Home » Archived » BIRT » Parameter Validation using validate() Javascript function
Parameter Validation using validate() Javascript function [message #191412] Thu, 21 September 2006 11:33 Go to next message
Greetings,
I have a requirement to validate input report parameters. I noticed
that each report parameter in BIRT has a validate() method associated
with it to do custom validation. Unfortunately I have not gotten this
to work. The Scripting spec says that the validate method will get
called before the report beings to be rendered, however based on my
experience I have never seen this occur in BIRT 2.1.
My question is what do I need to do to get the Javascript validate
method for each BIRT parameter to be executed? If anyone has a simple
example that would be muchly appreciated.
Thanks in advance.
Re: Parameter Validation using validate() Javascript function [message #191487 is a reply to message #191412] Thu, 21 September 2006 17:43 Go to previous message
This particular feature is not in BIRT yet. It has been logged as an
enhancement request.
See bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=132883
Jason
"Peter Maly" <user@domain.invalid> wrote in message
news:eeubek$h2a$1@utils.eclipse.org...
> Greetings,
> that each report parameter in BIRT has a validate() method associated with
> it to do custom validation. Unfortunately I have not gotten this to work.
> The Scripting spec says that the validate method will get called before
> the report beings to be rendered, however based on my experience I have
> Thanks in advance.
Previous Topic:Birt 2.2 branch in CVS?
Next Topic:BIRT build error
Current Time: Thu Oct 30 03:46:16 EDT 2025
Powered by FUDForum. Page generated in 0.02921 seconds
