Version control in Eclipse? [message #190889] |
Tue, 30 January 2007 20:14 |
Originally posted by: www.nospam.net
I have heard that Eclipse can do version control. Our company use
Subversion now. But since only two people including me are working here
and our Java files are related. I am wondering if Eclipse has some
internal handy version control tools, so we don't need to bother
Subversion.
We all program Java in Eclipse. If the version control tool in Eclipse
is sufficient for two of us, we may not need to bother to use Subversion.
Thank you.
Re: Version control in Eclipse? [message #190897 is a reply to message #190889] |
Tue, 30 January 2007 20:19 |
Eclipse comes with built-in CVS integration so I think that's the only
directly available alternative...
www wrote:
> here and our Java files are related. I am wondering if Eclipse has
> some internal handy version control tools, so we don't need to bother
> Subversion.
> Thank you.
Re: Version control in Eclipse? [message #191001 is a reply to message #190889] |
Wed, 31 January 2007 13:39 |
Originally posted by: nugaee.SPAMtlen.pl
www wrote:
> Subversion.
> Thank you.
there are two plugins that enables svn support in eclipse : subclipse
and subversive. subversive can be used even on file:// protocol, so i
think it's good solution if you don't want to use yours company server.
bartek michalik
Re: Version control in Eclipse? [message #191021 is a reply to message #190889] |
Wed, 31 January 2007 14:08 |
Originally posted by: wayne.beaton._NOSPAM_eclipse.org
www wrote:
> Subversion.
> Thank you.
The short answer is no. The slightly longer answer is that CVS doesn't
take up too much room and is probably worth looking at. You can even
install it on one of your developer workstations. CVSNT runs as a
service; once you have it set up, you can basically forget about it.
I have it set up on one of my workstations at home and I use it all the
time. With almost no prior experience, I was able to get CVSNT up and
running in about 15 minutes.
Consider it.
HTH,
Wayne
Re: Version control in Eclipse? [message #191027 is a reply to message #191001] |
Wed, 31 January 2007 14:10 |
Well that's interesting. Does it actually manage versions with the
file:// protocol, or is it just basic file copy?
Wayne
Re: Version control in Eclipse? [message #191051 is a reply to message #191027] |
Wed, 31 January 2007 14:52 |
the repository is built the same way as repositories than can be
accessed via http or svn protocols, and afaik it is used the same way.
but you can use file:/// protocol only if you are using JavaHL wrapper
to Subversion API. JavaSVN lib doesn't support file protocol
bartosz michalik
Re: Version control in Eclipse? [message #191177 is a reply to message #191001] |
Wed, 31 January 2007 20:30 |
Originally posted by: hendrik_maryns.despammed.com
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
NotDashEscaped: You need GnuPG to verify this message
Bartosz Michalik uitte de volgende tekst op 01/31/2007 02:39 PM:
> www wrote:
>> Subversion.
>> Thank you.
Newer versions of Subclipse support file:/// too.
H.
Hendrik Maryns
http://tcl.sfs.uni-tuebingen.de/~hendrik/
www.lieverleven.be
http://aouw.org
http://catb.org/~esr/faqs/smart-questions.html
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.2 (GNU/Linux)
iD8DBQFFwPx1e+7xMGD3itQRAssvAJ0ZJO8/dZuwEnqmzwS5vGE8zrVGwwCd FUjr
+4B/YzNO9AR+PZ7ZUtJ5poA=
=yMgX
-----END PGP SIGNATURE-----
FUDForum. Page generated in 0.09066 seconds
