Home » Newcomers » Newcomers » Code Headers
Code Headers [message #191400] Thu, 01 February 2007 09:02 Go to next message
Originally posted by: erick.p.heberling.lmco.com
I'm trying to set up a code comment header that my team can use throughout
our projects through Rational Clearcase. The catch is that it this must
be generated as the first line of the source file, prior to package
declaration and import statements. I've tried using the Eclipse built in
file comment, but then whenever I package the source file, the package
shows before the header. Is there anything I can do get the header before
the package declarations?
Thank you,
Re: Code Headers [message #191424 is a reply to message #191400] Thu, 01 February 2007 09:15 Go to previous messageGo to next message
Originally posted by: csae7511.uibk.ac.at
See:
Window --> Preferences --> Java --> Code Style --> Code Templates.
Select "New Java files" from "Code".
Here it should be possible to enter your header.
Hope that helps,
Stefan
> throughout our projects through Rational Clearcase. The catch is that
> it this must be generated as the first line of the source file, prior to
> package declaration and import statements. I've tried using the Eclipse
> built in file comment, but then whenever I package the source file, the
> package shows before the header. Is there anything I can do get the
> header before the package declarations?
> Thank you,
Re: Code Headers [message #191478 is a reply to message #191424] Thu, 01 February 2007 14:45 Go to previous messageGo to next message
Stefan,
Thank you for your answer.
I am able to generate a header, however I have some very specific rules to
follow about the header being set before the package declarations.
When I try to set this through the preferences it places the package prior
to the header.
Re: Code Headers [message #191495 is a reply to message #191478] Thu, 01 February 2007 15:41 Go to previous message
Hmm ... strange - I tried following template for "New Java files":
/*preheader*/
${filecomment}
${package_declaration}
${typecomment}
${type_declaration}
Results to following java file:
/*preheader*/
package core;
import java.util.List;
public class Test
Wasn't this you wanted to have or did I misunderstand you?
Stefan
Erick schrieb:
> Stefan,
> to follow about the header being set before the package declarations.
> prior to the header.
Previous Topic:Souce not found -- I had source -- now I don't...
Next Topic:Eclipse Classpath default packages
Current Time: Wed Jul 23 11:17:45 EDT 2025
Powered by FUDForum. Page generated in 0.12304 seconds
