Home » Eclipse Projects » GEF » copy & paste in GEF
copy & paste in GEF [message #18158] Tue, 27 August 2002 13:17 Go to next message
Is copy & paste supported in GEF? How should I register the actions to
the registry if the CopyAction and PasteAction aren't provided in
com.ibm.etools.gef.ui.actions package?
Thanks.
Shelley
Re: copy & paste in GEF [message #18176 is a reply to message #18158] Tue, 27 August 2002 13:32 Go to previous messageGo to next message
Originally posted by: hudsonr.spam.com
The registry is just a Map for actions. You can put anything in it. The
purpose of the registry is to manage disposing of Actions, which must be
done to avoid memory leaks. And by sharing this registry with other parts
of your Editor, you only have to do the dispose in one place.
Cut/Copy/Paste are global actions. You ActionBarContributor must register
them with the workbench in the same way that GEF's ActionBarContirbutor
register's Undo/Redo. GEF does not provide C/C/P support because this is
model specific.
"Shelley" <lshelley@ca.ibm.com> wrote in message
news:akgc6r$jkb$1@rogue.oti.com...
> Thanks.
> Shelley
Re: copy & paste in GEF [message #18213 is a reply to message #18176] Tue, 27 August 2002 13:53 Go to previous messageGo to next message
Originally posted by: lshelley.ibm.com
Thanks. Any help on implementating generic Copy and Paste action classes.
Can I refer to the CopyAction class in org.eclipse.ui.views.navigator?
Or could you suggest some sample code?
Thanks.
Shelley
> them with the workbench in the same way that GEF\\\\\\\'s
> register\\\\\\\'s Undo/Redo. GEF does not provide C/C/P support because
this is
> model specific.
> \\\\\\\"Shelley\\\\\\\" <lshelley@ca.ibm.com> wrote in message
> > Hi,
> > the registry if the CopyAction and PasteAction aren\\\\\\\'t provided in
> > Thanks.
> > Shelley
Re: copy & paste in GEF [message #18420 is a reply to message #18176] Thu, 29 August 2002 10:32 Go to previous messageGo to next message
Originally posted by: Bram.Stieperaere.REMOVEskynet.be
another copy-paste question: lots of diagramming tools (like Rose) support
copy/paste of the current selection in a diagram into the Clipboard of
Windows (so it can be pasted in Word)
Is this technically possible? How would a solution look like?
Bram
Re: copy & paste in GEF [message #229750 is a reply to message #18420] Wed, 24 January 2007 10:21 Go to previous message
Originally posted by: hryd.wanadoo.es
Goodmorning!
Paste in GEF ? example
Previous Topic:How to update connections to sub-figures?
Next Topic:Why nobody cares about Cut, Copy and Paste ?
Current Time: Sun Jul 27 08:34:02 EDT 2025
Powered by FUDForum. Page generated in 0.04373 seconds
