #192187] Tue, 10 February 2004 15:23 Go to next message
Originally posted by: IanPLang.yahoo.com
I have a simple app (based on the RCP articles originally posted at
http://www.eclipsepowered.org/rcp.html) which I am slowly building up. I
am working on the about box at the moment. What I want to do is something
similar to the way the Eclipse IDE does it (but less involved). I want to
get information about the installed features and use their branding
information to display a dialog box. After reading the code used in
Eclipse's about box I started with the code below.
My problem is I have two plug-ins and two features at the moment but only
the primary one shows up in the collection from
IPlatformConfiguration.getConfiguredFeatureEntries – see code below. In
fact I get different results depending on how I run it. If I run from the
command line in my install directory I get this (outside dev environment):
AboutAction run found primary feature ID: com.lesliesoftware.lphoto
Feature ID: com.lesliesoftware.lphoto
Version ID: null
Plug-in ID: com.lesliesoftware.lphoto
If I run from inside Eclipse with the target platform pointing to the
install image I get this:
Version ID: 0.1.0
So I have two questions: Why is only one of my features showing up? And
why is the version ID missing when I run outside the debugger?
IL
---8<---
IPlatformConfiguration conf =
BootLoader.getCurrentPlatformConfiguration();
// Primary feature
String featureId = conf.getPrimaryFeatureIdentifier();
ILog log = Platform.getPlugin(PlatformUI.PLUGIN_ID).getLog();
log.log (new Status (IStatus.INFO, PlatformUI.PLUGIN_ID, 0,
"AboutAction run found primary feature ID: " + featureId, null));
//$NON-NLS-1$
System.out.println ("AboutAction run found primary feature ID: " +
featureId); //$NON-NLS-1$
// All features
IPlatformConfiguration.IFeatureEntry[] entries =
conf.getConfiguredFeatureEntries();
for (int i = 0; i < entries.length; i++) {
featureId = entries[i].getFeatureIdentifier();
String versionId = entries[i].getFeatureVersion();
String pluginId = entries[i].getFeaturePluginIdentifier();
log.log (new Status (IStatus.INFO, PlatformUI.PLUGIN_ID, 0, "
Feature ID: " + featureId, null)); //$NON-NLS-1$
System.out.println (" Feature ID: " + featureId); //$NON-NLS-1$
Version ID: " + versionId, null)); //$NON-NLS-1$
System.out.println (" Version ID: " + versionId); //$NON-NLS-1$
Plug-in ID: " + pluginId, null)); //$NON-NLS-1$
System.out.println (" Plug-in ID: " + pluginId); //$NON-NLS-1$
---8<---
Re: RCP - Trouble getting feature information [message #192206 is a reply to message #192187] Tue, 10 February 2004 16:02 Go to previous messageGo to next message
Originally posted by: manahan.NOSPAM.ca.ibm.com
This is working as far as I can tell in an rcp app.
private void loadFeatureData() {
try {
ILocalSite ls = SiteManager.getLocalSite();
IConfiguredSite[] cs = ls.getCurrentConfiguration()
.getConfiguredSites();
for (int i = 0; i < cs.length; i++) {
IConfiguredSite site = cs[i];
IFeatureReference[] fr = site.getConfiguredFeatures();
for (int j = 0; j < fr.length; j++) {
IFeatureReference ref = fr[j];
IFeature f = ref.getFeature(null);
System.out.println(
f.getVersionedIdentifier().getIdentifier() +
f.getVersionedIdentifier().getVersion().toString());
Peter
> IPlatformConfiguration.getConfiguredFeatureEntries ? see code below. In
> Version ID: null
> Version ID: 0.1.0
> IL
> ---8<---
> // Primary feature
> //$NON-NLS-1$
> // All features
> ---8<---
Re: RCP - Trouble getting feature information [message #192312 is a reply to message #192206] Tue, 10 February 2004 22:33 Go to previous messageGo to next message
Originally posted by: jeff_mcaffer_REMOVE.ca.ibm.com
Just so you know, there is work going on in this area to remove the direct
dependency on features. I believe this is scheduled for M8. See IProduct,
IBundleGroup, IBundleGroupProvider and associated methods on Platform to get
an idea of what is coming. The About dialog will be reimplemented in terms
of these classes.
Jeff
"Peter Manahan" <manahan@NOSPAM.ca.ibm.com> wrote in message
news:c0bh2m$dql$1@eclipse.org...
