Home » Eclipse Projects » Eclipse Platform » About Eclipse IAdaptable, IAdapterFactory, IAdapterManager
About Eclipse IAdaptable, IAdapterFactory, IAdapterManager [message #190857] Fri, 06 February 2004 20:37 Go to next message
Originally posted by: charleszq.eastday.com
Hi there,
I'm now confused by the usage of IAdaptable, IAdapterFactory,
IAdapterManager, does anyone have some resource links or sample codes?
Thanks.
Actually, I just wanna know the architecture of the Eclipse framework, when
does a view, say, the property sheet view, asks the framework an instance of
IPropertySource? How can I write my own IAdapterFactory, and register it
into an IAdapterManager, and make my own view ask the framework for some
adapter via the getAdapter method of an instance of IAdaptable?
Thanks.
Charles
Re: About Eclipse IAdaptable, IAdapterFactory, IAdapterManager [message #190980 is a reply to message #190857] Sat, 07 February 2004 11:07 Go to previous messageGo to next message
Originally posted by: pnehrer.freeshell.org
Charles,
the Property Sheet view, specifically, listens to selection changes and
attempts to display the properties of the currently selected object. To
get the properties, it uses the IPropertySource protocol. When the
selection changes, it asks the selected object for that interface (or an
adapter for that interface).
Consider this scenario:
1. Suppose you have a view, or something else, that serves as a
selection provider -- it provides your model objects, say class
MyModelObject.
2. Create an adapter class that implements IPropertySource, say
MyModelObjectPropertySource. This one in particular would probably be
instance-specific -- it'll wrap a specific MyModelObject instance. Thus,
let's assume it'll have a public constructor with signature
MyModelObjectPropertySource(MyModelObject).
3. Create an adapter factory class for your model objects. You may want
to use it for adapters other than IPropertySource. E.g.,
public class MyAdapterFactory implements IAdapterFactory {
private static final Class[] ADAPTER_LIST = { IPropertySource.class };
public Object getAdapter(Object adaptableObject, Class adapterType) {
if(IPropertySource.class.equals(adapterType)) {
if(adaptableObject instanceof MyModelObject)
return new
MyModelObjectPropertySource((MyModelObject)adaptableObject);
return null;
public Class[] getAdapterList() {
return ADAPTER_LIST;
4. In your plug-in class, instantiate your adapter factory and register it:
private MyAdapterFactory myFactory;
public void startup() throws CoreException {
super.startup();
workbenchAdapterFactory = new WorkbenchAdapterFactory();
IAdapterManager mgr = Platform.getAdapterManager();
mgr.registerAdapters(workbenchAdapterFactory, IRSSElement.class);
And to be nice, unregister on shutdown:
public void shutdown() throws CoreException {
mgr.unregisterAdapters(workbenchAdapterFactory);
super.shutdown();
Now, when your MyModelObject is selected and the Property Sheet view is
open, it will display your properties as implemented in
Hope this helps.
--Peter
Charles wrote:
> Hi there,
> Thanks.
> Thanks.
> Charles
Re: About Eclipse IAdaptable, IAdapterFactory, IAdapterManager [message #190988 is a reply to message #190980] Sat, 07 February 2004 11:10 Go to previous messageGo to next message
Sorry, Step 4 should say:
super.startup();
myFactory = new MyAdapterFactory();
mgr.registerAdapters(myFactory, MyModelObject.class);
mgr.unregisterAdapters(myFactory);
super.shutdown();
Re: About Eclipse IAdaptable, IAdapterFactory, IAdapterManager [message #191052 is a reply to message #190988] Sat, 07 February 2004 22:09 Go to previous message
Thank you, Peter, that really helps. I'm really confused by where to
register my Adapter Factory. So if I'm doing RCP program with Eclipse 3.0, I
should register my factory in my WorkbenchAdvisor.
Thanks.
Charles
"Peter Nehrer" <pnehrer@freeshell.org> wrote in message
news:c032mn$en8$2@eclipse.org...
it:
> super.startup();
> super.shutdown();
Previous Topic:Import statement on Panther not same as XP?
Next Topic:Moving from windows to Linux
Current Time: Mon Sep 01 06:09:00 EDT 2025
Powered by FUDForum. Page generated in 0.08543 seconds
