Home » Modeling » GMF (Graphical Modeling Framework) » outline view problem in gmf
outline view problem in gmf [message #191433] Fri, 06 June 2008 11:31
Hello Everyone,
I am using Eclipse 3.3 and i am using gmf, I want to
customize outline view, When i insert a widget in graphics editor, In
outline view, a tree item is added but it doesn't show anything (means no
image and text),
How can i put the widget thumb nail in that tree item,
Another problem is when i select a Tree Item in outline view and press the
delete key the error dialog is open and nothing is deleted, What i want is
when i select a Tree Item and press the delete key the tree item and
corresponding widget will removed from the the diagram editors.
How can i achieve this, Give me proper suggestion.
Thanks in advance.
Previous Topic:Mindmap tutorial, step 2: problem with FeatureSeqInitializer
Next Topic:Create a link between a Node and another Link
Current Time: Tue Jul 08 05:23:11 EDT 2025
Powered by FUDForum. Page generated in 0.03215 seconds
