Re: Converting Plugin project into an ordinary java project [message #191353 is a reply to message #191278] |
Thu, 01 February 2007 13:37 |
--------------030105000207040502040202
Hussain,
I don't think there is any tool support for removing the plugin nature
or other PDE dependencies from the .project file:
<projectDescription>
<name>library</name>
<comment></comment>
<projects>
</projects>
<buildSpec>
<buildCommand>
<name>org.eclipse.jdt.core.javabuilder</name>
<arguments>
</arguments>
</buildCommand>
* <buildCommand>
<name>org.eclipse.pde.ManifestBuilder</name>
<arguments>
</arguments>
</buildCommand>
<buildCommand>
<name>org.eclipse.pde.SchemaBuilder</name>
<arguments>
</arguments>
</buildCommand>*
</buildSpec>
<natures>
<nature>org.eclipse.jdt.core.javanature</nature>
* <nature>org.eclipse.pde.PluginNature</nature>*
</natures>
</projectDescription>
I also don't understand why getting rid of the plugin support would be a
good thing. The jar generated from an EMF plugin will work perfectly
fine as a classpath entry for a standalone application so the PDE
support is just a convenience for managing dependencies between projects
in a simple way. For example, you'll notice that the generated
XyzExample.java in the generated *.tests project can be run simply as a
Java application...
Hussain wrote:
> Hi Friends,
> I wanted to convert the plugin project as an ordinary java project ,
> is there any possibility to convert it.
> Actually we have used EMF for creating our model and we had some other
> plugins.
> Right now we are asked to work with out creating plugins and use the
> ordinary java projects.
> If any one of you know the solution plz post it to me ..
> Hussain
<html>
<head>
http-equiv="Content-Type">
</head>
Hussain,<br>
<br>
or other PDE dependencies from the .project file:<br>
<blockquote><small><?xml version="1.0" encoding="UTF-8"?></small><br>
<small><projectDescription></small><br>
<small>
FUDForum. Page generated in 0.07744 seconds
