Ruby dynamically added methods and some static typing [message #18131] |
Sun, 18 November 2007 05:58 |
Originally posted by: martin.thiede.gmx.de
currently I am working on a modelling framework for Ruby called RGen
(see Rubyforge if you like), somewhat similar to EMF.
This involves building Ruby classes by means of some kind of Domain
Specific Language. Commands like "has_attr" or "has_one" add setter and
getter methods to the respective class which also ensure that only
values of a certain type can be set:
class Person < RGen::MetamodelBuilder::MMBase
has_attr 'name', String
has_attr 'age', Integer
end
class House < RGen::MetamodelBuilder::MMBase
has_attr 'address', String
end
Person.has_one 'home', House
p = Person.new
p.name = "Martin"
p.name = 5 # this would raise an exception since 5 is not a String
p.home = House.new(:address => "Some street")
p.home = Person.new # this would also raise an exception
It would be really great if DLTK could do two things:
1. show the dynamically added methods for auto completion.
p.<ctrl shift> should provide "name" and "age"
2. derive the result type of an accessor method
p.home.<ctrl shift> should provide "address"
(i.e. DLTK should know that "home" always returns a House)
Regarding 1:
Is there a chance to see dynamically added methods as completion options?
Currently I create the methods using "module_eval", something like:
def self.has_attr(name)
module_eval <<- END
def #{name}
end
END
end
Regarding 2:
One could define a generic way of giving hints to DLTK regarding method
result types. For example DLTK could check if the method "result_type"
is provided by the object in question. If yes, it could call the method
with the name of the method in question as parameter.
p.result_type(:home) # => House
This way DLTK could derive the result type of method "home" on a Person
object.
Is it technically possible to extend DLTK to enable stuff like this?
If it is and you could give me some hints how to do it I might try to do
so by myself.
Best Regards,
Martin
FUDForum. Page generated in 0.03373 seconds
