Home » Language IDEs » Java Development Tools (JDT) » JDT automatic source annotation *date format*
JDT automatic source annotation *date format* [message #192102] Sun, 09 January 2005 18:58 Go to next message
Originally posted by: natgross.rentalsystems.verizon.net
Hi;
On a WinXP platform, with Eclipse 3.0.1, although I have my Regional
settings set to US, the automatic ${date} that gets inserted in my code
is European format.
I have searched thru the preferences and failed to find where I can
adjust this to get the US format.
Please advise;
Thank you;
-nat
Re: JDT automatic source annotation *date format* [message #192185 is a reply to message #192102] Mon, 10 January 2005 12:33 Go to previous messageGo to next message
Nat Gross wrote:
> Hi;
> is European format.
You mean the ${date} in the default file template? It is the output of
return DateFormat.getDateInstance().format(new java.util.Date());
so I assume you have set your locale to european style somewhere.
-tom
Re: JDT automatic source annotation *date format* [message #192200 is a reply to message #192185] Mon, 10 January 2005 14:01 Go to previous messageGo to next message
Tom Eicher wrote:
> Nat Gross wrote:
>> Hi;
>> code is European format.
Yes.
>It is the output of
Hey. Never noticed that since I use a per-locale formatter in my code.
You are correct though, that this line of code returns European style
for me.
It's the million dollar question. Where? My XP Region is set to US.
I might have to resort to start Eclipse with a jvm parameter to set
locale, but hesitate to do so, because portions of my code is locale
specific, and I don't want the jvm parameter to 'confuse' the code.
Hopefully this fear is unfounded, and since I do not know what's causing
the Euro style date (maybe a hangover of a Windozzz crash), I should
just set the Eclipse's startup jvm's locale?
> -tom
Thank you much;
-nat
Re: JDT automatic source annotation *date format* [message #192243 is a reply to message #192200] Tue, 11 January 2005 05:57 Go to previous messageGo to next message
Originally posted by: zoopy.hates.spam.biz
On 10-1-2005 20:01, Nat Gross wrote:
> Tom Eicher wrote:
>> Nat Gross wrote:
>>> Hi;
> Yes.
>> It is the output of return DateFormat.getDateInstance().format(new
>> java.util.Date());
> for me.
>> -tom
> Thank you much;
> -nat
You can use the '-nl' parameter to the Eclipse executable. See
Help/Workbench User Guide/Tasks/Running Eclipse. E.g. with the Dutch
locale nl_NL:
"C:\Program Files\Eclipse\eclipse.3.0.1\eclipse\eclipse.exe" -nl nl_NL
-vm "C:\Program Files\Java\j2re1.4.2\bin\javaw.exe" -vmargs -Xmx192m
This produced the following date comment in a newly created class:
* <code>DateLocaleTest</code>
* @author SmithZ
* @created 11-jan-2005
Using '-nl en_US', it produced:
* <code>DateLocaleTest2</code>
* @author SmithZ
* @created Jan 11, 2005
In 'Help/About Eclipse Platform/Configuration details' you can verify
the locale used by the JVM. Even with the parameter '-nl nl_NL' I see
user.country=US
user.language=en
but also
osgi.nl=nl_NL
HTH,
Z.
Re: JDT automatic source annotation *date format* [message #192258 is a reply to message #192243] Tue, 11 January 2005 10:00 Go to previous message
>> Tom Eicher wrote:
>>> Nat Gross wrote:
>>>> Hi;
>> Yes.
>>> java.util.Date());
>> for me.
>> causing the Euro style date (maybe a hangover of a Windozzz crash), I
>> should just set the Eclipse's startup jvm's locale?
>>> -tom
>> Thank you much;
>> -nat
> locale nl_NL:
> * @author SmithZ
> * @author SmithZ
> user.country=US
> user.language=en
> but also
> osgi.nl=nl_NL
> HTH,
The -nl did the trick. However, my concern is that strings within my
sources that are *not* en_US, should not become confused.
I would much rather prefer a simple setting in preferences for the date
format of dates inserted in my source.
Also, a little peculiar thing. Before I set it to en_US, the date was
Euro format, but with numbers (Jan 10 was 10/1/2005), now it is indeed
set to US, but not numbers, rather Jan 10, 2005 string. Just wondering...
Thanks;
-nat
Previous Topic:ant build v Eclipse build mismatch
Next Topic:Looking for system memory requirements
Current Time: Sun Aug 31 04:36:23 EDT 2025
Powered by FUDForum. Page generated in 0.03680 seconds