> try {
> System.out.println(
> Peter
I
something
to
only
the
environment):
> > Version ID: null
> > Version ID: 0.1.0
And
> > IL
> > ---8<---
> > // Primary feature
> > //$NON-NLS-1$
> > // All features
> > ---8<---
Re: RCP - Trouble getting feature information [message #192582 is a reply to message #192187] Wed, 11 February 2004 09:52 Go to previous messageGo to next message
I solved my own problem with a little help from Jeff's answer to my splash
screen problem
< http://www.eclipse.org/newsportal/article.php?id=13981&g roup=eclipse.platform>.
After some experimentation trying to solve the splash screen I noticed a
log entry that indicated eclipse could not find
org.eclipse.update.core.<class I forget>. So I added two more plug-ins
org.eclipse.update.core_3.0.0 and org.eclipse.update.core.win32_3.0.0.
Now I get both my features when I run outside the debug environment - I
still only get the primary feature when running under the debugger. Any
ideas why that would be?
Ian
Re: RCP - Trouble getting feature information [message #192590 is a reply to message #192187] Wed, 11 February 2004 09:53 Go to previous messageGo to next message
screen problem
Ian
Re: RCP - Trouble getting feature information [message #192697 is a reply to message #192312] Wed, 11 February 2004 12:38 Go to previous messageGo to next message
Are you saying that in M8 RCP apps will be able to use the normal about
box directly?
IL
> of these classes.
<snip>
Re: RCP - Trouble getting feature information [message #192967 is a reply to message #192697] Wed, 11 February 2004 21:41 Go to previous messageGo to next message
I actually don't know if the About dialog is in the RCP layer or part of the
IDE layer. Good question for the UI team.
Jeff
"Ian Lang" <IanPLang@yahoo.com> wrote in message
news:c0dpba$23d$1@eclipse.org...
> box directly?
> IL
direct
IProduct,
get
terms
> > of these classes.
> <snip>
Re: RCP - Trouble getting feature information [message #193022 is a reply to message #192967] Wed, 11 February 2004 23:13 Go to previous messageGo to next message
I can say that in M6 it is definitely in the IDE layer. I took a shot at
using it in my RCP app and did not have to read much code to realize that
was not going to happen. Where can I find out about plans for about box
changes?
IL
> Jeff
> > box directly?
> > IL
Re: RCP - Trouble getting feature information [message #193297 is a reply to message #192206] Thu, 12 February 2004 09:45 Go to previous messageGo to next message
I am unable to get your code to work. Both IConfiguredSite and ILocalSite
cannot be found. I cannot find them in the 30 platform API documentation.
And when I search through the 30 source I find they referenced in
AboutFeaturesDialog and SystemSummaryDialog. Where are those two?
IL
> try {
> System.out.println(
> Peter
Problem solved [message #193313 is a reply to message #192590] Thu, 12 February 2004 09:51 Go to previous messageGo to next message
I have tried recreating the runtime workspace to no avail. I also noticed
that the .config directory is not under the workspace for 30 any more. So
when running from the commandline there is a .config and a workspace
directory and all is well. When running from the debugger there is only a
workspace - even if I set things up so they both use the same workspace it
does not work.
So I looked at the command line argument documentation and found
-configuration which let me point to the working .config directory and now
I see the right set of festures under the debugger. In fact previously
the primary feature was only being found because I was using the -feature
option.
IL
> screen problem
> Ian
Re: RCP - Trouble getting feature information [message #193460 is a reply to message #193297] Thu, 12 February 2004 13:05 Go to previous messageGo to next message
They are in org.eclipse.update.core. If you are using features and want
to update them via the update manager function you'll need that. If you
don't care and just want the branding, then the work Jeff mentioned
about the IProduct etc in Platform is probably the correct direction to
head. RCP applications may not be using features so there needs to be
another way to brand which is feature neutral.
Peter
> IL
>> try {
>> System.out.println(
>>Peter
Re: RCP - Trouble getting feature information [message #193934 is a reply to message #193460] Fri, 13 February 2004 08:59 Go to previous message
Thanks, Peter.
Funny I still do not see them in the API docs but I added a dependency and
every thing is good.
IL
> Peter
Previous Topic:Bringing the Menubar down the Shell
Next Topic:multiple editor partitioning in 3.0
Current Time: Sun Jul 27 11:08:47 EDT 2025
Powered by FUDForum. Page generated in 0.06437 seconds
